- Thank you received: 114
Ethercat HAL driver
- bkt
5 years 8 months ago - 5 years 8 months ago #199874
by bkt
Replied by bkt on topic Ethercat HAL driver
ethercat slaves -v command show these situations:
Enable PDO Configuration: no <- - - - - el5151
Enable Upload at startup: no
where all other slaves have:
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes <- - - - all other (not 1008-2008)
Enable SDO complete access: no
Warning: Spoiler!
=== Master 0, Slave 6 ===
Device: Main
State: PREOP
Flag: +
Identity:
Vendor Id: 0x00000002
Product code: 0x141f3052
Revision number: 0x00190000
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 2320 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0* EBUS up open yes 5 2309976900 0 155
1 EBUS down closed no - - - -
2 N/A down closed no - - - -
3 N/C down closed no - - - -
Mailboxes:
Bootstrap RX: 0x1000/244, TX: 0x10f4/244
Standard RX: 0x1000/128, TX: 0x1080/128
Supported protocols: CoE, FoE
General:
Group: Measuring
Image name:
Order number: EL5151
Device name: EL5151 1K. Inc. Encoder
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 130 mA
CoE details:
Enable SDO: yes
Last edit: 5 years 8 months ago by bkt.
- db1981
- Thank you received: 276
5 years 8 months ago - 5 years 8 months ago #199875
by db1981
Replied by db1981 on topic Ethercat HAL driver
not your ini debug ....
In an terminal window write the command "ethercat debug 1".
This sets the debug level from the ethercat master to the syslog (dmesg).
(0 = debug off, 1=debug messages on, 2=all frames to log) .
After this there must be ethercat messages in your dmesg log.
Start linuxcnc, open a second terminal write the command dmesg, there should be ethercat messages.
you should get something like this:
Warning: Spoiler!
[ 6878.616403] EtherCAT WARNING 0-main-1: Failed to clear PDO mapping.
[ 6878.616404] EtherCAT WARNING 0-main-1: Currently mapped PDO entries: 0x2050:00/32 0x2051:00/32. Entries to map: 0x2050:00/32 0x2051:00/32
[ 6878.616410] EtherCAT WARNING 0-main-1: Failed to configure mapping of PDO 0x1601.
[ 6878.628440] EtherCAT ERROR 0-main-1: SDO download 0x1602:00 (1 bytes) aborted.
[ 6878.628443] EtherCAT ERROR 0-main-1: SDO abort message 0x06010002: "Attempt to write a read-only object".
[ 6878.628445] EtherCAT WARNING 0-main-1: Failed to clear PDO mapping.
[ 6878.628445] EtherCAT WARNING 0-main-1: Currently mapped PDO entries: 0x2850:00/32 0x2851:00/32. Entries to map: 0x2850:00/32 0x2851:00/32
[ 6878.628451] EtherCAT WARNING 0-main-1: Failed to configure mapping of PDO 0x1602.
[ 6878.802190] EtherCAT 0: Domain 0: 2 working counter changes - now 29/38.
[ 6879.097563] EtherCAT ERROR 0-main-1: SDO download 0x1A01:00 (1 bytes) aborted.
[ 6879.097568] EtherCAT ERROR 0-main-1: SDO abort message 0x06010002: "Attempt to write a read-only object".
[ 6879.097569] EtherCAT WARNING 0-main-1: Failed to clear PDO mapping.
[ 6879.097570] EtherCAT WARNING 0-main-1: Currently mapped PDO entries: 0x6611:00/32 0x6613:00/32. Entries to map: 0x6611:00/32 0x6613:00/32
[ 6879.097576] EtherCAT WARNING 0-main-1: Failed to configure mapping of PDO 0x1A01.
[ 6879.109605] EtherCAT ERROR 0-main-1: SDO download 0x1A02:00 (1 bytes) aborted.
[ 6879.109608] EtherCAT ERROR 0-main-1: SDO abort message 0x06010002: "Attempt to write a read-only object".
[ 6879.109610] EtherCAT WARNING 0-main-1: Failed to clear PDO mapping.
[ 6879.109610] EtherCAT WARNING 0-main-1: Currently mapped PDO entries: 0x6E11:00/32 0x6E13:00/32. Entries to map: 0x6E11:00/32 0x6E13:00/32
[ 6879.109616] EtherCAT WARNING 0-main-1: Failed to configure mapping of PDO 0x1A02.
[ 6879.806263] EtherCAT 0: Domain 0: 2 working counter changes - now 32/38.
[ 6880.656964] EtherCAT 0: Slave states on main device: PREOP, SAFEOP, OP.
[ 6880.810332] EtherCAT 0: Domain 0: Working counter changed to 35/38.
[ 6880.945634] EtherCAT 0: Slave states on main device: PREOP, OP.
[ 6882.313434] EtherCAT 0: Domain 0: Working counter changed to 38/38.
[ 6882.388840] EtherCAT 0: Slave states on main device: SAFEOP, OP.
[ 6882.677523] EtherCAT 0: Slave states on main device: OP.
[ 6912.574521] EtherCAT 0: Master thread exited.
[ 6912.574637] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 6912.574704] EtherCAT ERROR 0-main-0: Failed to receive AL state datagram: Datagram initialized.
[ 6912.574728] EtherCAT 0: Releasing master...
[ 6912.574730] EtherCAT 0: Released.
[ 6912.578750] EtherCAT 0: Slave states on main device: SAFEOP, OP + ERROR.
[ 6912.582796] EtherCAT WARNING 0-main-0: Changed to SAFEOP + ERROR in the meantime.
[ 6912.582799] EtherCAT WARNING 0-main-2: Changed to SAFEOP + ERROR in the meantime.
[ 6912.651939] EtherCAT 0: Slave states on main device: PREOP, SAFEOP + ERROR.
[ 6912.945493] EtherCAT 0: Slave states on main device: PREOP.
[ 6913.185198] EtherCAT WARNING: Datagram ffff894e32dde360 (master-fsm) was SKIPPED 1 time.
[ 7246.297856] EtherCAT 0: Master debug level set to 1.
Last edit: 5 years 8 months ago by db1981. Reason: added dmesg example
The following user(s) said Thank You: bkt
- db1981
5 years 8 months ago #199879
by db1981
CoE details:
Enable SDO: yes //sdo communication
Enable SDO Info: yes //sdo info exists in the si eeprom
Enable PDO Assign: yes //pdo assign to sync managers allowed
Enable PDO Configuration: yes //free mapping from (sdo) register to cyclic pdos allowed, configurable, not neccesary for fixed function cards, in servo drives you can choose what parameter should be exists on the bus.
Enable Upload at startup: no //Mailbox stuff, upload complete object dictionry, file access .....
Enable SDO complete access: no //write raw data to index , without subindexs
- bkt
5 years 8 months ago - 5 years 8 months ago #199937
by bkt
I used ethercat debug 1 ysterday but nothing of relevant ... so i figured i meant the axis gui debug level .... however i attach the dmesg, which has no warming, just at some point slave 6 doesn't go into OP mode and linuxcnc doesn't seem to care anymore. I ask you once again because it is not clear to me: in my xml el5151 there is .... but in the .hal file I do not use it .... is not that it is for this reason that linuxcnc does not send it in OP? I don't use it because I didn't understand what signals I can use, however having read lcec_el5151.c I can use the enc-raw-count or enc-count pin.
debug in attach.
debug in attach.
- bkt
5 years 8 months ago #199940
by bkt
Just now I observe these:
[ 1460.285661] EtherCAT DEBUG 0-main-5: Assigning SII access to PDI.
[ 1460.285662] EtherCAT DEBUG 0-main-6: Configuring mailbox sync managers...
[ 1460.285663] EtherCAT DEBUG 0-main-6: SM0: Addr 0x1000, Size 128, Ctrl 0x26, En 1
[ 1460.285664] EtherCAT DEBUG 0-main-6: SM1: Addr 0x1080, Size 128, Ctrl 0x22, En 1
[ 1460.289681] EtherCAT DEBUG 0-main-0: Assigning SII access to PDI.
[ 1460.289682] EtherCAT DEBUG 0-main-1: Assigning SII access to PDI.
[ 1460.289683] EtherCAT DEBUG 0-main-2: Assigning SII access to PDI.
[ 1460.289684] EtherCAT DEBUG 0-main-6: Assigning SII access to PDI.
[ 1460.297829] EtherCAT DEBUG 0-main-3: Now in PREOP.
[ 1460.297833] EtherCAT DEBUG 0-main-3: Assigning SII access back to EtherCAT.
[ 1460.297835] EtherCAT DEBUG 0-main-4: Now in PREOP.
[ 1460.297837] EtherCAT DEBUG 0-main-4: Assigning SII access back to EtherCAT.
[ 1460.297840] EtherCAT DEBUG 0-main-5: Now in PREOP.
[ 1460.297841] EtherCAT DEBUG 0-main-5: Assigning SII access back to EtherCAT.
[ 1460.302018] EtherCAT DEBUG 0-main-0: Now in PREOP.
[ 1460.302022] EtherCAT DEBUG 0-main-0: Assigning SII access back to EtherCAT.
[ 1460.302025] EtherCAT DEBUG 0-main-1: Now in PREOP.
[ 1460.302027] EtherCAT DEBUG 0-main-1: Assigning SII access back to EtherCAT.
[ 1460.302029] EtherCAT DEBUG 0-main-2: Now in PREOP.
[ 1460.302031] EtherCAT DEBUG 0-main-2: Assigning SII access back to EtherCAT.
[ 1460.302033] EtherCAT DEBUG 0-main-3: Finished configuration.
[ 1460.302035] EtherCAT DEBUG 0-main-4: Finished configuration.
[ 1460.302037] EtherCAT DEBUG 0-main-5: Finished configuration.
[ 1460.302039] EtherCAT DEBUG 0-main-6: Now in PREOP.
[ 1460.302041] EtherCAT DEBUG 0-main-6: Assigning SII access back to EtherCAT.
[ 1460.306209] EtherCAT DEBUG 0-main-0: Finished configuration.
[ 1460.306212] EtherCAT DEBUG 0-main-1: Finished configuration.
[ 1460.306215] EtherCAT DEBUG 0-main-2: Finished configuration.
[ 1460.306217] EtherCAT DEBUG 0-main-6: Finished configuration.
Is normal these? Or is because el5151 need to configure a sincManager as a drive, because I not defined a specific sinc manger for el5151 .....
- db1981
5 years 8 months ago #199943
by db1981
@bkt
-this is very strange now. Lcnc ethercat doesn't initialize slave 6.
-you don't need to connect a pin from the device in the hal
-no dc config needed for initialization
-please attach ini, hal, and the xml as file (i think it needs an deeper look)
-to avoid strange seetings, do a factory reset of the card: "ethercat download -p6 0x1011 0x01 0x64616F6C --type uint32" -> few seconds -> power cycle
Time to create page: 1.904 seconds
