Ethercat HAL driver
5 years 4 months ago #212462 by Masa
Replied by Masa on topic Ethercat HAL driver
I connect the encoder Z phase signal from the servo driver to the lacth input using a signal conversion circuit, but the HAL Pin connection fails.
net home-index-enable joint.0.index-enable lcec.0.1.enc-0-latch-ext-valid
error:
Signal'home-index-enable' can not add OUT pin'lcec.0.1.enc-0-latch-ext-valid', it already has I / O pin'joint.0.index-enable'
No change in the signal is felt when observing with the Halscope. When I connected it to the gate instead of the latch, I was able to see the change in the signal on the Hal Watch. However, I am having trouble connecting the Hal Pin with the same error.
Am I doing something wrong?
5 years 4 months ago #212468 by db1981
Replied by db1981 on topic Ethercat HAL driver
hello,
for homing you have to connect the joint.X.index-enable pin to enc-0-index-ext-pos-enable or neg-enable pin (homing at pos/neg edge of the latch input).
The latch-ext-valid pin is only the return for an real latch mesaurement function.
The following user(s) said Thank You: Masa
5 years 4 months ago #212470 by db1981
hello,
theres an bug in your hal file.
Move the line "addf lcec.write-all servo-thread" at the last position of the addf's, after your line "addf conv-float-s32.7 servo-thread ".
at the moment your are constantly writing zero to the drives, because you are sending the output (write-all) before you are doing scaling and calculations.
And you have to move all convertions that are related to inputs (feedback) between
lcec-read and motion, otherwise motion reads zero or old values to.
-addf lcec.read-all
-addf input conversions....
-addf motion, pids, classic ladder...
-addf output conversions....
-addf lcec.write-all (the last)
all modules are called in every cycle in the order you have placed addf in the hal.
read this answer again: forum.linuxcnc.org/24-hal-components/223...er?start=1140#199443
5 years 4 months ago #212472 by Masa
Hi
I seem to have misunderstood. Homing seems to be successful. Since the operation is different from what you want, we will set it while trying the difference in parameters.
Thank you.
5 years 4 months ago #212474 by db1981
if it not works like expected, you have to set the parameter 8060:02 (Enable enc reset at latch) to true in the em7004 modul.
I cant remeber about that at the moment, it has been to long ago.
5 years 4 months ago #212486 by Masa
Hi
The difference from the expected behavior is the behavior pattern of homing, not the behavior of em7004. Homing is working with the description of hal you pointed out. I want to reproduce the FANUC homing that is often done on Japanese machines, so I will devise the settings of linuxcnc.
Thanks for any further advice.
Time to create page: 2.081 seconds
