- Thank you received: 92
Ethercat HAL driver
- besriworld
5 years 5 months ago - 5 years 5 months ago #209806
by besriworld
Replied by besriworld on topic Ethercat HAL driver
thanks for the help . I'm uploading new files. I did a new installation linuxcnc ethercat
There is no change.
I start LinuxCNC from the icon
PS: I make a new installation of LinuxCNC from this link Debian witch Ethercat
But I have new error again.
Debug file information:
Note: Using POSIX realtime
/usr/share/linuxcnc/hallib/core_sim.hal:29: Pin 'joint.1.motor-pos-cmd' does not exist
3330
Stopping realtime threads
Unloading hal components
There is no change.
3330
Last edit: 5 years 5 months ago by besriworld.
- Grotius
- Thank you received: 2349
5 years 5 months ago - 5 years 5 months ago #209824
by Grotius
Replied by Grotius on topic Ethercat HAL driver
3330
This is a hal message. It says the stepgenerator position command pin does not exist. I expect you edited hal files.
If you start the linuxcnc axis build in example from the linuxcnc config picker, check if this works.
Then for ethercat you should start with something very minimal in hal. Like only adding the lcec to the servo threat.
Step by step you gonna build it up. Attached a hal files that you can strip down and then try ant load it.
These lines should be your starting point for succes :
And edit the attached xml file to your needs.
3330
loadrt threads name1=base-thread fp1=0 period1=15000 name2=servo-thread period2=1000000
loadusr -W copy_filepath_here_that_points_to/lcec_conf copy_filepath_here_that_points_to/ethercat-conf.xml
loadrt lcec
net ec-slaves-responding <= lcec.slaves-responding
net ec-link-up <= lcec.link-up
net ec-all-op <= lcec.all-op
addf lcec.read-all base-thread
addf lcec.write-all base-thread
Last edit: 5 years 5 months ago by Grotius.
- db1981
- Thank you received: 276
5 years 5 months ago #209834
by db1981
Replied by db1981 on topic Ethercat HAL driver
remove the calls to the unneccesary hal files in the ini file HAL Section .
core _sim.hal should not be loaded.
and load your halfile with the ethercat lines as normal hal. not as postgui hal file.
- besriworld
5 years 5 months ago #209896
by besriworld
Hello ,
thanks for the help !!!
From solving one error I go to another. I reinstalled Linux. I did everything from the beginning.
I received a new error :
./ethercat_conf.hal:1: lcec_conf exited without becoming ready
1579
1579
- db1981
5 years 5 months ago #209900
by db1981
Hello,
please check what happens if you use this ethercat_conf file...
- besriworld
5 years 5 months ago #209916
by besriworld
Thanks a lot, I have a new error :
note: MAXV max: 400.000 units/sec 24000.000 units/min
note: LJOG max: 400.000 units/sec 24000.000 units/min
note: LJOG default: 400.000 units/sec 24000.000 units/min
Waiting for component 'inihal' to become ready....................................A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
...17861
17883
HAL: ERROR: exit called before init
<commandline>:0: waitpid failed milltask inihal
<commandline>:0: milltask exited without becoming ready
The error does not change even when the LAN cable is switched off.
...17861
17883
Time to create page: 3.922 seconds
