Ethercat HAL driver
9 years 4 months ago #94305 by ChrisB
Replied by ChrisB on topic Ethercat HAL driver
Hi
i think i got the linuxcnc-ethercat installed.
After booting the ethercat leds are flashing.
If i try to start i get this debuginformation
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.9 Machine configuration directory is '/home/cnc/linuxcnc/configs/Ethercat' Machine configuration file is 'Ethercat.ini' INIFILE=/home/cnc/linuxcnc/configs/Ethercat/Ethercat.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./Ethercat.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=3699 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: lcec_conf: ERROR: Parse error at line 18: not well-formed (invalid token) ./Ethercat.hal:1: waitpid failed lcec_conf lcec_conf ./Ethercat.hal:1: lcec_conf exited without becoming ready 3699 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff90000 (usable) [ 0.000000] BIOS-e820: 000000007ff90000 - 000000007ff9e000 (ACPI data) [ 0.000000] BIOS-e820: 000000007ff9e000 - 000000007ffd0000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007ffd0000 - 000000007ffde000 (reserved) [ 0.000000] BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.5 present. [ 0.000000] DMI: System manufacturer System Product Name/P5KPL-CM, BIOS 0702 08/27/2010 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x7ff90 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-DFFFF write-protect [ 0.000000] E0000-EFFFF write-through [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 disabled [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00ff780] ff780 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 3652a000 - 3728d000 [ 0.000000] ACPI: RSDP 000fb6a0 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 7ff90000 0003C (v01 A_M_I_ OEMRSDT 08001027 MSFT 00000097) [ 0.000000] ACPI: FACP 7ff90200 00084 (v02 A_M_I_ OEMFACP 08001027 MSFT 00000097) [ 0.000000] ACPI: DSDT 7ff905c0 07BFA (v01 A0968 A0968000 00000000 INTL 20060113) [ 0.000000] ACPI: FACS 7ff9e000 00040 [ 0.000000] ACPI: APIC 7ff90390 0006C (v01 A_M_I_ OEMAPIC 08001027 MSFT 00000097) [ 0.000000] ACPI: MCFG 7ff90400 0003C (v01 A_M_I_ OEMMCFG 08001027 MSFT 00000097) [ 0.000000] ACPI: OEMB 7ff9e040 00080 (v01 A_M_I_ AMI_OEM 08001027 MSFT 00000097) [ 0.000000] ACPI: HPET 7ff981c0 00038 (v01 A_M_I_ OEMHPET 08001027 MSFT 00000097) [ 0.000000] ACPI: GSCI 7ff9e0c0 02024 (v01 A_M_I_ GMCHSCI 08001027 MSFT 00000097) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1159MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x0007ff90 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x0007ff90 [ 0.000000] On node 0 totalpages: 524063 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f552a200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2320 pages used for memmap [ 0.000000] HighMem zone: 294530 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ee00000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519967 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=52ffd0f1-7192-47ff-ae51-f8ee2d49581c ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 4193280 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:0007ff90) [ 0.000000] Memory: 2055080k/2096704k available (3495k kernel code, 41172k reserved, 1237k data, 416k init, 1187400k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:712 16 [ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2665.948 MHz processor. [ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5331.89 BogoMIPS (lpj=10663792) [ 0.004006] pid_max: default: 32768 minimum: 301 [ 0.004044] Security Framework initialized [ 0.004047] AppArmor: AppArmor disabled by boot time parameter [ 0.004063] Mount-cache hash table entries: 512 [ 0.004241] Initializing cgroup subsys cpuacct [ 0.004243] Initializing cgroup subsys memory [ 0.004250] Initializing cgroup subsys devices [ 0.004252] Initializing cgroup subsys freezer [ 0.004254] Initializing cgroup subsys net_cls [ 0.004256] Initializing cgroup subsys blkio [ 0.004261] Initializing cgroup subsys perf_event [ 0.004286] CPU: Physical Processor ID: 0 [ 0.004287] CPU: Processor Core ID: 0 [ 0.004289] mce: CPU supports 6 MCE banks [ 0.004295] CPU0: Thermal monitoring enabled (TM2) [ 0.004344] ACPI: Core revision 20120320 [ 0.012041] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.012393] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.054695] CPU0: Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz stepping 06 [ 0.056003] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver. [ 0.056003] ... version: 2 [ 0.056003] ... bit width: 40 [ 0.056003] ... generic registers: 2 [ 0.056003] ... value mask: 000000ffffffffff [ 0.056003] ... max period: 000000007fffffff [ 0.056003] ... fixed-purpose events: 3 [ 0.056003] ... event mask: 0000000700000003 [ 0.064075] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.076026] CPU 1 irqstacks, hard=f50d4000 soft=f50d6000 [ 0.076030] Booting Node 0, Processors #1 [ 0.008000] Initializing CPU#1 [ 0.088034] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.088073] Brought up 2 CPUs [ 0.088076] Total of 2 processors activated (10663.79 BogoMIPS). [ 0.089610] devtmpfs: initialized [ 0.089610] PM: Registering ACPI NVS region [mem 0x7ff9e000-0x7ffcffff] (204800 bytes) [ 0.089610] dummy: [ 0.089610] NET: Registered protocol family 16 [ 0.089610] ACPI: bus type pci registered [ 0.089610] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) [ 0.089610] PCI: not using MMCONFIG [ 0.089610] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4 [ 0.089610] PCI: Using configuration type 1 for base access [ 0.092074] bio: create slab <bio-0> at 0 [ 0.092099] ACPI: Added _OSI(Module Device) [ 0.092099] ACPI: Added _OSI(Processor Device) [ 0.092099] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.092099] ACPI: Added _OSI(Processor Aggregator Device) [ 0.093450] ACPI: EC: Look up EC in DSDT [ 0.095129] ACPI: Executed 1 blocks of module-level executable AML code [ 0.099455] ACPI: SSDT 7ffa00f0 00214 (v01 AMI CPU1PM 00000001 INTL 20060113) [ 0.099824] ACPI: Dynamic OEM Table Load: [ 0.099827] ACPI: SSDT (null) 00214 (v01 AMI CPU1PM 00000001 INTL 20060113) [ 0.100043] ACPI: SSDT 7ffa0310 00143 (v01 AMI CPU2PM 00000001 INTL 20060113) [ 0.100403] ACPI: Dynamic OEM Table Load: [ 0.100406] ACPI: SSDT (null) 00143 (v01 AMI CPU2PM 00000001 INTL 20060113) [ 0.100720] ACPI: Interpreter enabled [ 0.100733] ACPI: (supports S0 S1 S3 S4 S5) [ 0.100760] ACPI: Using IOAPIC for interrupt routing [ 0.100782] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) [ 0.102143] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in ACPI motherboard resources [ 0.102146] PCI: Using MMCONFIG for extended config space [ 0.108689] ACPI: No dock devices found. [ 0.108696] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.108765] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.108878] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] [ 0.108881] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.108884] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.108886] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff] [ 0.108889] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xffffffff] [ 0.108921] PCI host bridge to bus 0000:00 [ 0.108923] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.108925] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.108928] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.108930] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff] [ 0.108932] pci_bus 0000:00: root bus resource [mem 0x80000000-0xffffffff] [ 0.108942] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000 [ 0.108982] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400 [ 0.109014] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.109056] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300 [ 0.109071] pci 0000:00:1b.0: reg 10: [mem 0xfe8fc000-0xfe8fffff 64bit] [ 0.109123] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.109144] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400 [ 0.109196] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.109218] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400 [ 0.109270] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.109295] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300 [ 0.109333] pci 0000:00:1d.0: reg 20: [io 0xb480-0xb49f] [ 0.109360] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300 [ 0.109398] pci 0000:00:1d.1: reg 20: [io 0xb800-0xb81f] [ 0.109426] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300 [ 0.109463] pci 0000:00:1d.2: reg 20: [io 0xb880-0xb89f] [ 0.109490] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300 [ 0.109528] pci 0000:00:1d.3: reg 20: [io 0xbc00-0xbc1f] [ 0.109564] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320 [ 0.109582] pci 0000:00:1d.7: reg 10: [mem 0xfe8fbc00-0xfe8fbfff] [ 0.109647] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.109666] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 [ 0.109720] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100 [ 0.109798] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003) [ 0.109829] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a [ 0.109842] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007] [ 0.109850] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003] [ 0.109859] pci 0000:00:1f.1: reg 18: [io 0x08f0-0x08f7] [ 0.109868] pci 0000:00:1f.1: reg 1c: [io 0x08f8-0x08fb] [ 0.109877] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf] [ 0.109909] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f [ 0.109922] pci 0000:00:1f.2: reg 10: [io 0xb400-0xb407] [ 0.109929] pci 0000:00:1f.2: reg 14: [io 0xb080-0xb083] [ 0.109937] pci 0000:00:1f.2: reg 18: [io 0xb000-0xb007] [ 0.109945] pci 0000:00:1f.2: reg 1c: [io 0xac00-0xac03] [ 0.109953] pci 0000:00:1f.2: reg 20: [io 0xa880-0xa88f] [ 0.109979] pci 0000:00:1f.2: PME# supported from D3hot [ 0.109993] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500 [ 0.110041] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f] [ 0.110108] pci 0000:01:00.0: [1002:94c3] type 00 class 0x030000 [ 0.110122] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.110133] pci 0000:01:00.0: reg 18: [mem 0xfe9e0000-0xfe9effff 64bit] [ 0.110141] pci 0000:01:00.0: reg 20: [io 0xc000-0xc0ff] [ 0.110154] pci 0000:01:00.0: reg 30: [mem 0xfe9c0000-0xfe9dffff pref] [ 0.110173] pci 0000:01:00.0: supports D1 D2 [ 0.110192] pci 0000:01:00.1: [1002:aa10] type 00 class 0x040300 [ 0.110205] pci 0000:01:00.1: reg 10: [mem 0xfe9fc000-0xfe9fffff 64bit] [ 0.110251] pci 0000:01:00.1: supports D1 D2 [ 0.110281] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.110284] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.110287] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff] [ 0.110291] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.110328] pci 0000:00:1c.0: PCI bridge to [bus 03-03] [ 0.110390] pci 0000:02:00.0: [1969:1026] type 00 class 0x020000 [ 0.110413] pci 0000:02:00.0: reg 10: [mem 0xfeac0000-0xfeafffff 64bit] [ 0.110425] pci 0000:02:00.0: reg 18: [io 0xdc00-0xdc7f] [ 0.110499] pci 0000:02:00.0: PME# supported from D3hot D3cold [ 0.110522] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.110531] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.110534] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.110538] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff] [ 0.110572] pci 0000:04:01.0: [10ec:8169] type 00 class 0x020000 [ 0.110589] pci 0000:04:01.0: reg 10: [io 0xe800-0xe8ff] [ 0.110599] pci 0000:04:01.0: reg 14: [mem 0xfebffc00-0xfebffcff] [ 0.110639] pci 0000:04:01.0: reg 30: [mem 0xfebc0000-0xfebdffff pref] [ 0.110657] pci 0000:04:01.0: supports D1 D2 [ 0.110659] pci 0000:04:01.0: PME# supported from D1 D2 D3hot D3cold [ 0.110703] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode) [ 0.110707] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff] [ 0.110711] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.110717] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.110719] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.110722] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.110724] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.110727] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xffffffff] (subtractive decode) [ 0.110742] pci_bus 0000:00: on NUMA node 0 [ 0.110747] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.110904] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.110997] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.111044] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT] [ 0.111099] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.117806] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *11 12 14 15) [ 0.117860] ACPI: PCI Interrupt Link [LNKB] (IRQs *10) [ 0.117908] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 11 12 14 15) [ 0.117960] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *11 12 14 15) [ 0.118012] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118066] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118119] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118173] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 11 12 14 15) [ 0.118223] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.118223] vgaarb: loaded [ 0.118223] vgaarb: bridge control possible 0000:01:00.0 [ 0.118223] PCI: Using ACPI for IRQ routing [ 0.118223] PCI: pci_cache_line_size set to 64 bytes [ 0.118223] reserve RAM buffer: 000000000009fc00 - 000000000009ffff [ 0.118223] reserve RAM buffer: 000000007ff90000 - 000000007fffffff [ 0.118223] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 [ 0.118223] hpet0: 3 comparators, 64-bit 14.318180 MHz counter [ 0.120022] Switching to clocksource hpet [ 0.120070] pnp: PnP ACPI init [ 0.120080] ACPI: bus type pnp registered [ 0.120150] pnp 00:00: [bus 00-ff] [ 0.120153] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.120156] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.120158] pnp 00:00: [io 0x0d00-0xffff window] [ 0.120160] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.120163] pnp 00:00: [mem 0x000d0000-0x000dffff window] [ 0.120165] pnp 00:00: [mem 0x80000000-0xffffffff window] [ 0.120205] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.120216] pnp 00:01: [mem 0xfed14000-0xfed19fff] [ 0.120254] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.120257] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.120291] pnp 00:02: [dma 4] [ 0.120293] pnp 00:02: [io 0x0000-0x000f] [ 0.120295] pnp 00:02: [io 0x0081-0x0083] [ 0.120297] pnp 00:02: [io 0x0087] [ 0.120299] pnp 00:02: [io 0x0089-0x008b] [ 0.120301] pnp 00:02: [io 0x008f] [ 0.120303] pnp 00:02: [io 0x00c0-0x00df] [ 0.120326] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.120341] pnp 00:03: [io 0x0070-0x0071] [ 0.120349] pnp 00:03: [irq 8] [ 0.120372] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.120382] pnp 00:04: [io 0x0061] [ 0.120406] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.120416] pnp 00:05: [io 0x00f0-0x00ff] [ 0.120421] pnp 00:05: [irq 13] [ 0.120445] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.120806] pnp 00:06: [irq 6] [ 0.120808] pnp 00:06: [dma 2] [ 0.120811] pnp 00:06: [io 0x03f0-0x03f5] [ 0.120813] pnp 00:06: [io 0x03f7] [ 0.120861] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.121321] pnp 00:07: [irq 7] [ 0.121324] pnp 00:07: [dma 3] [ 0.121326] pnp 00:07: [io 0x0378-0x037f] [ 0.121328] pnp 00:07: [io 0x0778-0x077f] [ 0.121491] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.121524] pnp 00:08: [io 0x0000-0xffffffff disabled] [ 0.121527] pnp 00:08: [io 0x0000-0xffffffff disabled] [ 0.121529] pnp 00:08: [io 0x0290-0x0297] [ 0.121570] system 00:08: [io 0x0290-0x0297] has been reserved [ 0.121573] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.121657] pnp 00:09: [io 0x0010-0x001f] [ 0.121659] pnp 00:09: [io 0x0022-0x003f] [ 0.121661] pnp 00:09: [io 0x0044-0x005f] [ 0.121663] pnp 00:09: [io 0x0062-0x0063] [ 0.121665] pnp 00:09: [io 0x0065-0x006f] [ 0.121667] pnp 00:09: [io 0x0072-0x007f] [ 0.121669] pnp 00:09: [io 0x0080] [ 0.121671] pnp 00:09: [io 0x0084-0x0086] [ 0.121673] pnp 00:09: [io 0x0088] [ 0.121675] pnp 00:09: [io 0x008c-0x008e] [ 0.121677] pnp 00:09: [io 0x0090-0x009f] [ 0.121679] pnp 00:09: [io 0x00a2-0x00bf] [ 0.121681] pnp 00:09: [io 0x00e0-0x00ef] [ 0.121683] pnp 00:09: [io 0x04d0-0x04d1] [ 0.121685] pnp 00:09: [io 0x0800-0x087f] [ 0.121687] pnp 00:09: [io 0x0000-0xffffffff disabled] [ 0.121691] pnp 00:09: [io 0x0480-0x04bf] [ 0.121693] pnp 00:09: [mem 0xfed1c000-0xfed1ffff] [ 0.121695] pnp 00:09: [mem 0xfed20000-0xfed8ffff] [ 0.121748] system 00:09: [io 0x04d0-0x04d1] has been reserved [ 0.121750] system 00:09: [io 0x0800-0x087f] has been reserved [ 0.121753] system 00:09: [io 0x0480-0x04bf] has been reserved [ 0.121756] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.121759] system 00:09: [mem 0xfed20000-0xfed8ffff] has been reserved [ 0.121762] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.121836] pnp 00:0a: [mem 0xfed00000-0xfed003ff] [ 0.121864] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.121921] pnp 00:0b: [mem 0xffb00000-0xffbfffff] [ 0.121923] pnp 00:0b: [mem 0xfff00000-0xffffffff] [ 0.121950] pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active) [ 0.121996] pnp 00:0c: [mem 0xffc00000-0xffefffff] [ 0.122038] system 00:0c: [mem 0xffc00000-0xffefffff] has been reserved [ 0.122041] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122092] pnp 00:0d: [mem 0xfec00000-0xfec00fff] [ 0.122095] pnp 00:0d: [mem 0xfee00000-0xfee00fff] [ 0.122138] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.122141] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.122144] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122175] pnp 00:0e: [io 0x0060] [ 0.122177] pnp 00:0e: [io 0x0064] [ 0.122182] pnp 00:0e: [irq 1] [ 0.122214] pnp 00:0e: Plug and Play ACPI device, IDs PNP0303 PNP030b (active) [ 0.122264] pnp 00:0f: [irq 12] [ 0.122299] pnp 00:0f: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active) [ 0.122615] pnp 00:10: [irq 4] [ 0.122617] pnp 00:10: [dma 0 disabled] [ 0.122620] pnp 00:10: [io 0x03f8-0x03ff] [ 0.122686] pnp 00:10: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.122722] pnp 00:11: [mem 0xf0000000-0xf3ffffff] [ 0.122766] system 00:11: [mem 0xf0000000-0xf3ffffff] has been reserved [ 0.122769] system 00:11: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122958] pnp 00:12: [mem 0x00000000-0x0009ffff] [ 0.122961] pnp 00:12: [mem 0x000c0000-0x000cffff] [ 0.122963] pnp 00:12: [mem 0x000e0000-0x000fffff] [ 0.122965] pnp 00:12: [mem 0x00100000-0x7fffffff] [ 0.122968] pnp 00:12: [mem 0x00000000-0xffffffff disabled] [ 0.123022] system 00:12: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.123025] system 00:12: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.123028] system 00:12: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.123031] system 00:12: [mem 0x00100000-0x7fffffff] could not be reserved [ 0.123034] system 00:12: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.123181] pnp: PnP ACPI: found 19 devices [ 0.123183] ACPI: ACPI bus type pnp unregistered [ 0.123186] PnPBIOS: Disabled by ACPI PNP [ 0.159777] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000 [ 0.159781] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000 [ 0.159785] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000 [ 0.159794] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000 [ 0.159806] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.159808] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.159811] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.159814] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.159818] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff] [ 0.159821] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref] [ 0.159824] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref] [ 0.159827] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.159831] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.159834] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.159838] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff] [ 0.159841] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.159845] pci 0000:00:1c.0: PCI bridge to [bus 03-03] [ 0.159848] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff] [ 0.159853] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff] [ 0.159857] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref] [ 0.159862] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.159865] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.159870] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff] [ 0.159874] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref] [ 0.159879] pci 0000:00:1e.0: PCI bridge to [bus 04-04] [ 0.159882] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff] [ 0.159887] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.159905] pci 0000:00:1c.0: enabling device (0104 -> 0107) [ 0.159923] pci 0000:00:1e.0: setting latency timer to 64 [ 0.159927] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.159929] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.159931] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.159934] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.159936] pci_bus 0000:00: resource 8 [mem 0x80000000-0xffffffff] [ 0.159938] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff] [ 0.159940] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfe9fffff] [ 0.159943] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref] [ 0.159945] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff] [ 0.159947] pci_bus 0000:03: resource 1 [mem 0x80000000-0x801fffff] [ 0.159950] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref] [ 0.159952] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff] [ 0.159954] pci_bus 0000:02: resource 1 [mem 0xfea00000-0xfeafffff] [ 0.159957] pci_bus 0000:02: resource 2 [mem 0x80400000-0x805fffff 64bit pref] [ 0.159959] pci_bus 0000:04: resource 0 [io 0xe000-0xefff] [ 0.159961] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff] [ 0.159964] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7] [ 0.159966] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff] [ 0.159968] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff] [ 0.159970] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff] [ 0.159973] pci_bus 0000:04: resource 8 [mem 0x80000000-0xffffffff] [ 0.160044] NET: Registered protocol family 2 [ 0.160101] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.160255] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.160541] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.160679] TCP: Hash tables configured (established 131072 bind 65536) [ 0.160681] TCP: reno registered [ 0.160684] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.160690] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.160758] NET: Registered protocol family 1 [ 0.160899] pci 0000:01:00.0: Boot video device [ 0.160909] PCI: CLS 32 bytes, default 64 [ 0.160947] Unpacking initramfs... [ 0.410589] Freeing initrd memory: 13708k freed [ 0.415901] audit: initializing netlink socket (disabled) [ 0.415922] type=2000 audit(1496944844.412:1): initialized [ 0.426186] highmem bounce pool size: 64 pages [ 0.426191] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.426356] VFS: Disk quotas dquot_6.5.2 [ 0.426381] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.426451] msgmni has been set to 1721 [ 0.426602] alg: No test for stdrng (krng) [ 0.426625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.426629] io scheduler noop registered [ 0.426630] io scheduler deadline registered [ 0.426648] io scheduler cfq registered (default) [ 0.426861] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.426878] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.426880] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.427222] GHES: HEST is not enabled! [ 0.427233] isapnp: Scanning for PnP cards... [ 0.780005] isapnp: No Plug & Play device found [ 0.780053] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.800370] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.821011] 00:10: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.821207] Linux agpgart interface v0.103 [ 0.821472] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12 [ 0.824182] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.824211] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.824305] mousedev: PS/2 mouse device common for all mice [ 0.824352] rtc_cmos 00:03: RTC can wake from S4 [ 0.824458] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 0.824481] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 0.824593] TCP: cubic registered [ 0.824640] NET: Registered protocol family 10 [ 0.824842] Mobile IPv6 [ 0.824845] NET: Registered protocol family 17 [ 0.824849] Registering the dns_resolver key type [ 0.824895] Using IPI No-Shortcut mode [ 0.824986] PM: Hibernation image not present or could not be loaded. [ 0.824995] registered taskstats version 1 [ 0.825291] rtc_cmos 00:03: setting system clock to 2017-06-08 18:00:45 UTC (1496944845) [ 0.825389] Freeing unused kernel memory: 416k freed [ 0.825563] Write protecting the kernel text: 3496k [ 0.825583] Write protecting the kernel read-only data: 984k [ 0.835285] udevd[49]: starting version 175 [ 0.848962] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 0.862823] SCSI subsystem initialized [ 0.867239] usbcore: registered new interface driver usbfs [ 0.867265] usbcore: registered new interface driver hub [ 0.869517] usbcore: registered new device driver usb [ 0.869869] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.869913] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 0.869917] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 0.869937] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 0.869954] ehci_hcd 0000:00:1d.7: using broken periodic workaround [ 0.869964] ehci_hcd 0000:00:1d.7: debug port 1 [ 0.873849] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 0.873872] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe8fbc00 [ 0.873906] libata version 3.00 loaded. [ 0.876314] uhci_hcd: USB Universal Host Controller Interface driver [ 0.879358] microcode: CPU0 sig=0x10676, pf=0x1, revision=0x60b [ 0.884019] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 0.884070] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.884072] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.884075] usb usb1: Product: EHCI Host Controller [ 0.884077] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 0.884079] usb usb1: SerialNumber: 0000:00:1d.7 [ 0.884189] hub 1-0:1.0: USB hub found [ 0.884194] hub 1-0:1.0: 8 ports detected [ 0.884415] ata_piix 0000:00:1f.1: version 2.13 [ 0.884464] ata_piix 0000:00:1f.1: setting latency timer to 64 [ 0.887374] scsi0 : ata_piix [ 0.890627] scsi1 : ata_piix [ 0.893012] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14 [ 0.893015] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15 [ 0.893187] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 0.893228] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 0.896540] scsi2 : ata_piix [ 0.900269] scsi3 : ata_piix [ 0.901963] ata3: SATA max UDMA/133 cmd 0xb400 ctl 0xb080 bmdma 0xa880 irq 19 [ 0.901966] ata4: SATA max UDMA/133 cmd 0xb000 ctl 0xac00 bmdma 0xa888 irq 19 [ 0.902084] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 0.902088] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 0.902100] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 0.902125] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b480 [ 0.902162] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902164] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902167] usb usb2: Product: UHCI Host Controller [ 0.902169] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902171] usb usb2: SerialNumber: 0000:00:1d.0 [ 0.902272] hub 2-0:1.0: USB hub found [ 0.902277] hub 2-0:1.0: 2 ports detected [ 0.902352] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 0.902355] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 0.902362] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 0.902383] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b800 [ 0.902414] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902417] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902419] usb usb3: Product: UHCI Host Controller [ 0.902421] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902423] usb usb3: SerialNumber: 0000:00:1d.1 [ 0.902514] hub 3-0:1.0: USB hub found [ 0.902518] hub 3-0:1.0: 2 ports detected [ 0.902585] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 0.902588] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 0.902595] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 0.902629] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b880 [ 0.902660] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902662] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902665] usb usb4: Product: UHCI Host Controller [ 0.902667] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902669] usb usb4: SerialNumber: 0000:00:1d.2 [ 0.902758] hub 4-0:1.0: USB hub found [ 0.902762] hub 4-0:1.0: 2 ports detected [ 0.902831] uhci_hcd 0000:00:1d.3: setting latency timer to 64 [ 0.902835] uhci_hcd 0000:00:1d.3: UHCI Host Controller [ 0.902842] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5 [ 0.902873] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000bc00 [ 0.902902] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902905] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902907] usb usb5: Product: UHCI Host Controller [ 0.902909] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902911] usb usb5: SerialNumber: 0000:00:1d.3 [ 0.903006] hub 5-0:1.0: USB hub found [ 0.903010] hub 5-0:1.0: 2 ports detected [ 0.905396] Floppy drive(s): fd0 is 1.44M [ 0.922406] microcode: CPU0 updated to revision 0x60f, date = 2010-09-29 [ 0.923629] microcode: CPU1 sig=0x10676, pf=0x1, revision=0x60b [ 0.927025] FDC 0 is a post-1991 82077 [ 0.930376] microcode: CPU1 updated to revision 0x60f, date = 2010-09-29 [ 0.932300] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.076128] ata3.00: ATA-8: Hitachi HTS542525K9SA00, BBFOC32P, max UDMA/100 [ 1.076132] ata3.00: 488397168 sectors, multi 16: LBA48 [ 1.092126] ata3.00: configured for UDMA/100 [ 1.092232] scsi 2:0:0:0: Direct-Access ATA Hitachi HTS54252 BBFO PQ: 0 ANSI: 5 [ 1.096940] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB) [ 1.096995] sd 2:0:0:0: [sda] Write Protect is off [ 1.096998] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.097019] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.144963] sda: sda1 sda2 < sda5 > [ 1.145277] sd 2:0:0:0: [sda] Attached SCSI disk [ 1.146742] sd 2:0:0:0: Attached scsi generic sg0 type 0 [ 1.380027] usb 3-2: new low-speed USB device number 2 using uhci_hcd [ 1.412018] Refined TSC clocksource calibration: 2666.151 MHz. [ 1.412025] Switching to clocksource tsc [ 1.555423] usb 3-2: New USB device found, idVendor=0458, idProduct=000e [ 1.555429] usb 3-2: New USB device strings: Mfr=2, Product=1, SerialNumber=0 [ 1.555433] usb 3-2: Product: Genius USB Wheel Mouse [ 1.555436] usb 3-2: Manufacturer: KYE [ 1.573815] input: KYE Genius USB Wheel Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input1 [ 1.573890] generic-usb 0003:0458:000E.0001: input,hidraw0: USB HID v1.00 Mouse [KYE Genius USB Wheel Mouse] on usb-0000:00:1d.1-2/input0 [ 1.573908] usbcore: registered new interface driver usbhid [ 1.573910] usbhid: USB HID core driver [ 6.917126] PM: Starting manual resume from disk [ 6.917130] PM: Hibernation image partition 8:5 present [ 6.917132] PM: Looking for hibernation image. [ 6.917324] PM: Image not found (code -22) [ 6.917327] PM: Hibernation image not present or could not be loaded. [ 6.969868] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 9.239765] udevd[344]: starting version 175 [ 9.836898] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2 [ 9.836904] ACPI: Power Button [PWRB] [ 9.836955] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 9.836958] ACPI: Power Button [PWRF] [ 10.358749] parport_pc 00:07: reported by Plug and Play ACPI [ 10.358848] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] [ 10.383976] [drm] Initialized drm 1.1.0 20060810 [ 10.395617] intel_rng: FWH not detected [ 10.413941] iTCO_vendor_support: vendor-support=0 [ 10.414620] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 10.414686] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860) [ 10.414916] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 10.421639] leds_ss4200: no LED devices found [ 10.498925] [drm] radeon kernel modesetting enabled. [ 10.499170] [drm] initializing kernel modesetting (RV610 0x1002:0x94C3 0x1462:0x1103). [ 10.499187] [drm] register mmio base: 0xFE9E0000 [ 10.499189] [drm] register mmio size: 65536 [ 10.499298] ATOM BIOS: 113 [ 10.499314] radeon 0000:01:00.0: VRAM: 256M 0x0000000000000000 - 0x000000000FFFFFFF (256M used) [ 10.499317] radeon 0000:01:00.0: GTT: 512M 0x0000000010000000 - 0x000000002FFFFFFF [ 10.500655] [drm] Detected VRAM RAM=256M, BAR=256M [ 10.500658] [drm] RAM width 64bits DDR [ 10.500711] [TTM] Zone kernel: Available graphics memory: 440902 kiB [ 10.500713] [TTM] Zone highmem: Available graphics memory: 1034602 kiB [ 10.500715] [TTM] Initializing pool allocator [ 10.500739] [drm] radeon: 256M of VRAM memory ready [ 10.500741] [drm] radeon: 512M of GTT memory ready. [ 10.500759] [drm] GART: num cpu pages 131072, num gpu pages 131072 [ 10.501064] [drm] radeon: ib pool ready. [ 10.501149] [drm] Loading RV610 Microcode [ 10.618571] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4 [ 10.618655] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5 [ 10.618721] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6 [ 10.618784] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7 [ 10.618849] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8 [ 10.618908] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9 [ 10.620280] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10 [ 10.620350] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11 [ 10.697753] udevd[396]: renamed network interface eth0 to eth1 [ 11.253379] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000). [ 11.253417] radeon 0000:01:00.0: WB enabled [ 11.253420] [drm] fence driver on ring 0 use gpu addr 0x10000c00 and cpu addr 0xff96bc00 [ 11.253424] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 11.253426] [drm] Driver supports precise vblank timestamp query. [ 11.253441] [drm] radeon: irq initialized. [ 11.284564] [drm] ring test on 0 succeeded in 1 usecs [ 11.284701] [drm] ib test on ring 0 succeeded in 0 usecs [ 11.284956] [drm] Radeon Display Connectors [ 11.284958] [drm] Connector 0: [ 11.284960] [drm] VGA [ 11.284962] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c [ 11.284964] [drm] Encoders: [ 11.284966] [drm] CRT2: INTERNAL_KLDSCP_DAC2 [ 11.284968] [drm] Connector 1: [ 11.284969] [drm] DIN [ 11.284970] [drm] Encoders: [ 11.284972] [drm] TV1: INTERNAL_KLDSCP_DAC2 [ 11.284973] [drm] Connector 2: [ 11.284975] [drm] DVI-I [ 11.284976] [drm] HPD1 [ 11.284978] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c [ 11.284980] [drm] Encoders: [ 11.284982] [drm] CRT1: INTERNAL_KLDSCP_DAC1 [ 11.284983] [drm] DFP1: INTERNAL_LVTM1 [ 11.284991] [drm] Internal thermal controller with fan control [ 11.285025] [drm] radeon: power management initialized [ 11.338509] [drm] fb mappable at 0xE0142000 [ 11.338511] [drm] vram apper at 0xE0000000 [ 11.338513] [drm] size 5242880 [ 11.338514] [drm] fb depth is 24 [ 11.338516] [drm] pitch is 5120 [ 11.338573] fbcon: radeondrmfb (fb0) is primary device [ 11.755864] Console: switching to colour frame buffer device 160x64 [ 11.759713] fb0: radeondrmfb frame buffer device [ 11.759715] drm: registered panic notifier [ 11.759721] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0 [ 11.817272] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12 [ 13.191706] Adding 2095100k swap on /dev/sda5. Priority:-1 extents:1 across:2095100k [ 13.202758] EXT4-fs (sda1): re-mounted. Opts: (null) [ 13.435471] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 13.570543] loop: module loaded [ 13.934297] EtherCAT: Master driver 1.5.2 2eff7c993a63 [ 13.934376] EtherCAT: 1 master waiting for devices. [ 14.011882] ec_r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 14.011917] ec_r8169 0000:04:01.0: (unregistered net_device): not PCI Express [ 14.011936] EtherCAT: Accepting 98:DE:D0:1B:AF:FC as main device for master 0. [ 14.011942] ec_r8169 0000:04:01.0: (unregistered net_device): RTL8169sb/8110sb at 0xf8038c00, 98:de:d0:1b:af:fc, XID 10000000 IRQ 16 [ 14.011945] ec_r8169 0000:04:01.0: (unregistered net_device): jumbo features [frames: 7152 bytes, tx checksumming: ok] [ 14.012968] EtherCAT 0: Starting EtherCAT-IDLE thread. [ 14.971351] RPC: Registered named UNIX socket transport module. [ 14.971354] RPC: Registered udp transport module. [ 14.971356] RPC: Registered tcp transport module. [ 14.971357] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 15.018127] FS-Cache: Loaded [ 15.059938] NFS: Registering the id_resolver key type [ 15.059957] FS-Cache: Netfs 'nfs' registered for caching [ 15.065072] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 16.008019] EtherCAT 0: Link state of ecm0 changed to UP. [ 16.012024] EtherCAT 0: 1 slave(s) responding on main device. [ 16.012029] EtherCAT 0: Slave states on main device: PREOP. [ 16.012063] EtherCAT 0: Scanning bus. [ 16.020008] EtherCAT WARNING 0: 1 datagram TIMED OUT! [ 16.460076] EtherCAT ERROR 0-0: Reception of CoE upload response failed: No response. [ 16.460124] EtherCAT ERROR 0-0: Failed to read number of mapped PDO entries. [ 16.460160] EtherCAT ERROR 0-0: Failed to read mapped PDO entries for PDO 0x1B01. [ 16.460197] EtherCAT 0: Bus scanning completed in 448 ms. [ 16.460200] EtherCAT 0: Using slave 0 as DC reference clock. [ 17.051376] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input13 [ 18.605498] Bluetooth: Core ver 2.16 [ 18.605512] NET: Registered protocol family 31 [ 18.605514] Bluetooth: HCI device and connection manager initialized [ 18.605516] Bluetooth: HCI socket layer initialized [ 18.605518] Bluetooth: L2CAP socket layer initialized [ 18.605522] Bluetooth: SCO socket layer initialized [ 18.673616] Bluetooth: RFCOMM TTY layer initialized [ 18.673621] Bluetooth: RFCOMM socket layer initialized [ 18.673623] Bluetooth: RFCOMM ver 1.11 [ 19.016320] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 19.016323] Bluetooth: BNEP filters: protocol multicast [ 19.562871] lp0: using parport0 (interrupt-driven). [ 19.715477] ppdev: user-space parallel port driver [ 21.273419] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 21.274685] ATL1E 0000:02:00.0: eth1: NIC Link is Up <100 Mbps Full Duplex> [ 21.274774] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 29.984467] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 66 [ 29.984472] Raw EDID: [ 29.984474] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 01 00 [ 29.984476] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 29.984478] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00 [ 29.984480] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 29.984482] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 61 [ 29.984483] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 29.984485] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 29.984487] 51 00 2a 40 30 70 13 00 21 1b 00 00 00 1e 00 73 [ 30.013057] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 136 [ 30.013059] Raw EDID: [ 30.013060] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00 [ 30.013062] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 30.013064] 11 50 54 af cf 00 31 40 45 40 61 40 81 c0 00 00 [ 30.013066] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 30.013068] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20 [ 30.013070] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 30.013071] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 30.013073] 51 00 2a 40 30 70 13 00 21 1b 08 00 00 1e 00 73 [ 30.041688] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 8 [ 30.041690] Raw EDID: [ 30.041692] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00 [ 30.041693] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 30.041695] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00 [ 30.041697] 00 00 08 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 30.041699] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20 [ 30.041701] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 30.041702] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 30.041704] 51 00 2a 40 30 70 13 00 21 1b 00 00 00 1e 00 73 [ 32.416008] eth1: no IPv6 routers present [ 74.710767] I-pipe: head domain RTAI registered. [ 74.710772] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 74.710800] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 74.710803] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16662258, CLK_FREQ 2665948000, CPU_FREQ 2665948000 [ 74.710806] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 74.710809] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16662258, 16662258, 8888750 [ 74.783038] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 74.783064] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 74.783068] RTAI[sched]: hard timer type/freq = APIC/16662258(Hz); default timing: oneshot; linear timed lists. [ 74.783071] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2665948000 hz. [ 74.783073] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 74.810814] RTAI[math]: loaded. [ 75.495466] RTAI[math]: unloaded. [ 75.496776] SCHED releases registered named ALIEN PEDV$D [ 75.500788] RTAI[malloc]: unloaded. [ 75.600012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 75.601481] I-pipe: head domain RTAI unregistered. [ 75.601516] RTAI[hal]: unmounted.
i think there is an error in the ethercat_config_n.xml file ?
Can someone check this or tell me how to creat it?
Tank you
Chris
9 years 4 months ago #94307 by ChrisB
OK
i found the mistake myself. The xml comments...
but now the next error:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.9 Machine configuration directory is '/home/cnc/linuxcnc/configs/Ethercat' Machine configuration file is 'Ethercat.ini' INIFILE=/home/cnc/linuxcnc/configs/Ethercat/Ethercat.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./Ethercat.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=4137 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Invalid parameters ./Ethercat.hal:2: exit value: 1 ./Ethercat.hal:2: insmod for lcec failed, returned -1 See the output of 'dmesg' for more information. 4137 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff90000 (usable) [ 0.000000] BIOS-e820: 000000007ff90000 - 000000007ff9e000 (ACPI data) [ 0.000000] BIOS-e820: 000000007ff9e000 - 000000007ffd0000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007ffd0000 - 000000007ffde000 (reserved) [ 0.000000] BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.5 present. [ 0.000000] DMI: System manufacturer System Product Name/P5KPL-CM, BIOS 0702 08/27/2010 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x7ff90 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-DFFFF write-protect [ 0.000000] E0000-EFFFF write-through [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 disabled [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00ff780] ff780 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 3652a000 - 3728d000 [ 0.000000] ACPI: RSDP 000fb6a0 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 7ff90000 0003C (v01 A_M_I_ OEMRSDT 08001027 MSFT 00000097) [ 0.000000] ACPI: FACP 7ff90200 00084 (v02 A_M_I_ OEMFACP 08001027 MSFT 00000097) [ 0.000000] ACPI: DSDT 7ff905c0 07BFA (v01 A0968 A0968000 00000000 INTL 20060113) [ 0.000000] ACPI: FACS 7ff9e000 00040 [ 0.000000] ACPI: APIC 7ff90390 0006C (v01 A_M_I_ OEMAPIC 08001027 MSFT 00000097) [ 0.000000] ACPI: MCFG 7ff90400 0003C (v01 A_M_I_ OEMMCFG 08001027 MSFT 00000097) [ 0.000000] ACPI: OEMB 7ff9e040 00080 (v01 A_M_I_ AMI_OEM 08001027 MSFT 00000097) [ 0.000000] ACPI: HPET 7ff981c0 00038 (v01 A_M_I_ OEMHPET 08001027 MSFT 00000097) [ 0.000000] ACPI: GSCI 7ff9e0c0 02024 (v01 A_M_I_ GMCHSCI 08001027 MSFT 00000097) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1159MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x0007ff90 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x0007ff90 [ 0.000000] On node 0 totalpages: 524063 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f552a200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2320 pages used for memmap [ 0.000000] HighMem zone: 294530 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ee00000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519967 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=52ffd0f1-7192-47ff-ae51-f8ee2d49581c ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 4193280 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:0007ff90) [ 0.000000] Memory: 2055080k/2096704k available (3495k kernel code, 41172k reserved, 1237k data, 416k init, 1187400k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:712 16 [ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2665.948 MHz processor. [ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5331.89 BogoMIPS (lpj=10663792) [ 0.004006] pid_max: default: 32768 minimum: 301 [ 0.004044] Security Framework initialized [ 0.004047] AppArmor: AppArmor disabled by boot time parameter [ 0.004063] Mount-cache hash table entries: 512 [ 0.004241] Initializing cgroup subsys cpuacct [ 0.004243] Initializing cgroup subsys memory [ 0.004250] Initializing cgroup subsys devices [ 0.004252] Initializing cgroup subsys freezer [ 0.004254] Initializing cgroup subsys net_cls [ 0.004256] Initializing cgroup subsys blkio [ 0.004261] Initializing cgroup subsys perf_event [ 0.004286] CPU: Physical Processor ID: 0 [ 0.004287] CPU: Processor Core ID: 0 [ 0.004289] mce: CPU supports 6 MCE banks [ 0.004295] CPU0: Thermal monitoring enabled (TM2) [ 0.004344] ACPI: Core revision 20120320 [ 0.012041] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.012393] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.054695] CPU0: Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz stepping 06 [ 0.056003] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver. [ 0.056003] ... version: 2 [ 0.056003] ... bit width: 40 [ 0.056003] ... generic registers: 2 [ 0.056003] ... value mask: 000000ffffffffff [ 0.056003] ... max period: 000000007fffffff [ 0.056003] ... fixed-purpose events: 3 [ 0.056003] ... event mask: 0000000700000003 [ 0.064075] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.076026] CPU 1 irqstacks, hard=f50d4000 soft=f50d6000 [ 0.076030] Booting Node 0, Processors #1 [ 0.008000] Initializing CPU#1 [ 0.088034] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.088073] Brought up 2 CPUs [ 0.088076] Total of 2 processors activated (10663.79 BogoMIPS). [ 0.089610] devtmpfs: initialized [ 0.089610] PM: Registering ACPI NVS region [mem 0x7ff9e000-0x7ffcffff] (204800 bytes) [ 0.089610] dummy: [ 0.089610] NET: Registered protocol family 16 [ 0.089610] ACPI: bus type pci registered [ 0.089610] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) [ 0.089610] PCI: not using MMCONFIG [ 0.089610] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4 [ 0.089610] PCI: Using configuration type 1 for base access [ 0.092074] bio: create slab <bio-0> at 0 [ 0.092099] ACPI: Added _OSI(Module Device) [ 0.092099] ACPI: Added _OSI(Processor Device) [ 0.092099] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.092099] ACPI: Added _OSI(Processor Aggregator Device) [ 0.093450] ACPI: EC: Look up EC in DSDT [ 0.095129] ACPI: Executed 1 blocks of module-level executable AML code [ 0.099455] ACPI: SSDT 7ffa00f0 00214 (v01 AMI CPU1PM 00000001 INTL 20060113) [ 0.099824] ACPI: Dynamic OEM Table Load: [ 0.099827] ACPI: SSDT (null) 00214 (v01 AMI CPU1PM 00000001 INTL 20060113) [ 0.100043] ACPI: SSDT 7ffa0310 00143 (v01 AMI CPU2PM 00000001 INTL 20060113) [ 0.100403] ACPI: Dynamic OEM Table Load: [ 0.100406] ACPI: SSDT (null) 00143 (v01 AMI CPU2PM 00000001 INTL 20060113) [ 0.100720] ACPI: Interpreter enabled [ 0.100733] ACPI: (supports S0 S1 S3 S4 S5) [ 0.100760] ACPI: Using IOAPIC for interrupt routing [ 0.100782] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) [ 0.102143] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in ACPI motherboard resources [ 0.102146] PCI: Using MMCONFIG for extended config space [ 0.108689] ACPI: No dock devices found. [ 0.108696] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.108765] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.108878] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] [ 0.108881] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.108884] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.108886] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff] [ 0.108889] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xffffffff] [ 0.108921] PCI host bridge to bus 0000:00 [ 0.108923] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.108925] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.108928] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.108930] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff] [ 0.108932] pci_bus 0000:00: root bus resource [mem 0x80000000-0xffffffff] [ 0.108942] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000 [ 0.108982] pci 0000:00:01.0: [8086:29c1] type 01 class 0x060400 [ 0.109014] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.109056] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300 [ 0.109071] pci 0000:00:1b.0: reg 10: [mem 0xfe8fc000-0xfe8fffff 64bit] [ 0.109123] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.109144] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400 [ 0.109196] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.109218] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400 [ 0.109270] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.109295] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300 [ 0.109333] pci 0000:00:1d.0: reg 20: [io 0xb480-0xb49f] [ 0.109360] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300 [ 0.109398] pci 0000:00:1d.1: reg 20: [io 0xb800-0xb81f] [ 0.109426] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300 [ 0.109463] pci 0000:00:1d.2: reg 20: [io 0xb880-0xb89f] [ 0.109490] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300 [ 0.109528] pci 0000:00:1d.3: reg 20: [io 0xbc00-0xbc1f] [ 0.109564] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320 [ 0.109582] pci 0000:00:1d.7: reg 10: [mem 0xfe8fbc00-0xfe8fbfff] [ 0.109647] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.109666] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 [ 0.109720] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100 [ 0.109798] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003) [ 0.109829] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a [ 0.109842] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007] [ 0.109850] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003] [ 0.109859] pci 0000:00:1f.1: reg 18: [io 0x08f0-0x08f7] [ 0.109868] pci 0000:00:1f.1: reg 1c: [io 0x08f8-0x08fb] [ 0.109877] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf] [ 0.109909] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f [ 0.109922] pci 0000:00:1f.2: reg 10: [io 0xb400-0xb407] [ 0.109929] pci 0000:00:1f.2: reg 14: [io 0xb080-0xb083] [ 0.109937] pci 0000:00:1f.2: reg 18: [io 0xb000-0xb007] [ 0.109945] pci 0000:00:1f.2: reg 1c: [io 0xac00-0xac03] [ 0.109953] pci 0000:00:1f.2: reg 20: [io 0xa880-0xa88f] [ 0.109979] pci 0000:00:1f.2: PME# supported from D3hot [ 0.109993] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500 [ 0.110041] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f] [ 0.110108] pci 0000:01:00.0: [1002:94c3] type 00 class 0x030000 [ 0.110122] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.110133] pci 0000:01:00.0: reg 18: [mem 0xfe9e0000-0xfe9effff 64bit] [ 0.110141] pci 0000:01:00.0: reg 20: [io 0xc000-0xc0ff] [ 0.110154] pci 0000:01:00.0: reg 30: [mem 0xfe9c0000-0xfe9dffff pref] [ 0.110173] pci 0000:01:00.0: supports D1 D2 [ 0.110192] pci 0000:01:00.1: [1002:aa10] type 00 class 0x040300 [ 0.110205] pci 0000:01:00.1: reg 10: [mem 0xfe9fc000-0xfe9fffff 64bit] [ 0.110251] pci 0000:01:00.1: supports D1 D2 [ 0.110281] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.110284] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.110287] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff] [ 0.110291] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.110328] pci 0000:00:1c.0: PCI bridge to [bus 03-03] [ 0.110390] pci 0000:02:00.0: [1969:1026] type 00 class 0x020000 [ 0.110413] pci 0000:02:00.0: reg 10: [mem 0xfeac0000-0xfeafffff 64bit] [ 0.110425] pci 0000:02:00.0: reg 18: [io 0xdc00-0xdc7f] [ 0.110499] pci 0000:02:00.0: PME# supported from D3hot D3cold [ 0.110522] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.110531] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.110534] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.110538] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff] [ 0.110572] pci 0000:04:01.0: [10ec:8169] type 00 class 0x020000 [ 0.110589] pci 0000:04:01.0: reg 10: [io 0xe800-0xe8ff] [ 0.110599] pci 0000:04:01.0: reg 14: [mem 0xfebffc00-0xfebffcff] [ 0.110639] pci 0000:04:01.0: reg 30: [mem 0xfebc0000-0xfebdffff pref] [ 0.110657] pci 0000:04:01.0: supports D1 D2 [ 0.110659] pci 0000:04:01.0: PME# supported from D1 D2 D3hot D3cold [ 0.110703] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode) [ 0.110707] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff] [ 0.110711] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.110717] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.110719] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.110722] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.110724] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.110727] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xffffffff] (subtractive decode) [ 0.110742] pci_bus 0000:00: on NUMA node 0 [ 0.110747] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.110904] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.110997] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.111044] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT] [ 0.111099] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.117806] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *11 12 14 15) [ 0.117860] ACPI: PCI Interrupt Link [LNKB] (IRQs *10) [ 0.117908] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 11 12 14 15) [ 0.117960] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *11 12 14 15) [ 0.118012] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118066] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118119] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.118173] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 11 12 14 15) [ 0.118223] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.118223] vgaarb: loaded [ 0.118223] vgaarb: bridge control possible 0000:01:00.0 [ 0.118223] PCI: Using ACPI for IRQ routing [ 0.118223] PCI: pci_cache_line_size set to 64 bytes [ 0.118223] reserve RAM buffer: 000000000009fc00 - 000000000009ffff [ 0.118223] reserve RAM buffer: 000000007ff90000 - 000000007fffffff [ 0.118223] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 [ 0.118223] hpet0: 3 comparators, 64-bit 14.318180 MHz counter [ 0.120022] Switching to clocksource hpet [ 0.120070] pnp: PnP ACPI init [ 0.120080] ACPI: bus type pnp registered [ 0.120150] pnp 00:00: [bus 00-ff] [ 0.120153] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.120156] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.120158] pnp 00:00: [io 0x0d00-0xffff window] [ 0.120160] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.120163] pnp 00:00: [mem 0x000d0000-0x000dffff window] [ 0.120165] pnp 00:00: [mem 0x80000000-0xffffffff window] [ 0.120205] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.120216] pnp 00:01: [mem 0xfed14000-0xfed19fff] [ 0.120254] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.120257] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.120291] pnp 00:02: [dma 4] [ 0.120293] pnp 00:02: [io 0x0000-0x000f] [ 0.120295] pnp 00:02: [io 0x0081-0x0083] [ 0.120297] pnp 00:02: [io 0x0087] [ 0.120299] pnp 00:02: [io 0x0089-0x008b] [ 0.120301] pnp 00:02: [io 0x008f] [ 0.120303] pnp 00:02: [io 0x00c0-0x00df] [ 0.120326] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.120341] pnp 00:03: [io 0x0070-0x0071] [ 0.120349] pnp 00:03: [irq 8] [ 0.120372] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.120382] pnp 00:04: [io 0x0061] [ 0.120406] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.120416] pnp 00:05: [io 0x00f0-0x00ff] [ 0.120421] pnp 00:05: [irq 13] [ 0.120445] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.120806] pnp 00:06: [irq 6] [ 0.120808] pnp 00:06: [dma 2] [ 0.120811] pnp 00:06: [io 0x03f0-0x03f5] [ 0.120813] pnp 00:06: [io 0x03f7] [ 0.120861] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.121321] pnp 00:07: [irq 7] [ 0.121324] pnp 00:07: [dma 3] [ 0.121326] pnp 00:07: [io 0x0378-0x037f] [ 0.121328] pnp 00:07: [io 0x0778-0x077f] [ 0.121491] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.121524] pnp 00:08: [io 0x0000-0xffffffff disabled] [ 0.121527] pnp 00:08: [io 0x0000-0xffffffff disabled] [ 0.121529] pnp 00:08: [io 0x0290-0x0297] [ 0.121570] system 00:08: [io 0x0290-0x0297] has been reserved [ 0.121573] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.121657] pnp 00:09: [io 0x0010-0x001f] [ 0.121659] pnp 00:09: [io 0x0022-0x003f] [ 0.121661] pnp 00:09: [io 0x0044-0x005f] [ 0.121663] pnp 00:09: [io 0x0062-0x0063] [ 0.121665] pnp 00:09: [io 0x0065-0x006f] [ 0.121667] pnp 00:09: [io 0x0072-0x007f] [ 0.121669] pnp 00:09: [io 0x0080] [ 0.121671] pnp 00:09: [io 0x0084-0x0086] [ 0.121673] pnp 00:09: [io 0x0088] [ 0.121675] pnp 00:09: [io 0x008c-0x008e] [ 0.121677] pnp 00:09: [io 0x0090-0x009f] [ 0.121679] pnp 00:09: [io 0x00a2-0x00bf] [ 0.121681] pnp 00:09: [io 0x00e0-0x00ef] [ 0.121683] pnp 00:09: [io 0x04d0-0x04d1] [ 0.121685] pnp 00:09: [io 0x0800-0x087f] [ 0.121687] pnp 00:09: [io 0x0000-0xffffffff disabled] [ 0.121691] pnp 00:09: [io 0x0480-0x04bf] [ 0.121693] pnp 00:09: [mem 0xfed1c000-0xfed1ffff] [ 0.121695] pnp 00:09: [mem 0xfed20000-0xfed8ffff] [ 0.121748] system 00:09: [io 0x04d0-0x04d1] has been reserved [ 0.121750] system 00:09: [io 0x0800-0x087f] has been reserved [ 0.121753] system 00:09: [io 0x0480-0x04bf] has been reserved [ 0.121756] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.121759] system 00:09: [mem 0xfed20000-0xfed8ffff] has been reserved [ 0.121762] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.121836] pnp 00:0a: [mem 0xfed00000-0xfed003ff] [ 0.121864] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.121921] pnp 00:0b: [mem 0xffb00000-0xffbfffff] [ 0.121923] pnp 00:0b: [mem 0xfff00000-0xffffffff] [ 0.121950] pnp 00:0b: Plug and Play ACPI device, IDs INT0800 (active) [ 0.121996] pnp 00:0c: [mem 0xffc00000-0xffefffff] [ 0.122038] system 00:0c: [mem 0xffc00000-0xffefffff] has been reserved [ 0.122041] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122092] pnp 00:0d: [mem 0xfec00000-0xfec00fff] [ 0.122095] pnp 00:0d: [mem 0xfee00000-0xfee00fff] [ 0.122138] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.122141] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.122144] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122175] pnp 00:0e: [io 0x0060] [ 0.122177] pnp 00:0e: [io 0x0064] [ 0.122182] pnp 00:0e: [irq 1] [ 0.122214] pnp 00:0e: Plug and Play ACPI device, IDs PNP0303 PNP030b (active) [ 0.122264] pnp 00:0f: [irq 12] [ 0.122299] pnp 00:0f: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active) [ 0.122615] pnp 00:10: [irq 4] [ 0.122617] pnp 00:10: [dma 0 disabled] [ 0.122620] pnp 00:10: [io 0x03f8-0x03ff] [ 0.122686] pnp 00:10: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.122722] pnp 00:11: [mem 0xf0000000-0xf3ffffff] [ 0.122766] system 00:11: [mem 0xf0000000-0xf3ffffff] has been reserved [ 0.122769] system 00:11: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.122958] pnp 00:12: [mem 0x00000000-0x0009ffff] [ 0.122961] pnp 00:12: [mem 0x000c0000-0x000cffff] [ 0.122963] pnp 00:12: [mem 0x000e0000-0x000fffff] [ 0.122965] pnp 00:12: [mem 0x00100000-0x7fffffff] [ 0.122968] pnp 00:12: [mem 0x00000000-0xffffffff disabled] [ 0.123022] system 00:12: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.123025] system 00:12: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.123028] system 00:12: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.123031] system 00:12: [mem 0x00100000-0x7fffffff] could not be reserved [ 0.123034] system 00:12: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.123181] pnp: PnP ACPI: found 19 devices [ 0.123183] ACPI: ACPI bus type pnp unregistered [ 0.123186] PnPBIOS: Disabled by ACPI PNP [ 0.159777] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000 [ 0.159781] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000 [ 0.159785] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000 [ 0.159794] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000 [ 0.159806] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.159808] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.159811] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.159814] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.159818] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff] [ 0.159821] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref] [ 0.159824] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref] [ 0.159827] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.159831] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.159834] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.159838] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff] [ 0.159841] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.159845] pci 0000:00:1c.0: PCI bridge to [bus 03-03] [ 0.159848] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff] [ 0.159853] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff] [ 0.159857] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref] [ 0.159862] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.159865] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.159870] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff] [ 0.159874] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref] [ 0.159879] pci 0000:00:1e.0: PCI bridge to [bus 04-04] [ 0.159882] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff] [ 0.159887] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.159905] pci 0000:00:1c.0: enabling device (0104 -> 0107) [ 0.159923] pci 0000:00:1e.0: setting latency timer to 64 [ 0.159927] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.159929] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.159931] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.159934] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.159936] pci_bus 0000:00: resource 8 [mem 0x80000000-0xffffffff] [ 0.159938] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff] [ 0.159940] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfe9fffff] [ 0.159943] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref] [ 0.159945] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff] [ 0.159947] pci_bus 0000:03: resource 1 [mem 0x80000000-0x801fffff] [ 0.159950] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref] [ 0.159952] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff] [ 0.159954] pci_bus 0000:02: resource 1 [mem 0xfea00000-0xfeafffff] [ 0.159957] pci_bus 0000:02: resource 2 [mem 0x80400000-0x805fffff 64bit pref] [ 0.159959] pci_bus 0000:04: resource 0 [io 0xe000-0xefff] [ 0.159961] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff] [ 0.159964] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7] [ 0.159966] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff] [ 0.159968] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff] [ 0.159970] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff] [ 0.159973] pci_bus 0000:04: resource 8 [mem 0x80000000-0xffffffff] [ 0.160044] NET: Registered protocol family 2 [ 0.160101] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.160255] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.160541] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.160679] TCP: Hash tables configured (established 131072 bind 65536) [ 0.160681] TCP: reno registered [ 0.160684] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.160690] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.160758] NET: Registered protocol family 1 [ 0.160899] pci 0000:01:00.0: Boot video device [ 0.160909] PCI: CLS 32 bytes, default 64 [ 0.160947] Unpacking initramfs... [ 0.410589] Freeing initrd memory: 13708k freed [ 0.415901] audit: initializing netlink socket (disabled) [ 0.415922] type=2000 audit(1496944844.412:1): initialized [ 0.426186] highmem bounce pool size: 64 pages [ 0.426191] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.426356] VFS: Disk quotas dquot_6.5.2 [ 0.426381] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.426451] msgmni has been set to 1721 [ 0.426602] alg: No test for stdrng (krng) [ 0.426625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.426629] io scheduler noop registered [ 0.426630] io scheduler deadline registered [ 0.426648] io scheduler cfq registered (default) [ 0.426861] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.426878] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.426880] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.427222] GHES: HEST is not enabled! [ 0.427233] isapnp: Scanning for PnP cards... [ 0.780005] isapnp: No Plug & Play device found [ 0.780053] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.800370] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.821011] 00:10: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.821207] Linux agpgart interface v0.103 [ 0.821472] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12 [ 0.824182] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.824211] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.824305] mousedev: PS/2 mouse device common for all mice [ 0.824352] rtc_cmos 00:03: RTC can wake from S4 [ 0.824458] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 0.824481] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 0.824593] TCP: cubic registered [ 0.824640] NET: Registered protocol family 10 [ 0.824842] Mobile IPv6 [ 0.824845] NET: Registered protocol family 17 [ 0.824849] Registering the dns_resolver key type [ 0.824895] Using IPI No-Shortcut mode [ 0.824986] PM: Hibernation image not present or could not be loaded. [ 0.824995] registered taskstats version 1 [ 0.825291] rtc_cmos 00:03: setting system clock to 2017-06-08 18:00:45 UTC (1496944845) [ 0.825389] Freeing unused kernel memory: 416k freed [ 0.825563] Write protecting the kernel text: 3496k [ 0.825583] Write protecting the kernel read-only data: 984k [ 0.835285] udevd[49]: starting version 175 [ 0.848962] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 0.862823] SCSI subsystem initialized [ 0.867239] usbcore: registered new interface driver usbfs [ 0.867265] usbcore: registered new interface driver hub [ 0.869517] usbcore: registered new device driver usb [ 0.869869] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.869913] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 0.869917] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 0.869937] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 0.869954] ehci_hcd 0000:00:1d.7: using broken periodic workaround [ 0.869964] ehci_hcd 0000:00:1d.7: debug port 1 [ 0.873849] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 0.873872] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe8fbc00 [ 0.873906] libata version 3.00 loaded. [ 0.876314] uhci_hcd: USB Universal Host Controller Interface driver [ 0.879358] microcode: CPU0 sig=0x10676, pf=0x1, revision=0x60b [ 0.884019] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 0.884070] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.884072] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.884075] usb usb1: Product: EHCI Host Controller [ 0.884077] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 0.884079] usb usb1: SerialNumber: 0000:00:1d.7 [ 0.884189] hub 1-0:1.0: USB hub found [ 0.884194] hub 1-0:1.0: 8 ports detected [ 0.884415] ata_piix 0000:00:1f.1: version 2.13 [ 0.884464] ata_piix 0000:00:1f.1: setting latency timer to 64 [ 0.887374] scsi0 : ata_piix [ 0.890627] scsi1 : ata_piix [ 0.893012] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14 [ 0.893015] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15 [ 0.893187] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 0.893228] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 0.896540] scsi2 : ata_piix [ 0.900269] scsi3 : ata_piix [ 0.901963] ata3: SATA max UDMA/133 cmd 0xb400 ctl 0xb080 bmdma 0xa880 irq 19 [ 0.901966] ata4: SATA max UDMA/133 cmd 0xb000 ctl 0xac00 bmdma 0xa888 irq 19 [ 0.902084] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 0.902088] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 0.902100] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 0.902125] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b480 [ 0.902162] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902164] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902167] usb usb2: Product: UHCI Host Controller [ 0.902169] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902171] usb usb2: SerialNumber: 0000:00:1d.0 [ 0.902272] hub 2-0:1.0: USB hub found [ 0.902277] hub 2-0:1.0: 2 ports detected [ 0.902352] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 0.902355] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 0.902362] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 0.902383] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b800 [ 0.902414] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902417] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902419] usb usb3: Product: UHCI Host Controller [ 0.902421] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902423] usb usb3: SerialNumber: 0000:00:1d.1 [ 0.902514] hub 3-0:1.0: USB hub found [ 0.902518] hub 3-0:1.0: 2 ports detected [ 0.902585] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 0.902588] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 0.902595] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 0.902629] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b880 [ 0.902660] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902662] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902665] usb usb4: Product: UHCI Host Controller [ 0.902667] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902669] usb usb4: SerialNumber: 0000:00:1d.2 [ 0.902758] hub 4-0:1.0: USB hub found [ 0.902762] hub 4-0:1.0: 2 ports detected [ 0.902831] uhci_hcd 0000:00:1d.3: setting latency timer to 64 [ 0.902835] uhci_hcd 0000:00:1d.3: UHCI Host Controller [ 0.902842] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5 [ 0.902873] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000bc00 [ 0.902902] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.902905] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.902907] usb usb5: Product: UHCI Host Controller [ 0.902909] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd [ 0.902911] usb usb5: SerialNumber: 0000:00:1d.3 [ 0.903006] hub 5-0:1.0: USB hub found [ 0.903010] hub 5-0:1.0: 2 ports detected [ 0.905396] Floppy drive(s): fd0 is 1.44M [ 0.922406] microcode: CPU0 updated to revision 0x60f, date = 2010-09-29 [ 0.923629] microcode: CPU1 sig=0x10676, pf=0x1, revision=0x60b [ 0.927025] FDC 0 is a post-1991 82077 [ 0.930376] microcode: CPU1 updated to revision 0x60f, date = 2010-09-29 [ 0.932300] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.076128] ata3.00: ATA-8: Hitachi HTS542525K9SA00, BBFOC32P, max UDMA/100 [ 1.076132] ata3.00: 488397168 sectors, multi 16: LBA48 [ 1.092126] ata3.00: configured for UDMA/100 [ 1.092232] scsi 2:0:0:0: Direct-Access ATA Hitachi HTS54252 BBFO PQ: 0 ANSI: 5 [ 1.096940] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB) [ 1.096995] sd 2:0:0:0: [sda] Write Protect is off [ 1.096998] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.097019] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.144963] sda: sda1 sda2 < sda5 > [ 1.145277] sd 2:0:0:0: [sda] Attached SCSI disk [ 1.146742] sd 2:0:0:0: Attached scsi generic sg0 type 0 [ 1.380027] usb 3-2: new low-speed USB device number 2 using uhci_hcd [ 1.412018] Refined TSC clocksource calibration: 2666.151 MHz. [ 1.412025] Switching to clocksource tsc [ 1.555423] usb 3-2: New USB device found, idVendor=0458, idProduct=000e [ 1.555429] usb 3-2: New USB device strings: Mfr=2, Product=1, SerialNumber=0 [ 1.555433] usb 3-2: Product: Genius USB Wheel Mouse [ 1.555436] usb 3-2: Manufacturer: KYE [ 1.573815] input: KYE Genius USB Wheel Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input1 [ 1.573890] generic-usb 0003:0458:000E.0001: input,hidraw0: USB HID v1.00 Mouse [KYE Genius USB Wheel Mouse] on usb-0000:00:1d.1-2/input0 [ 1.573908] usbcore: registered new interface driver usbhid [ 1.573910] usbhid: USB HID core driver [ 6.917126] PM: Starting manual resume from disk [ 6.917130] PM: Hibernation image partition 8:5 present [ 6.917132] PM: Looking for hibernation image. [ 6.917324] PM: Image not found (code -22) [ 6.917327] PM: Hibernation image not present or could not be loaded. [ 6.969868] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 9.239765] udevd[344]: starting version 175 [ 9.836898] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2 [ 9.836904] ACPI: Power Button [PWRB] [ 9.836955] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 9.836958] ACPI: Power Button [PWRF] [ 10.358749] parport_pc 00:07: reported by Plug and Play ACPI [ 10.358848] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] [ 10.383976] [drm] Initialized drm 1.1.0 20060810 [ 10.395617] intel_rng: FWH not detected [ 10.413941] iTCO_vendor_support: vendor-support=0 [ 10.414620] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 10.414686] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860) [ 10.414916] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 10.421639] leds_ss4200: no LED devices found [ 10.498925] [drm] radeon kernel modesetting enabled. [ 10.499170] [drm] initializing kernel modesetting (RV610 0x1002:0x94C3 0x1462:0x1103). [ 10.499187] [drm] register mmio base: 0xFE9E0000 [ 10.499189] [drm] register mmio size: 65536 [ 10.499298] ATOM BIOS: 113 [ 10.499314] radeon 0000:01:00.0: VRAM: 256M 0x0000000000000000 - 0x000000000FFFFFFF (256M used) [ 10.499317] radeon 0000:01:00.0: GTT: 512M 0x0000000010000000 - 0x000000002FFFFFFF [ 10.500655] [drm] Detected VRAM RAM=256M, BAR=256M [ 10.500658] [drm] RAM width 64bits DDR [ 10.500711] [TTM] Zone kernel: Available graphics memory: 440902 kiB [ 10.500713] [TTM] Zone highmem: Available graphics memory: 1034602 kiB [ 10.500715] [TTM] Initializing pool allocator [ 10.500739] [drm] radeon: 256M of VRAM memory ready [ 10.500741] [drm] radeon: 512M of GTT memory ready. [ 10.500759] [drm] GART: num cpu pages 131072, num gpu pages 131072 [ 10.501064] [drm] radeon: ib pool ready. [ 10.501149] [drm] Loading RV610 Microcode [ 10.618571] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4 [ 10.618655] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5 [ 10.618721] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6 [ 10.618784] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7 [ 10.618849] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8 [ 10.618908] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9 [ 10.620280] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10 [ 10.620350] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11 [ 10.697753] udevd[396]: renamed network interface eth0 to eth1 [ 11.253379] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000). [ 11.253417] radeon 0000:01:00.0: WB enabled [ 11.253420] [drm] fence driver on ring 0 use gpu addr 0x10000c00 and cpu addr 0xff96bc00 [ 11.253424] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 11.253426] [drm] Driver supports precise vblank timestamp query. [ 11.253441] [drm] radeon: irq initialized. [ 11.284564] [drm] ring test on 0 succeeded in 1 usecs [ 11.284701] [drm] ib test on ring 0 succeeded in 0 usecs [ 11.284956] [drm] Radeon Display Connectors [ 11.284958] [drm] Connector 0: [ 11.284960] [drm] VGA [ 11.284962] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c [ 11.284964] [drm] Encoders: [ 11.284966] [drm] CRT2: INTERNAL_KLDSCP_DAC2 [ 11.284968] [drm] Connector 1: [ 11.284969] [drm] DIN [ 11.284970] [drm] Encoders: [ 11.284972] [drm] TV1: INTERNAL_KLDSCP_DAC2 [ 11.284973] [drm] Connector 2: [ 11.284975] [drm] DVI-I [ 11.284976] [drm] HPD1 [ 11.284978] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c [ 11.284980] [drm] Encoders: [ 11.284982] [drm] CRT1: INTERNAL_KLDSCP_DAC1 [ 11.284983] [drm] DFP1: INTERNAL_LVTM1 [ 11.284991] [drm] Internal thermal controller with fan control [ 11.285025] [drm] radeon: power management initialized [ 11.338509] [drm] fb mappable at 0xE0142000 [ 11.338511] [drm] vram apper at 0xE0000000 [ 11.338513] [drm] size 5242880 [ 11.338514] [drm] fb depth is 24 [ 11.338516] [drm] pitch is 5120 [ 11.338573] fbcon: radeondrmfb (fb0) is primary device [ 11.755864] Console: switching to colour frame buffer device 160x64 [ 11.759713] fb0: radeondrmfb frame buffer device [ 11.759715] drm: registered panic notifier [ 11.759721] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0 [ 11.817272] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12 [ 13.191706] Adding 2095100k swap on /dev/sda5. Priority:-1 extents:1 across:2095100k [ 13.202758] EXT4-fs (sda1): re-mounted. Opts: (null) [ 13.435471] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 13.570543] loop: module loaded [ 13.934297] EtherCAT: Master driver 1.5.2 2eff7c993a63 [ 13.934376] EtherCAT: 1 master waiting for devices. [ 14.011882] ec_r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 14.011917] ec_r8169 0000:04:01.0: (unregistered net_device): not PCI Express [ 14.011936] EtherCAT: Accepting 98:DE:D0:1B:AF:FC as main device for master 0. [ 14.011942] ec_r8169 0000:04:01.0: (unregistered net_device): RTL8169sb/8110sb at 0xf8038c00, 98:de:d0:1b:af:fc, XID 10000000 IRQ 16 [ 14.011945] ec_r8169 0000:04:01.0: (unregistered net_device): jumbo features [frames: 7152 bytes, tx checksumming: ok] [ 14.012968] EtherCAT 0: Starting EtherCAT-IDLE thread. [ 14.971351] RPC: Registered named UNIX socket transport module. [ 14.971354] RPC: Registered udp transport module. [ 14.971356] RPC: Registered tcp transport module. [ 14.971357] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 15.018127] FS-Cache: Loaded [ 15.059938] NFS: Registering the id_resolver key type [ 15.059957] FS-Cache: Netfs 'nfs' registered for caching [ 15.065072] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 16.008019] EtherCAT 0: Link state of ecm0 changed to UP. [ 16.012024] EtherCAT 0: 1 slave(s) responding on main device. [ 16.012029] EtherCAT 0: Slave states on main device: PREOP. [ 16.012063] EtherCAT 0: Scanning bus. [ 16.020008] EtherCAT WARNING 0: 1 datagram TIMED OUT! [ 16.460076] EtherCAT ERROR 0-0: Reception of CoE upload response failed: No response. [ 16.460124] EtherCAT ERROR 0-0: Failed to read number of mapped PDO entries. [ 16.460160] EtherCAT ERROR 0-0: Failed to read mapped PDO entries for PDO 0x1B01. [ 16.460197] EtherCAT 0: Bus scanning completed in 448 ms. [ 16.460200] EtherCAT 0: Using slave 0 as DC reference clock. [ 17.051376] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input13 [ 18.605498] Bluetooth: Core ver 2.16 [ 18.605512] NET: Registered protocol family 31 [ 18.605514] Bluetooth: HCI device and connection manager initialized [ 18.605516] Bluetooth: HCI socket layer initialized [ 18.605518] Bluetooth: L2CAP socket layer initialized [ 18.605522] Bluetooth: SCO socket layer initialized [ 18.673616] Bluetooth: RFCOMM TTY layer initialized [ 18.673621] Bluetooth: RFCOMM socket layer initialized [ 18.673623] Bluetooth: RFCOMM ver 1.11 [ 19.016320] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 19.016323] Bluetooth: BNEP filters: protocol multicast [ 19.562871] lp0: using parport0 (interrupt-driven). [ 19.715477] ppdev: user-space parallel port driver [ 21.273419] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 21.274685] ATL1E 0000:02:00.0: eth1: NIC Link is Up <100 Mbps Full Duplex> [ 21.274774] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 29.984467] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 66 [ 29.984472] Raw EDID: [ 29.984474] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 01 00 [ 29.984476] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 29.984478] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00 [ 29.984480] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 29.984482] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 61 [ 29.984483] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 29.984485] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 29.984487] 51 00 2a 40 30 70 13 00 21 1b 00 00 00 1e 00 73 [ 30.013057] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 136 [ 30.013059] Raw EDID: [ 30.013060] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00 [ 30.013062] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 30.013064] 11 50 54 af cf 00 31 40 45 40 61 40 81 c0 00 00 [ 30.013066] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 30.013068] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20 [ 30.013070] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 30.013071] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 30.013073] 51 00 2a 40 30 70 13 00 21 1b 08 00 00 1e 00 73 [ 30.041688] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 8 [ 30.041690] Raw EDID: [ 30.041692] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00 [ 30.041693] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27 [ 30.041695] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00 [ 30.041697] 00 00 08 00 00 00 d5 09 80 90 20 e0 1d 10 08 60 [ 30.041699] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20 [ 30.041701] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00 [ 30.041702] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98 [ 30.041704] 51 00 2a 40 30 70 13 00 21 1b 00 00 00 1e 00 73 [ 32.416008] eth1: no IPv6 routers present [ 74.710767] I-pipe: head domain RTAI registered. [ 74.710772] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 74.710800] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 74.710803] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16662258, CLK_FREQ 2665948000, CPU_FREQ 2665948000 [ 74.710806] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 74.710809] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16662258, 16662258, 8888750 [ 74.783038] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 74.783064] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 74.783068] RTAI[sched]: hard timer type/freq = APIC/16662258(Hz); default timing: oneshot; linear timed lists. [ 74.783071] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2665948000 hz. [ 74.783073] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 74.810814] RTAI[math]: loaded. [ 75.495466] RTAI[math]: unloaded. [ 75.496776] SCHED releases registered named ALIEN PEDV$D [ 75.500788] RTAI[malloc]: unloaded. [ 75.600012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 75.601481] I-pipe: head domain RTAI unregistered. [ 75.601516] RTAI[hal]: unmounted. [ 780.865863] I-pipe: head domain RTAI registered. [ 780.865868] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 780.865896] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 780.865899] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16662258, CLK_FREQ 2665948000, CPU_FREQ 2665948000 [ 780.865902] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 780.865905] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16662258, 16662258, 16642750 [ 780.873514] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 780.873539] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 780.873543] RTAI[sched]: hard timer type/freq = APIC/16662258(Hz); default timing: oneshot; linear timed lists. [ 780.873546] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2665948000 hz. [ 780.873548] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 780.877795] RTAI[math]: loaded. [ 781.234262] RTAI[math]: unloaded. [ 781.235608] SCHED releases registered named ALIEN PEDV$D [ 781.237421] RTAI[malloc]: unloaded. [ 781.336017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 781.337641] I-pipe: head domain RTAI unregistered. [ 781.337673] RTAI[hal]: unmounted. [ 1176.137183] I-pipe: head domain RTAI registered. [ 1176.137188] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1176.137214] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1176.137217] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16662258, CLK_FREQ 2665948000, CPU_FREQ 2665948000 [ 1176.137220] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1176.137223] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16662258, 16662258, 16639500 [ 1176.144813] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1176.144839] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1176.144843] RTAI[sched]: hard timer type/freq = APIC/16662258(Hz); default timing: oneshot; linear timed lists. [ 1176.144846] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2665948000 hz. [ 1176.144848] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1176.149693] RTAI[math]: loaded. [ 1176.336188] lcec: disagrees about version of symbol hal_param_float_newf [ 1176.336195] lcec: Unknown symbol hal_param_float_newf (err -22) [ 1176.336201] lcec: disagrees about version of symbol hal_pin_u32_newf [ 1176.336210] lcec: Unknown symbol hal_pin_u32_newf (err -22) [ 1176.336228] lcec: disagrees about version of symbol ecrt_slave_config_sdo8 [ 1176.336230] lcec: Unknown symbol ecrt_slave_config_sdo8 (err -22) [ 1176.336243] lcec: disagrees about version of symbol ecrt_request_master [ 1176.336245] lcec: Unknown symbol ecrt_request_master (err -22) [ 1176.336248] lcec: disagrees about version of symbol hal_param_bit_newf [ 1176.336251] lcec: Unknown symbol hal_param_bit_newf (err -22) [ 1176.336257] lcec: disagrees about version of symbol ecrt_release_master [ 1176.336259] lcec: Unknown symbol ecrt_release_master (err -22) [ 1176.336265] lcec: disagrees about version of symbol ecrt_master_activate [ 1176.336267] lcec: Unknown symbol ecrt_master_activate (err -22) [ 1176.336270] lcec: disagrees about version of symbol hal_param_s32_newf [ 1176.336272] lcec: Unknown symbol hal_param_s32_newf (err -22) [ 1176.336288] lcec: disagrees about version of symbol hal_pin_s32_newf [ 1176.336290] lcec: Unknown symbol hal_pin_s32_newf (err -22) [ 1176.336296] lcec: disagrees about version of symbol ecrt_domain_size [ 1176.336298] lcec: Unknown symbol ecrt_domain_size (err -22) [ 1176.336305] lcec: disagrees about version of symbol ecrt_master_deactivate [ 1176.336307] lcec: Unknown symbol ecrt_master_deactivate (err -22) [ 1176.336315] lcec: disagrees about version of symbol ecrt_slave_config_create_sdo_request [ 1176.336317] lcec: Unknown symbol ecrt_slave_config_create_sdo_request (err -22) [ 1176.336322] lcec: disagrees about version of symbol hal_pin_bit_newf [ 1176.336324] lcec: Unknown symbol hal_pin_bit_newf (err -22) [ 1176.336331] lcec: disagrees about version of symbol ecrt_master_sync_reference_clock [ 1176.336333] lcec: Unknown symbol ecrt_master_sync_reference_clock (err -22) [ 1176.336340] lcec: disagrees about version of symbol ecrt_slave_config_pdos [ 1176.336342] lcec: Unknown symbol ecrt_slave_config_pdos (err -22) [ 1176.336347] lcec: disagrees about version of symbol ecrt_domain_data [ 1176.336349] lcec: Unknown symbol ecrt_domain_data (err -22) [ 1176.336359] lcec: disagrees about version of symbol ecrt_slave_config_dc [ 1176.336361] lcec: Unknown symbol ecrt_slave_config_dc (err -22) [ 1176.336367] lcec: disagrees about version of symbol ecrt_master_slave_config [ 1176.336369] lcec: Unknown symbol ecrt_master_slave_config (err -22) [ 1176.336377] lcec: disagrees about version of symbol ecrt_slave_config_state [ 1176.336379] lcec: Unknown symbol ecrt_slave_config_state (err -22) [ 1176.336385] lcec: disagrees about version of symbol ecrt_master_state [ 1176.336387] lcec: Unknown symbol ecrt_master_state (err -22) [ 1176.336394] lcec: disagrees about version of symbol ecrt_master_callbacks [ 1176.336396] lcec: Unknown symbol ecrt_master_callbacks (err -22) [ 1176.336401] lcec: disagrees about version of symbol ecrt_domain_process [ 1176.336403] lcec: Unknown symbol ecrt_domain_process (err -22) [ 1176.336411] lcec: disagrees about version of symbol ecrt_master_application_time [ 1176.336413] lcec: Unknown symbol ecrt_master_application_time (err -22) [ 1176.336419] lcec: disagrees about version of symbol ecrt_domain_reg_pdo_entry_list [ 1176.336421] lcec: Unknown symbol ecrt_domain_reg_pdo_entry_list (err -22) [ 1176.336427] lcec: disagrees about version of symbol ecrt_slave_config_watchdog [ 1176.336429] lcec: Unknown symbol ecrt_slave_config_watchdog (err -22) [ 1176.336435] lcec: disagrees about version of symbol ecrt_slave_config_complete_sdo [ 1176.336437] lcec: Unknown symbol ecrt_slave_config_complete_sdo (err -22) [ 1176.336443] lcec: disagrees about version of symbol ecrt_master_sync_slave_clocks [ 1176.336445] lcec: Unknown symbol ecrt_master_sync_slave_clocks (err -22) [ 1176.336448] lcec: disagrees about version of symbol hal_param_u32_newf [ 1176.336450] lcec: Unknown symbol hal_param_u32_newf (err -22) [ 1176.336458] lcec: disagrees about version of symbol ecrt_domain_queue [ 1176.336460] lcec: Unknown symbol ecrt_domain_queue (err -22) [ 1176.336469] lcec: disagrees about version of symbol ecrt_master_send [ 1176.336471] lcec: Unknown symbol ecrt_master_send (err -22) [ 1176.336476] lcec: disagrees about version of symbol ecrt_slave_config_sdo [ 1176.336478] lcec: Unknown symbol ecrt_slave_config_sdo (err -22) [ 1176.336483] lcec: disagrees about version of symbol ecrt_master_create_domain [ 1176.336485] lcec: Unknown symbol ecrt_master_create_domain (err -22) [ 1176.336492] lcec: disagrees about version of symbol ecrt_master_receive [ 1176.336494] lcec: Unknown symbol ecrt_master_receive (err -22) [ 1176.558804] RTAI[math]: unloaded. [ 1176.560162] SCHED releases registered named ALIEN PEDV$D [ 1176.564669] RTAI[malloc]: unloaded. [ 1176.664015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1176.665415] I-pipe: head domain RTAI unregistered. [ 1176.665451] RTAI[hal]: unmounted.
9 years 4 months ago #94311 by sirop
Replied by sirop on topic Ethercat HAL driver
Could you do:
ldd lcec.so
9 years 4 months ago #94313 by ChrisB
Replied by ChrisB on topic Ethercat HAL driver
No !
9 years 4 months ago #94314 by sirop
Please, do it.
9 years 4 months ago #94315 by ChrisB
Sorry,
It does not work!
cnc@CNC-Plasma:~/linuxcnc/configs/Ethercat$ sudo ldd lcec.so
ldd: ./lcec.so: Datei oder Verzeichnis nicht gefunden
Time to create page: 0.204 seconds
