Ethercat HAL driver
- endian
- Thank you received: 134
11 Nov 2025 14:18 #338211
by endian
Replied by endian on topic Ethercat HAL driver
Translate it as complex . Import it as s32 or u32.. Then create simple component to cut it a pieces... Simple and effective
- mrgksworld
05 Mar 2026 09:48 #343896
by mrgksworld
Replied by mrgksworld on topic Ethercat HAL driver
Hello,
I try to integrate the security plc from Sick Flexi Soft via ethercat but I get the message that bitLen only allows 32 bits.
Are the restrictions limited to Linuxcnc-ethercat or do they also apply to the IGH ethercat-master.
Did you manage to integrate Sick Flexi Soft Safety controller with IgH Ethercat?
I can set the Sick safety controller in operational mode but can not able to get the data exchange correctly. Probably configuring the pdo incorrectly.
Time to create page: 0.170 seconds
