- Thank you received: 113
Ethercat HAL driver
- CORBETT
6 years 5 months ago #166565
by CORBETT
Replied by CORBETT on topic Ethercat HAL driver
I kept working over and over on TwinCAT 2.11 to get the ethernet card working and never could, but I downloaded TwinCAT 3.1 and it loaded the intel based ethernet card on the first try. I had already checked Beckhoff's website to make sure the ethernet card was compatible, but it just would never work in TC2.
So now I can see the EL5151 terminal in TwinCAT 3 config mode, but I am not quite sure what to do. I had read so much about TC2 that I am lost in TC3. I am just glad to finally see the thing show up in TwinCAT so I can try to get it working.
@ chimeno Albert, I will have to go back and review all that you stated in the past since I can finally see the terminal in TC3
- theshade
- Thank you received: 5
6 years 5 months ago #166640
by theshade
Replied by theshade on topic Ethercat HAL driver
Thank you, that was it..!!!!!
Except that (maybe because it's a pi... doing it as the "pi" user (without sudo) seemed to work better..
running
hg config --debug helped me figuring this out...
running
- theshade
6 years 5 months ago - 6 years 5 months ago #166754
by theshade
Still trying to compile on a raspberry,
I think I compiled everything but it seems the tool doesn't match the kernel module... and I don't know how to debug, configure or change what I did to make them match:
pi@raspberrypi:~/etherlabmaster/etherlabmaster-code/tool $ ./ethercat master
Failed to get master information: Inappropriate ioctl for device
found this related link from Florian but it's pretty old...
lists.etherlab.org/pipermail/etherlab-users/2009/000437.html
pi@raspberrypi:~/etherlabmaster/etherlabmaster-code/tool $ ./ethercat version
IgH EtherCAT master 1.5.2 0c011dc6dbc4+
the service is loaded:
pi@raspberrypi:~/etherlabmaster/etherlabmaster-code/tool $ systemctl status ethercat.service
* ethercat.service - EtherCAT Master Kernel Modules
Loaded: loaded (/etc/systemd/system/ethercat.service; enabled; vendor preset: enabled)
Active: active (exited) since Tue 2020-05-05 10:47:20 CEST; 1h 13min ago
Main PID: 2751 (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 4915)
Memory: 0B
CGroup: /system.slice/ethercat.service
May 05 10:47:20 raspberrypi systemd[1]: Starting EtherCAT Master Kernel Modules...
May 05 10:47:20 raspberrypi systemd[1]: Started EtherCAT Master Kernel Modules.
module are here:
pi@raspberrypi:~/etherlabmaster/etherlabmaster-code/tool $ modinfo ec_master
filename: /lib/modules/4.19.58-rt22-v7l+/updates/dkms/ec_master.ko
version: 1.5.2 unknown
license: GPL
description: EtherCAT master driver module
author: Florian Pose <fp@igh-essen.com>
srcversion: 39580AF71CC604526D48086
depends:
vermagic: 4.19.58-v7l SMP preempt mod_unload modversions ARMv7 p2v8
parm: main_devices:MAC addresses of main devices (array of charp)
parm: backup_devices:MAC addresses of backup devices (array of charp)
parm: debug_level:Debug level (uint)
pi@raspberrypi:~/etherlabmaster/etherlabmaster-code/script $ modinfo ec_generic
filename: /lib/modules/4.19.58-rt22-v7l+/updates/dkms/ec_generic.ko
license: GPL
description: EtherCAT master generic Ethernet device module
srcversion: 1AE486D6201500C92B67C63
depends: ec_master
so I redid a (not sure why) :
sudo apt-get install etherlabmaster
( I also checked the log when I use ec-debianize to build it and get the same errors)
Which resulted in this:
DKMS make.log for etherlabmaster-1.5.2+20190904hg33b922p8ea394 for kernel 4.19.58-rt22-v7l+ (armv7l)
Tue 5 May 11:51:01 CEST 2020
make: Entering directory '/usr/src/linux-headers-4.19.58-rt22-v7l+'
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/examples/mini/mini.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/module.o
LD [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/examples/mini/ec_mini.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/generic.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/sram.o
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c: In function 'ccat_dma_free':
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:264:3: error: implicit declaration of func$
free_dma(priv->func->info.tx_dma_chan);
free_irq
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c: In function 'ccat_dma_init':
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:286:6: error: implicit declaration of func$
if (request_dma(channel, KBUILD_MODNAME)) {
request_irq
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:303: /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.o]$
make[2]: *** [scripts/Makefile.build:544: /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat] Error 2
make[2]: *** Waiting for unfinished jobs....
LD [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ec_generic.o
make[1]: *** [scripts/Makefile.build:544: /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices] Error 2
make[1]: *** Waiting for unfinished jobs....
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/cdev.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/coe_emerg_ring.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/datagram.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/datagram_pair.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/device.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/domain.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fmmu_config.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/foe_request.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_change.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_coe.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_foe.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_reboot.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_master.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_mbox_gateway.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_pdo.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_pdo_entry.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_sii.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_slave.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_slave_config.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_slave_scan.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/fsm_soe.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/ioctl.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/mailbox.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/master.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/mbox_gateway_request.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/module.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/pdo.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/pdo_entry.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/pdo_list.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/reg_request.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sdo.o CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/datagram_pair.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sdo_entry.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sdo_request.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/slave.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/slave_config.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sii_firmware.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/soe_errors.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/soe_request.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sync.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/sync_config.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/voe_handler.o
CC [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/dict_request.o
LD [M] /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/master/ec_master.o
make: *** [Makefile:1517: _module_/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build] Error 2
make: Leaving directory '/usr/src/linux-headers-4.19.58-rt22-v7l+'
I did put:
MASTER0_DEVICE="eth0" in ethercat.conf
and
echo "ENABLE_CYCLES = NO" > configure/CONFIG_OPTIONS.local
and run
./configure --enable-generic --disable-8139too
recompiled and then did that ( forum.linuxcnc.org/27-driver-boards/3559...uxcnc-how-to-install ):
Open etc/default/ethercat as root : $ sudo thunar
Find your mac adres : $ ip link show (output = link/ether ....)
Type in MASTER0_DEVICE="lo:ve:me:te:nd:er" (your mac adres my dear)
Type in DEVICE_MODULES="generic"
$ sudo update-ethercat-config (reboot, or restart your pc)
I think I missed some configuration steps or maybe having both ec-debianized dpkg installed after the igh etherlabmaster.... but I don't know where... still trying things... but mostly getting lost...
Thank you in advance and sorry if I am slow and don't yet grab the essence of it... maybe I should start again from scratch (
Memory: 0B
module are here:
license: GPL
depends:
license: GPL
depends: ec_master
Warning: Spoiler!
Reading package lists... Done
Building dependency tree
Reading state information... Done
etherlabmaster is already the newest version (1.5.2+20190904hg33b922p8ea394-1).
The following packages were automatically installed and are no longer required:
comerr-dev cython krb5-multidev libavahi-client-dev libavahi-common-dev libboost-serialization-dev libboost-thread-dev
libczmq-dev libczmq4 libdbus-1-dev libev-dev libev4 libgssrpc4 libjansson-dev libkadm5clnt-mit11 libkadm5srv-mit11 libkdb5-9
libkrb5-dev libnorm-dev libpgm-dev libprotobuf-dev libprotobuf17 libprotoc-dev libprotoc17 libsodium-dev libsystemd-dev
liburiparser-dev liburiparser1 libwebsockets-dev libwebsockets8 libxaw7-dev libxpm-dev libzmq3-dev protobuf-compiler
python-protobuf python-pyftpdlib python-zmq
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 77 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up etherlabmaster (1.5.2+20190904hg33b922p8ea394-1) ...
Removing old etherlabmaster-1.5.2+20190904hg33b922p8ea394 DKMS files...
Deleting module version: 1.5.2+20190904hg33b922p8ea394
completely from the DKMS tree.
Done.
Loading new etherlabmaster-1.5.2+20190904hg33b922p8ea394 DKMS files...
Building for 4.19.58-rt22-v7l+
Building initial module for 4.19.58-rt22-v7l+
Error! Bad return status for module build on kernel: 4.19.58-rt22-v7l+ (armv7l)
Consult /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/make.log for more information.
dpkg: error processing package etherlabmaster (--configure):
installed etherlabmaster package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of etherlabmaster-dbgsym:
etherlabmaster-dbgsym depends on etherlabmaster (= 1.5.2+20190904hg33b922p8ea394-1); however:
Package etherlabmaster is not configured yet.
Version of etherlabmaster on system, provided by etherlabmaster:armhf, is <none>.
dpkg: error processing package etherlabmaster-dbgsym (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of etherlabmaster-dev:
etherlabmaster-dev depends on etherlabmaster; however:
Package etherlabmaster which provides etherlabmaster is not configured yet.
dpkg: error processing package etherlabmaster-dev (--configure):
Processing triggers for libc-bin (2.28-10+rpi1) ...
Errors were encountered while processing:
etherlabmaster
etherlabmaster-dev
E: Sub-process /usr/bin/dpkg returned an error code (1)
Done.
etherlabmaster
etherlabmaster-dev
Warning: Spoiler!
free_irq
request_irq
I did put:
and
and run
Last edit: 6 years 5 months ago by theshade.
- theshade
6 years 5 months ago #166822
by theshade
well tonigh I restarted from a fresh raspbian image and logged everything I did:
# Starting from fresh 2020-02-13-raspbian-buster-full.img install
# configure language, keyboard, wifi, enable VNC
#install subversion (svn)
sudo apt-get install subversion
# just because I forgot (it's the first thing to do)
sudo apt-get update
sudo apt-get upgrade
svn checkout github.com/sgawad/rpi4-4.19.58-rt/trunk/prebuilt
cd prebuilt/
chmod +x deploy.sh
./deploy.sh
# the pi will reboot by itself... at the end of deploy.sh
uname -a
Linux raspberrypi 4.19.58-rt22-v7l+ #1 SMP PREEMPT RT Fri Nov 1 14:58:37 KST 2019 armv7l GNU/Linux
git clone github.com/sittner/ec-debianize
cd ec-debianize/
# install mercurial with mq extensions (thx chimeno)
sudo apt-get install mercurial
hg config --edit
#PRESS 1
#ADD under
#[extensions]
mq =
save file /home/pi/.hgrc
./get_source.sh
cd etherlabmaster
dpkg-checkbuilddeps
sudo apt-get install debhelper
sudo apt-get install dkms
sudo apt-get install quilt
# end of output looks like
# dpkg-genbuildinfo
# dpkg-genchanges >../etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_armhf.changes
#dpkg-genchanges: info: including full source code in upload
# dpkg-source --after-build .
#dpkg-source: info: unapplying 40_safe_rt_mutex_enable.patch
#dpkg-source: info: unapplying 30_relax_al_state_change_timeout.diff
#dpkg-source: info: unapplying 20_fix_read_pdo_count.diff
#dpkg-source: info: unapplying 10_fix_distclean.diff
#dpkg-buildpackage: info: full upload (original source is included)
# signfile etherlabmaster_1.5.2+20190904hg33b922p8ea394-1.dsc
#gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
#gpg: skipped "Sascha Ittner <sascha.ittner@modusoft.de>": No secret key
#gpg: dpkg-sign.K_Eus86w/etherlabmaster_1.5.2+20190904hg33b922p8ea394-1.dsc: clear-sign failed: #No secret key
#dpkg-buildpackage: error: failed to sign .dsc file
# but apparently it's all normal !!!
#running
sudo dpkg -i etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_armhf.deb
#gives errors looking at the log... so had to fix acrroding to this
#The kernel headers are cross compiled and there's a bug in deb-pkg that packs the build host #executables rather than the target executables. Thankfully, the sources are also included with #the headers so you just have to recompile the header scripts.
#There are 4 steps needed to do this:
#1) Change to the Linux header directory:
cd /usr/src/linux-headers-`uname -r`
#1) Install the necessary dependencies:
sudo apt-get install -y build-essential bc bison flex libssl-dev
#2) Apply the byteshift patch to the headers:
wget raw.githubusercontent.com/armbian/build/...bian-byteshift.patch -O - | sudo patch -p1
#3) Compile the scripts:
sudo make scripts
#Now DKMS should work like normal. This is useful for adding Realtek wireless devices and other #drivers.
(Reading database ... 230473 files and directories currently installed.)
Preparing to unpack etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_armhf.deb ...
Done.
Unpacking etherlabmaster (1.5.2+20190904hg33b922p8ea394-1) over (1.5.2+20190904hg33b922p8ea394-1) ...
dpkg: error processing package etherlabmaster (--install):
etherlabmaster
the log content is now as follow and the first error is gone... others are still there tough...
sudo apt-get update
cd prebuilt/
chmod +x deploy.sh
./deploy.sh
uname -a
cd ec-debianize/
hg config --edit
#PRESS 1
#ADD under
#[extensions]
mq =
./get_source.sh
cd etherlabmaster
dpkg-checkbuilddeps
# dpkg-genbuildinfo
#running
sudo make scripts
Done.
etherlabmaster
Warning: Spoiler!
Wed 6 May 00:56:07 BST 2020
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:264:3: error: implicit declaration of function 'free_dma'; did you mean 'free_irq'? [-Werror=implicit-function-declaration]
free_irq
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:286:6: error: implicit declaration of function 'request_dma'; did you mean 'request_irq'? [-Werror=implicit-function-declaration]
request_irq
make[3]: *** [scripts/Makefile.build:303: /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.o] Error 1
make[3]: *** Waiting for unfinished jobs....
free_irq
request_irq
- chimeno
- Thank you received: 125
6 years 5 months ago #166888
by chimeno
Replied by chimeno on topic Ethercat HAL driver
Hi @theshade
I have no experience in Raspbian, can you try this if it helps you?
Greeting
Chimeno
./get_source.sh
dpkg-buildpackage -uc -us
Chimeno
- theshade
6 years 5 months ago #166894
by theshade
Hi @chimeno, Thank you so much for your help.
making the package works with
./get_source.sh
and it doesn't complain about the missing signature ..
but again it's when I install the package:
that I get the some compile errors about "free_dma" and "free_irq" : (same as last night)
Thu 7 May 00:27:29 CEST 2020
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:264:3: error: implicit declaration of function 'free_dma'; did you mean 'free_irq'? [-Werror=$
free_irq
/var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/devices/ccat/netdev.c:286:6: error: implicit declaration of function 'request_dma'; did you mean 'request_irq'? [-W$
request_irq
Thanks anyway..
./get_source.sh
Warning: Spoiler!
free_irq
request_irq
Thanks anyway..
Time to create page: 0.186 seconds
