Ethercat HAL driver
5 years 4 days ago #224564 by db1981
Replied by db1981 on topic Ethercat HAL driver
Hello Robert,
why is your EM7004 not working?
This has been the first module that ever works.... For using an EM7004, linuxcnc-ethercat has been born.....
5 years 3 days ago #224609 by CORBETT
Replied by CORBETT on topic Ethercat HAL driver
I believe lightning hit the power line... as it and the PLC that I bought were both no good....
I have plenty of other setups using EL4132's, but wanted to use the EM7004 for one of our 4 axis mills for a nice compact setup.  Yeah I have always wanted one and too bad the very one that I bought was non-functioning....   Plus the loss of money on non-working unit.
4 years 11 months ago - 4 years 11 months ago #225468 by ASKoskov
Replied by ASKoskov on topic Ethercat HAL driver
I think it doesn't reach the op state.
Last edit: 4 years 11 months ago by ASKoskov.
The following user(s) said Thank You: GuiHue
  • Schaumstofffräsnewbie
  • Senior Member
  • Senior Member
4 years 11 months ago #225793 by Schaumstofffräsnewbie
Replied by Schaumstofffräsnewbie on topic Ethercat HAL driver
When I try to start Linuxcnc with my configuration, I get the following error messages:
lcec_conf: ERROR: unexpected node syncmanager found
lcec_conf: ERROR: Parse error at line 4: parsing aborted
/usr/share/linuxcnc/hallib/ethercat.hal:1: waitpid failed lcec_conf lcec_conf
/usr/share/linuxcnc/hallib/ethercat.hal:1: lcec_conf exited without becoming ready
After that lcnc is shutting down.
I attached my .ini, my ethercat.hal and my ethercat-config.xml
I hope you can find what I am missing here (I am new to linux, linuxcnc and HAL)
best regards
Antonio
4 years 11 months ago #225807 by db1981
Hello,
-"syncmanager" hast to be "syncManager" ( M)
-as haltypes only exists (float, bit, u32, s32) you have to change this
uint = u32, int = s32
-at this stage for getting ethercat communication to work, your hal file works.
but for motion etc. it will not. search in this thread for "execution order" i have explained this a few times...
The following user(s) said Thank You: tommylight, jc2ktr
  • Senior Member
  • Senior Member
4 years 11 months ago #225814 by Schaumstofffräsnewbie
Okay, so if I got u right, I need to do your suggested changes in my ethercat-conf.xml.
But if UINT=u32 int=s32, what about DINT and SINT?
I guess that they are not float, but are they bit?
Time to create page: 3.756 seconds
