- Thank you received: 57
Ethercat HAL driver
- sirop
Has anybody tried to run a CoE slave at 250 us?
[strike]I found out that the usage of
void ecrt_slave_config_state(const ec_slave_config_t *sc, ec_slave_config_state_t *state)
in github.com/sittner/linuxcnc-ethercat/blo...c_main.c#L1086-L1097
can cause problems....[/strike]
Sorry, it was false alarm, this alleged bug was because of my experimenting with the code.
- highbiker
- Thank you received: 3
I have got a Problem with the inputs of one slave in my EtherCAT Network. I'm using the Etherlab Master 1.5.2 and the latest lcec driver from the sittner-git.
My Network extends of the following slaves:
Slave 1: Bausano EasyCAT Arduino Shield (32 byte Output, 32 byte Input)
Slave 2: Beckhoff EK1100
Slave 3: Beckhoff EL1008 (1 byte Input)
Slave 4: Beckhoff EL2008 (1 byte Output)
With my configuration linuxcnc starts and everything works exept the Inputs of the EasyCAT Arduino Shield. In Hal-Meter they are always 0.
I tested the Network with the Beckoff EtherCAT Configurator and there the inputs worked. So the EasyCAT Shield must be ok.
my ethercat-conf.xml:
The ESI (xml) File of the EasyCAT Shield could be found here:
www.bausano.net/images/arduino-easycat/EasyCAT.xml
while linuxcnc was running i read out the etherlab domain information (ethercat domain -v):
The input section of the EasyCAT ist missing and I'm confused about the size of 34. I think i should get 32+32+1+1=66. Are the inputs completely dropped?
In my dmesg output i also find the domain size of 34:
What am I doing wrong? I've run out of ideas. Could someone please help me to figure out a solution for my annoying problem.
Thanks and kind regards
Arndt
- sirop
highbiker wrote: In my dmesg output i also find the domain size of 34:
Code:[Do Jun 23 01:58:17 2016] EtherCAT 0: Using slave 0 as DC reference clock.
Seems to have only two Sync Managers:
You use however 4 Sync Managers.
BTW, what is the maximum cycle frequency this EasyCAT Arduino Shield can work with?
- highbiker
The four Sync Managers were just a test. At first I tried only two Sync Managers (0 and 1) with no success.
I don't know the max cycle frequency of the EasyCAT Shield, so I have to ask the manufacturer. But in Beckhoff EtherCAT Configurator it worked with 1ms. In LinuxCNC I also tried a cycle time of 25ms with no success too.
It's a mystery to me, why only the outputs operate. So the communication couldn't be completely wrong.
BTW: is there any way to use the Etherlab Master (Slaves PREOP -> OP and reading Process Data) from Terminal without using the lcec driver, or do I have to write a C-Program?
I would like to test my Network without lcec in order to identify the point of failure.
kind regards
Arndt
- sirop
highbiker wrote: Thanks for your fast reply!
That's strange as the case of only 2 Sync Managers is allowed by the EtherCAT standard.
Are you sure that you use the latest linuxcnc-ethercat? This patch github.com/sittner/linuxcnc-ethercat/com...e59d9d70b46cb2c7f3cc solved the parsing problem of complex pins,
so it might help you too.
Do you use this patch github.com/sittner/ec-debianize/blob/mas...ead_pdo_count.dpatch with etherlabmaster-1.5.2 ?
ethercat command line utility can help you read SDOs, not PDOs as those are read and written in a real time cycle.
You can however insert something like rtapi_print_msg at any place of linuxcnc-ethercat for debugging.
- sirop
I think my first answer was too fast and therefore incomplete.
1. Look, for example, at this line:
2. This Arduino slave has no DC functionality, however, this is the first slave on the physical ring in your case,
that's why it is chosen per default to be
So rearrange your slaves so that this Arduino slave without DC is not slave 0 .
