Ethercat HAL driver
5 years 8 months ago #200124 by db1981
Replied by db1981 on topic Ethercat HAL driver
Ethercat version is EP 3E? is there anywere an english manual?
5 years 8 months ago - 5 years 8 months ago #200128 by bkt
Replied by bkt on topic Ethercat HAL driver
tomorrow is send you one pdf copy ... now I can't.
I understand the best way is to control dmesg ..... but I usually look for the shortest and safest way .... re-initializing everything seems pretty safe to me. Certainly it is inconvenient, but I have also had similar problems with bechkoff plc in the past .... I got the idea that it is a common problem with some types of intel chipset rj45 ports, used on small bechkoff plcs, on my pc and on EP3E drives.
bkt
Last edit: 5 years 8 months ago by bkt.
5 years 8 months ago #200514 by bkt
Sorry but administrator settings not permit upload file more big than 1.6Mb ..... I I split manual into 4 part.
5 years 7 months ago #201227 by besriworld
Replied by besriworld on topic Ethercat HAL driver
Hello ,
I have a question . I bought servo motors/driver with EtherCAT, but they are not supported by the HAL driver. I need to use a generic driver . Will I have a problem with latency? I have three drivers for 3axis Mori Seiki MV-JR
I am attaching the hml file for drivers (Adatech model QXEH10NE)
File Name: 6_ADTECH_X...1.38.xml
File Size:193 KB
5 years 7 months ago #201239 by db1981
Hello,
it makes no difference using the generic or an already programmed driver. All Slave Data is read and written once per rt cycle period.
5 years 7 months ago #201266 by jc2ktr
Replied by jc2ktr on topic Ethercat HAL driver
@db1981
you mentioned in an earlier Post that it is Possible to use EOE in LinuxCNC do you have any Expirience with it?
I tried to set it up but i am stuck.
I tried it with these Steps.
sf.net Etherlabmaster EOE
Time to create page: 3.836 seconds
