Ethercat HAL driver
5 years 4 months ago - 5 years 4 months ago #211403 by Masa
Replied by Masa on topic Ethercat HAL driver
Hello
I am writing this from Japan using Google Translate.
I would like to use LinuxCNC + EtherCAT.
Currently, the Beckhoff EM7004 can drive the servo motor. However, since the Z phase of the encoder cannot be used for Homing, I am thinking of changing the EM7004 to EL4132 + EL5102. Can the EL5102 be used with the EtherCAT HAL Driver for encoder input?
Since it is a machine translation, I apologize if it does not convey well.
Thank you .
Last edit: 5 years 4 months ago by Masa.
5 years 4 months ago #211405 by db1981
Replied by db1981 on topic Ethercat HAL driver
Hello,
EL5102 is not yet implemented.
I am using EM7004 for Encoder Z Homing on two machines. I used an Signal Converter to convert the Z Signal from the glass scales to the 24V Latch input of the EM7004.
www.leg-gmbh.de/en/html/signal_converter.html
The following user(s) said Thank You: Masa
5 years 4 months ago #211409 by Masa
Thank you for your great advice.
I will try to find something similar in Japan.
5 years 4 months ago #212138 by jc2ktr
Replied by jc2ktr on topic Ethercat HAL driver
Hi it´s been a while since i was last online,
but i have not found the time to work on my CNC lately.
I have now changed all my motors and drives at my CNC to EtherCAT Drives from Rexroth.
I had in january/february a functional setup on my Testbench.
After the changes to 3 Drives and reconfig of my Hal.
I am able to Enable all of the drives, but they don´t react on jog comands or MDI comands.
When i try to move the axis by hand the driver´s immediatly corrects the positions.
i upload my config and hal.
maybe someone could take a look at it, if there are some errors maybe.
Thanks a lot.
File Name: EtherCAT_SOE.ini
File Size:2 KB
File Name: EtherCAT_SOE.hal
File Size:7 KB
File Name: ethercat_s...ives.xml
File Size:5 KB
File Name: postgui_call_list.hal
File Size:0 KB
File Name: custom_postgui.hal
File Size:0 KB
5 years 4 months ago #212141 by thomaseg
Replied by thomaseg on topic Ethercat HAL driver
db1981 wrote: EL5102 is not yet implemented.
I'm having the "same" issue with EL5112, it's missing from the library... is it possible to "bribe" someone to make it? I'm not clever enough myself :-/
5 years 4 months ago #212187 by db1981
hello,
EL5102 and EL5112 are lieing next to me on the desk....
I need them for one of the next projects, i estimat i will do the drivers in the last week of june.
The following user(s) said Thank You: besriworld, thomaseg
Time to create page: 0.799 seconds
