- Thank you received: 276
Ethercat HAL driver
- db1981
4 years 11 months ago #225817
by db1981
Replied by db1981 on topic Ethercat HAL driver
Dint and Sint , are s32 too. IN hal they are all 4 Byte, casting is done by the value of bitlen .
The following user(s) said Thank You: Schaumstofffräsnewbie
- Schaumstofffräsnewbie
4 years 11 months ago #226069
by Schaumstofffräsnewbie
Replied by Schaumstofffräsnewbie on topic Ethercat HAL driver
Changed the syncmanager Entrys to syncManager, and changed the data types like you described it. Now I got the following errors:
I see that got no permission to enter the ethercat-conf file but I did not find the option where i can change the entry permissions yet..
- db1981
4 years 11 months ago #226081
by db1981
is the hal file still the same as above?
seems like a typo, because at one of your last posts, lcec_conf has worked...
4 years 11 months ago #226082
No I changed it a little bit, because of the execution order stuff you mentioned.
This is it now:
This is it now:
- db1981
4 years 11 months ago - 4 years 11 months ago #226093
by db1981
in line 2 the component is missing.
change:
loadusr -W /home/sfm100/linuxcnc/configs/SFM100/ethercat-conf.xml
to:
loadusr -W lcec_conf /home/sfm100/linuxcnc/configs/SFM100/ethercat-conf.xml
change:
to:
Last edit: 4 years 11 months ago by db1981.
4 years 11 months ago #226553
Took my old ethercat.hal file with the adjustments you mentioned, but I got a different error. Seems like I got Permission issues for some access..
I attached the used file below and the error message from the terminal.
Time to create page: 2.244 seconds
