- Thank you received: 57
Ethercat HAL driver
- sirop
ethercat slaves -v
or
ethercat master -v
- REEEN
I think some linking is missing probably
- narogon
- Thank you received: 14
I'm trying to configure a machine with 37 servos HIWIN. I created my own lcec_hiwin and everything is fine for many machines with 3, 4 or 5 servos.
I get some kind of problem when I connect more than 13 slaves. The 13th and 14th get stuck on PRE-OP with error and the following not even try to get OP.
the output of ethercat slaves for 15 servos:
The dmesg output:
Hal configuration:
And the xml:
I've tried to change all the xml parameters, refClockSyncCycles, Dc values... with no result. Has anybody any idea of how to solve this?
- sirop
Do you see
AL status code 0x002E is indeed unknown.
Besides all that:
lists.etherlab.org/pipermail/etherlab-dev/2016/000553.html0055-fsm_slave_config_scan-to-fsm_slave.patch
The motivating case was a network of about 100 slave devices; while scanning
is fast (under a second, after prior SII patches), the configuration process
to bring the slaves from PREOP to OP took about 80 seconds (and you could
see the lights coming on each slave in sequence). After the patch it takes
about 20 seconds.
- mfalcon
sirop wrote:
Code:[ 133.613219] EtherCAT ERROR 0 0:1: PDO entry 0x6000:01 is not mapped. [ 133.613226] LCEC: master 0 PDO entry registration failed
That's the point to research.
thanks for help.
but I searched over here and in internet and still and I could not figure out what is the cause or remedy of this problem. I used the example xml file by sascha, so where is the mistake?
one more question too: Am I supposed to be connected online to all devices that are defined in xml file during start up of linuxcnc with hal driver?? may be this what causes error ?
- sirop
thanks for help.
Which xml file by sascha is that?
