Ethercat HAL driver
5 years 1 month ago #221203 by udoS
Replied by udoS on topic Ethercat HAL driver
There is an other problem I see here.
If your RPi has the ethercat master running then there is NO free NIC.
So you need additional hardware one or the other way. Wether it's the slave HAT or TCP HAT.
What is that setup anyway. Two interconnected robots. Working together. Sounds interesting.
best rgds. udos
5 years 1 month ago - 5 years 1 month ago #221205 by yrodriguez1234
Replied by yrodriguez1234 on topic Ethercat HAL driver
I measuring position of parts that move on a conveyor with my rpi + camera this position is send to trípod robot controled by PC with linuxcnc.
I want sent the position of moving parts through ethercat.
I made this with a raspberry pi but latency is high (70000ns) to improve this I use a PC with linuxcnc to control de robot and latency is better (16000ns) but I can not get comunícate de rpi with PC.
Last edit: 5 years 1 month ago by yrodriguez1234.
5 years 1 month ago #221231 by udoS
Just so I understand correctly.
You already have the coordinates of your moving part on the rip available. ( say: just 3 float numbers ; )
You need those 3 numbers transferred to your PC into the cnc. So, it's a matter of testing, but you could stream these coordinates over the Wifi of the  RPi to your PC.
What camera do you use and what's the software for position recognition. I don' think that the latency of the RPi4 is the problem.
look from 45sec on.  This is all running on a RPi4 ;
Best rgds Udo
5 years 1 month ago - 5 years 1 month ago #221234 by yrodriguez1234
I have a rpi + picamera with opencv 4.5 to position and orientation measurement, the PC with LCNC control 4 stepper motor through paralell Port and every pulse output is a 20khz, now the set of position need be send to PC but I don't know how to do it.
Could You told me how stream position from rpi to PC using whatever comunication method.
The latency on LCNC on rpi increase when a use opencv to image processing and don't let me get 20khz, for this a use PC to control three robot axis and one axis to conveyor and after put adicional axis for a rotation gripper.
5 years 1 month ago #221259 by udoS
@yrodriguez
First: very nice, clean setup. My compliments.
As I understand you do NOT need the ethercat master on the RPI, you only use it for the camera and the position recognition.
If you can make up your mind to go for the Epocat slave HAT then you can easy bring your data to your PC with the ethercat master on the PC.
I could help you on that for the plugin component.
If speed is not an issue and you do not use the tcp-port on the RPi, then you could use a client/server socket solution over tcp writing the data directly into the HAL of Lcnc.
If you need more speed or accuracy consider the FR1000 from Bausano, giving you 5 axis Puls/dir over ethercat plus some additional I/O.
Best Rgds. udo
5 years 1 month ago #221269 by yrodriguez1234
I was thinked to use ethercat to sending parts position from rpi to PC controller but as both are setup master ethercat i can not comunicate it.
Now i don't goint to use ethercat i goint to use tcp port of rpi and tcp port of PC with a client/server socket to send position of parts like udo sugested, but I don't know use a socket, could You help me with it, i great you.
Time to create page: 1.970 seconds
