Ethercat HAL driver
14 Jul 2016 06:37 #77429 by zerix
Replied by zerix on topic Ethercat HAL driver
Servo invertores uses usual ethernet cable. Error LEDs don't blink or switch on.
Command "ethercat slaves" does nothing. it seems like:
#ethercat slaves
And nothing more.
Sometime IN and OUT ports of an EtherCAT drive are mixed up,
see page 11 of www.delta.com.tw/product/em/motion/motio...E_UM_EN_20150430.pdf .
Did you also follow Chapter 2 of the user manual?
You might try look through dmesg output... Nothing else comes to my mind.
what should i see? when use
dmesg output
i saw many strings. and find two strings, in that written "ethercat master 1.5.2..." and "master waiting devices..."
15 Jul 2016 03:53 #77475 by Roger
Replied by Roger on topic Ethercat HAL driver
Thought I better report we had some success a some weeks ago :) Ver happy to report the motors now run via linuxcnc.
But perhaps you can try it with EOE.
You have a running EtherCAT Master and the possibility to connect via IndraWorks over EOE. Then you have the possibility to get more information via the gui.
Thanks that was a very good idea. I was able to replicate the problem using TwinCat instead of linuxcnc - in Free run/Config mode, not in Run mode - and monitoring with IndraWorks over EoE.
The two key points:
The first problem was I was using the wrong position register for the positioning mode.
The other problem with our linuxcnc config was the NC cycle time TwinCat was using was not the same as the value we extracted from the xml file as per the tutorial. Once I realised that difference the remaining issues were reasonably straightforward to solve.
The issue in my previous post turned out to be a red herring.
Thanks for your help Andreas
The following user(s) said Thank You: Nico2017
15 Jul 2016 10:58 - 15 Jul 2016 10:59 #77480 by zerix
#ethercat slaves
And nothing more.
I found problem. ethernet-port haven't contact. i put paper in port and now i can see device. But now I am having other problem. when I write
ethercat upload -t int8 0x6061 0
it is showing me
Failed to upload SDO: input/output error
Last edit: 15 Jul 2016 10:59 by zerix.
15 Jul 2016 12:22 #77486 by sirop
Replied by sirop on topic Ethercat HAL driver
it is showing me
In my case:
$ ethercat upload -p1 -t int8 0x6061 0
0x08 8
So your line without position argument would work if the master sees only 1 slave on the network.
The following user(s) said Thank You: zerix
20 Jul 2016 08:21 #77681 by kehaar
Replied by kehaar on topic Ethercat HAL driver
Hello, everyone! Thank you for sharing your knowledge on this topic. I am a newbie in LinuxCNC and I managed to control Yaskawa servo drives through EtherCAT by following your advices!
Now I have an Ethernet device, and I have bought a Beckhoff EOE port switch, EL6601, for my system to communicate with this Ethernet device through EtherCAT. I believe that I need to write a driver for EL6601 to enable the communication. May I know how to write this driver? Is there any documents or other information I can refer to?
Thank you!
20 Jul 2016 10:12 #77694 by sirop
Thank you!
If you download the source code of the IgH EtherCAT-Master, you can run Doxygen over it.
It seems to me from the Doxygen output of eoe_request.c that you can run EoE only as a kernel space application,
so in principle it should be possible on RTAI to build such a kernel space component.
If you are on rt-preempt, then it might be worth having a look at userspace port of the IgH EtherCAT-Master
fh-soft.de/src/ethercat-userspace.html .
The following user(s) said Thank You: kehaar
21 Jul 2016 07:53 #77758 by zerix
it is showing me
In my case:
0x08 8
I have two servo. and one servo works normal. but second servo doesn't can work with ethercat. Green LED blinks, but orange LED doesn't blink or switch on. Can you also help me with command
ethercat reg_read
? i dont understand what i should write. when i wrote
ethercat reg_read -t int8 0x040e 1
it shows me
Failed to read register: Input/output error
when i wrote
ethercat reg_read -t int16 0x040e 1
it shows me last error again.
21 Jul 2016 09:21 #77761 by sirop
ethercat reg_read
it shows me
1. Please always use a position argument to avoid confusion as one cannot know if you have only 1 or more slaves on the
EtherCAT network.
2. You mentioned some hardware problems like loose contacts on the NIC ports.
So first do
ethercat slaves
just to know if the master can really see all slaves.
3.
ethercat reg_read [OPTIONS] <ADDRESS> [SIZE]
so your command should be either
ethercat reg_read -p$SLAVEPOSITION  -t int8 0x040e 1
or
ethercat reg_read -p$SLAVEPOSITION  -t int16 0x040e 2
But what is 0x40e register about? Never seen it...
As for LED indicators of the slave's states - rather consult the manual.
25 Jul 2016 09:09 #77967 by kehaar
Thank you for your reply!
Currently, apart from EL6601(Ethernet switch port from Beckhoff), I still have several EtherCAT devices to control simultaneously. Previously, I have written a HAL driver for EL3008, an 8 channel analog input I/Os from Beckhoff. However, I do not have any clue and experience in writing one for the EL6601, do you have any advice in writing an EtherCAT HAL driver for EL6601 under the LinuxCNC environment?
Thank you for your time !
25 Jul 2016 09:53 #77968 by sirop
First of all, it is worth looking at this docs patch:
sourceforge.net/p/etherlabmaster/code/ci...d87dcbc43fd04cffbea/
I cannot tell you more as I never used EoE functions of IgH EtherCAT-Master .
Besides this EL6601 manual makes a difference between Real-time data exchange and Non-real-time data exchange.
Non-real-time data exchange is the actual EoE.
So I would begin with standalone app just to learn how to "speak" with this slave either in real time or acyclic in terms of EL66601 manual.
Time to create page: 0.329 seconds
