- Thank you received: 4
Ethercat HAL driver
- juniorfi
5 years 1 month ago #220411
by juniorfi
Replied by juniorfi on topic Ethercat HAL driver
Hi udoS,
I think will be better for me right now to use open source software at University.
But will be nice to know if you have experience with LinuxCNC and TwinSAFE.
Because is undocumented right now and I guess just few knows how to get that working (I haven't yet, unfortunately).
Regards.
Regards.
- udoS
- Thank you received: 25
5 years 1 month ago #220430
by udoS
Replied by udoS on topic Ethercat HAL driver
@juniorfi
Sorry, no I do have not. I left the etherlab-ethercat some time back. No TwinSAFE.
And no Docu is one of the major problems in Linuxcnc.
I use a soft-plc with an etherCAT Master and a shared memory to connect to Lcnc.
I'm working on a nml interface but not ready yet.
Every thing regarding etherCAT is done in the plc.
Best regds
Udo
Best regds
Udo
- yrodriguez1234
5 years 1 month ago #221156
by yrodriguez1234
Replied by yrodriguez1234 on topic Ethercat HAL driver
Hi.
I am looking for setting up a raspberry pi 4 as ethercat slave to send image position to a ethercat Master to a PC with preemt rt with linuxcnc-ethercat and LCNC 2.8 almost all show how setting raspberry pi like Master but never show how setting one like slave.
Thanks.
Thanks.
- udoS
5 years 1 month ago - 5 years 1 month ago #221175
by udoS
@yrodriguez
This board makes the RPi3/4 a slave. Works great. Easy to setup.
Gives you a max of 128 Bytes Space.
Best thing: Great support ! "Andrea Bausano"
www.bausano.net/en/hardware/ethercat-e-a...t-and-raspberry.html
Best regds. udo
Best regds. udo
Last edit: 5 years 1 month ago by udoS.
- yrodriguez1234
5 years 1 month ago #221188
by yrodriguez1234
Thanks udo.
Will be possible a hal component for LCNC that convert a raspberry pi 4 in a ethercat slave.
- db1981
- Thank you received: 276
5 years 1 month ago - 5 years 1 month ago #221190
by db1981
Replied by db1981 on topic Ethercat HAL driver
hello,
you can't build an ethercat slave without an licensed hardware chip or Asic firmware by beckhoff. You can code your own master, but not legaly a slave.
For this you can by boards/Chips from Beckhoff ET1100 / ET1815 or licensed ic's at Infinion / Microchip etc...
if you need an high counts of pieces them cost only a few dollars...
for prototypes or homebuildings i would by an ethercat evaluation Kit and then use Soes (simple open ethercat slave) or buy an ready to use rasppi or arduino expansion board.
getting your own slave running with linuxcnc ethercat then, is the smallest step.... (coding own driver or config manual in the conf xml.)
Last edit: 5 years 1 month ago by db1981.
Time to create page: 1.562 seconds
