Ethercat HAL driver
- LinuxBen
9 years 8 months ago - 9 years 8 months ago #87602
by LinuxBen
Replied by LinuxBen on topic Ethercat HAL driver
Thanks for your response sirop. Very helpful. So I can continue this path.
Excuse me for the error I made with "syncmaster". I meant the XML tags "SyncManager"in the hal files of the tutorial docs.google.com/document/d/1GiB065ZIAaoM...xGQl2X9DM9-THNM/edit
or in github.com/sittner/linuxcnc-ethercat/blo...ex/ethercat-conf.xml .
I assume they are from the ESI xml file too. I'll look into that a bit deeper (toil was a new englisch word for me;-)
The ESI xml, I assume it is the correct one, can be found here if anyone comes along this thread: www.beckhoff.ch/default.asp?download/elconfg.htm
Thank you again
Ben
Thank you again
Ben
Last edit: 9 years 8 months ago by LinuxBen. Reason: Hyperlink was not recognised
- robh
- Thank you received: 24
9 years 6 months ago #90878
by robh
Replied by robh on topic Ethercat HAL driver
Hi
looking at trying this out,
i found on the wiki how to install so followed this
wiki.linuxcnc.org/cgi-bin/wiki.pl?EtherCatDriver
create a file "/etc/apt/sources.list.d/linuxcnc-mds.list":
deb repo.modusoft.de/linuxcnc/wheezy ./
# sudo apt-get update
# sudo apt-get install linuxcnc-ethercat
The etherlabmaster should be installed automaticaly.
Currently you will get a warning about missing key.
edit /etc/default/ethercat to match your setup
# sudo update-ethercat-config
reboot
# ethercat slaves
this sould show your connected slaves, which there is 0 and shows its loaded in dmsg
what else does one need todo to get things working in hal? i presume the above has installed everything needed?
i see you need to write a XML file is there any guids to what everything means or how to edit/write one?
looking to maybe end up using some servo drives on ethercat
thanks,rob
reboot
# ethercat slaves
thanks,rob
- sirop
- Thank you received: 57
9 years 6 months ago #90879
by sirop
Replied by sirop on topic Ethercat HAL driver
the linucxnc-ethercat in the modsoft repo is of 28-Jan-2015 16:03 .
There have been some important updates/commits since then.
So rather install from github sources.
- robh
9 years 6 months ago #90880
by robh
thank you,
take it the instructions in post #82576 are most current then
forum.linuxcnc.org/24-hal-components/223...iver?start=380#82576
- sirop
9 years 6 months ago - 9 years 6 months ago #90881
by sirop
well, they at least build from sources in forum.linuxcnc.org/24-hal-components/223...iver?start=380#82576 .
Last edit: 9 years 6 months ago by sirop. Reason: typo
- wazza77
9 years 6 months ago - 9 years 6 months ago #92420
by wazza77
Replied by wazza77 on topic Ethercat HAL driver
Hi Everyone
It has been a while since I posted on this EtherCAT driver forum and a lot has changed.
Due to recent cyclone here my last linuxnc setup received some terminal damage and now I have a new box
and I have installed the latest release of linuxcnc, I have the etherlab master working, and in the terminal, i can get my slaves
but it's now the linuxcnc EtherCAT HAL setup that is unclear to me previously I had cloned the sittner linuxcnc with the add hal EtherCAT component in it now I believe this is all changed to a deb package, and I am unsure of the correct steps involved
can someone make this a little bit clearer for me I have the linuxcnc-dev package how do I add the Hal EtherCAT component to this
I have looked at the post forum.linuxcnc.org/24-hal-components/223...iver?start=380#82576
And it still seems a little unclear to me the linuxcnc-ethercat.git doesn't seem to be the full linuxcnc?
Last edit: 9 years 6 months ago by wazza77.
Time to create page: 2.087 seconds
