- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Beckhoff ethercat 64 with bit linuxcnc, How to install.
- hozte
29 Sep 2020 06:35 #184242
by hozte
Replied by hozte on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hello AP,
do you find a solution? I have the same problem.
Matthias
Matthias
- hozte
29 Sep 2020 08:21 #184253
by hozte
After reading this Thread, Grotis give a hint at page 4 to someone who have the same problem. Unfortunately i cant read the hint:-(
Maybe Grotius can help again?
best regards Matthias
- Grotius
- Thank you received: 2349
29 Sep 2020 09:11 - 29 Sep 2020 09:18 #184257
by Grotius
Replied by Grotius on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Ec debianize is just a script for autostart the ethercat bus at pc startup.
But if ec debianize is not working, follow this steps and start your bus by a terminal command.
For info, this example has nothing involved with linuxcnc. The steps are showing how to install the ethercat bus on a linux pc and
then how to insert a ethercat kernel module EL2124 into the golden ring.
Info:
etherlab.org/en/ethercat/index.php
in terminal :
hg clone hg.code.sf.net/p/etherlabmaster/code ethercat-hg
cd ethercat-hg
hg update stable-1.5
Then in the ethercat-hg directory open the textfile INSTALL with text editor. Follow this steps.
In terminal:
./bootstrap
./configure --disable-8139too (this disables the 8139 driver, we will use generic driver)
make all modules
sudo make modules_install install
sudo depmod
--x--
sudo ln -s ${PREFIX}/etc/init.d/ethercat /etc/init.d/ethercat
sudo cp ${PREFIX}/etc/sysconfig/ethercat /etc/sysconfig/ethercat
--x--
if the steps between x are a problem. open directory ethercat-hg/script/
copy the ethercat-hg/sysconfig map to c:etc/ result = c:etc/sysconfig/ethercat
copy the ethercat-hg/inti.d/ethercat to c:etc/init.d/.. result = etc/init.d/etercat
Then in terminal :
ip link show (for your mac adres, used by next step)
open file as root : (sudo thunar, or sudo apt-get install thunar)
/etc/sysconfig/ethercat ( insert mac adress and generic driver )
MASTER0_DEVICE="yo:ur:ma:c:ad:re"
DEVICE_MODULES="generic"
Ok close file.
This one i did not use :
echo KERNEL==\"EtherCAT[0-9]*\", MODE=\"0664\" > /etc/udev/rules.d/99-EtherCAT.rules
Restart your system.
I started the ethercat by terminal command :
/etc/init.d/ethercat start
or
sudo /etc/init.d/ethercat start
You can do also : ethercat start / ethercat stop / ethercat status / etc.
Now the lights on the busterminal are flickering.
To test a kernel module, in terminal :
goto :
ethercat-hg/examples/mini/ (open terminal here)
In terminal :
sudo insmod ec_mini.ko
dmesg
My output : [ 6256.088425] ec_mini: AL states: 0x0A.
Ok now we make a custom kernel module for the EL2124. See attached mini.c file
Rename your current ethercat-hg/examples/mini.c file
Copy the attached mini.c file into ethercat-hg/examples
1.
open terminal in : ethercat-hg/examples/mini/
in terminal :
sudo make clean
2.
in terminal :
make modules all
3.
in terminal :
4.
In terminal type : dmesg
Output dmesg :
[ 6647.436412] EtherCAT 0: Domain 0: Working counter changed to 1/1
[ 6647.436413] .
[ 6647.436414] ec_mini: Domain1: WC 1.
[ 6647.436415] ec_mini: Domain1: State 2.
[ 6647.508440] EtherCAT 0: Slave states on main device: OP.
[ 6647.804426] ec_mini: AL states: 0x08.
Ok the EL2124 is flickering 5 volts outputs. So now we are sure the ethercat bus is working oke.
to unload the kernel module : sudo rmmod ec_mini.ko
then : dmesg
Terminal output:
[ 7365.583838] ec_mini: Stopping...
[ 7365.583841] ec_mini: Releasing master...
[ 7365.583842] EtherCAT 0: Releasing master...
[ 7365.583868] EtherCAT 0: Master thread exited.
[ 7365.583875] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 7365.583916] EtherCAT 0: Released.
[ 7365.583916] ec_mini: Unloading.
[ 7365.592445] EtherCAT 0: Slave states on main device: PREOP, OP.
[ 7365.616433] EtherCAT 0: Slave states on main device: PREOP.
In the map /ethercat-hg/examples/user/main.c
This example is also working nice with QT programming. But it's at userland level.
Info:
in terminal :
cd ethercat-hg
In terminal:
./bootstrap
make all modules
sudo depmod
--x--
--x--
Then in terminal :
Ok close file.
or
goto :
In terminal :
dmesg
1.
in terminal :
sudo make clean
2.
in terminal :
make modules all
3.
in terminal :
4.
Output dmesg :
[ 6647.436413] .
then : dmesg
Terminal output:
Last edit: 29 Sep 2020 09:18 by Grotius.
The following user(s) said Thank You: Nico2017
- hozte
29 Sep 2020 18:03 #184314
by hozte
Hello Grotius,
thanks for this fast answer. I will test this tomorrow.
- hozte
05 Oct 2020 10:08 #184955
by hozte
it requiered more time, but it works!
Many thanks
Many thanks
- Grotius
05 Oct 2020 18:31 #184991
by Grotius
** Installation guide for Ethercat with Debian10.
It's done in 4 stages.
1. Install debian 10 (includes linuxcnc)
2. Install etherlab software
3. Install ec-debianize (is etherlab, configured linuxcnc compatible)
4. Install linuxcnc-ethercat (lcec driver for linuxcnc)
$ are user terminal commands, # as root.
-- Download & install the iso cd : www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso
-- Install missing buster kernel headers
$ sudo apt install linux-headers-$(uname -r)
-- Install some dependencies
$ sudo apt-get install debhelper dkms gettext autoconf automake libtool quilt mercurial git
-- Get the ethercat software
$ hg clone hg.code.sf.net/p/etherlabmaster/code ethercat-hg
$ cd ethercat-hg
$ hg update stable-1.5
-- Install the ethercat software
$ ./bootstrap
$ ./configure --disable-8139too --with-linux-dir=/usr/src/linux-headers-4.19.0-11-rt-amd64/
$ make all modules
$ sudo make modules_install install
$ sudo depmod
**x**
-- Retrieve mac adres
$ ip link show
-- Copy some files around. Use $ sudo thunar
copy from etherlab-hg directory "script/init.d/ethercat" to /etc/init.d/ -->> change permissions to user
copy from etherlab-hg directory "script/sysconfig/ethercat" to /etc/sysconfig -->> change permissions to user
-- Edit ethercat file in /etc/sysconfig/:
MASTER0_DEVICE="your mac adres"
**x**
-- Start Ethercat bus
$ sudo /etc/init.d/ethercat start
-- Check if your ethercat bus is running :
$ sudo /etc/init.d/ethercat status
-- At this stage we have no ec-debianize patches done to the ethercat software.
-- Install ec-debianize
edit file :
/etc/mercurial/hgrc
add to file :
[extensions]
mq =
$ git clone github.com/sittner/ec-debianize.git
$ cd ec-debianize
$ ./get_source.sh
$ cd etherlabmaster && dpkg-checkbuilddeps (and install missing deps by : sudo apt-get instal ..)
$ dpkg-buildpackage
-- Install deb packages
$ sudo dpkg -i /home/user/ec-debianize/etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_amd64.deb
$ sudo dpkg -i /home/user/ec-debianize/etherlabmaster-dbgsym_1.5.2+20190904hg33b922p8ea394-1_amd64.deb
$ sudo dpkg -i /home/user/ec-debianize/etherlabmaster-dev_1.5.2+20190904hg33b922p8ea394-1_amd64.deb
edit file : /etc/default/ethercat -> see steps section **x** above
$ sudo update-ethercat-config
-- Install linuxcnc-ethercat
$ git clone github.com/sittner/linuxcnc-ethercat.git
$ cd linuxcnc-ethercat
$ sudo apt-get install libexpat1-dev
$ make
Restart pc. Ethercat bus will now start by itself. Don't forget to attach cat cable.
-- Test Linuxcnc with ethercat
1. Start linuxcnc choose axis config, create desktop icon.
2. Edit : /home/user/linuxcnc/configs/sim.axis/axis.ini
Add : POSTGUI_HALFILE = postgui.hal
3. Create postgui.hal file in the axis.ini directory.
Add :
loadusr -W /home/user/linuxcnc-ethercat/src/lcec_conf /home/user/linuxcnc/configs/sim.axis/ethercat-conf.xml
loadrt lcec
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
4. Create ethercat-conf.xml file in the axis.ini directory.
my file looks like :
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000">
<slave idx="0" type="EK1100" name="Terminal"/>
<slave idx="1" type="EL2124" name="Dig_out0"/>
<slave idx="2" type="EL2124" name="Dig_out1"/>
</master>
</masters>
5. Copy the lcec_conf file from /home/user/linuxcnc-ethercat/src/ to your linuxcnc axis.ini directory
6. Copy the lcec.so file from /home/user/linuxcnc-ethercat/src/ to /usr/lib/linuxcnc/modules/
7. Open /dev/Ethercat0 --> set all permissions to read/write.
Open /etc/udev/rules.d/00-ethercat.rules -> to stop complaining Ethercat0 rules i modified to : KERNEL=="EtherCAT[0-9]*", MODE="0660", GROUP="your user group name"
8. Restart linuxcnc. Open machine -> hal configuration -> Pins -> lcec
your slave pin's will show up.
9. Test Hal command : setp lcec.0.Dig_out0.dout-0 true
10. Oke that's all. Application restart tested ok.
$ cd ethercat-hg
$ ./bootstrap
$ make all modules
$ sudo depmod
**x**
$ ip link show
**x**
edit file :
/etc/mercurial/hgrc
add to file :
[extensions]
mq =
$ cd ec-debianize
$ ./get_source.sh
$ dpkg-buildpackage
$ make
Add :
loadrt lcec
<masters>
</master>
</masters>
The following user(s) said Thank You: tommylight, Nico2017
- Mduran
05 Oct 2020 20:07 #185002
by Mduran
Replied by Mduran on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
good, I new to this group and i want to install ethercat on my machines as show in your instructions, when executing the "dpkg-buildpackage" instruction inside the etherlabmaster directory, it throws me this error, you know why:
dpkg-source --before-build etherlabmaster
debian/rules clean
dh clean --with autoreconf,dkms
dh_testdir
dh_auto_clean
dh_autoreconf_clean
debian/rules override_dh_clean
make[1]: Entering directory '/home/lion/ec-debianize/etherlabmaster'
rm -f ChangeLog
dh_clean
make[1]: Leaving directory '/home/lion/ec-debianize/etherlabmaster'
dpkg-source -b etherlabmaster
dpkg-source: error: can't build with source format '3.0 (quilt)': no upstream tarball found at ../etherlabmaster_1.5.2+20190904hg33b922p8ea394.orig.tar.{bz2,gz,lzma,xz}
dpkg-buildpackage: error: dpkg-source -b etherlabmaster gave error exit status 255
debian/rules clean
dh_testdir
dh_auto_clean
dh_autoreconf_clean
rm -f ChangeLog
dh_clean
- Grotius
05 Oct 2020 20:46 - 05 Oct 2020 20:58 #185006
by Grotius
Hi, I know your error. I could fix that quite quickly. It's solution is at --Install ec-debianize next line.
Just to help you a little bit more :
First be sure you have a mercurial install.
$ sudo apt-get install mercurial (mercurial is just as github, mercurial has a config file we have to edit to solve your issue).
Open file : c:/etc/mercurial/hgrc (use "sudo thunar" in terminal to edit the file as root)
Add to file hgrc file the following 2 lines of text :
[extensions]
mq =
save file.
reference 1 : forum.linuxcnc.org/24-hal-components/223...ver?start=870#166516
reference 2 : stackoverflow.com/questions/8360471/how-...xtensions-such-as-mq
If your error keeps the same. restart pc.
[extensions]
mq =
save file.
Last edit: 05 Oct 2020 20:58 by Grotius.
The following user(s) said Thank You: Nico2017, Mduran
- Mduran
05 Oct 2020 23:37 #185019
by Mduran
Grotius, thanks for your quick answer, it worked for me but at the moment of wanting to run an ini file from linuxcnc I get the following error in terminal:
# I already copied the lcec_conf file in the file where the ini are, so if the error I do not think is because of that
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/lion/linuxcnc_debug.txt
and
/home/lion/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
and
- Grotius
06 Oct 2020 12:40 - 06 Oct 2020 12:48 #185057
by Grotius
Hi Mike,
You forgot to send the debug output of linuxcnc. Or make a screenshot of the relevant debug info.
Start your linuxcnc config step by step. And be sure about correct path's.
In my postgui.hal file the search path is :
For your postgui.hal file the path is :
1**. loadusr -W /youpath/lcec_conf .. .. .. .. .. /yourpath/ethercat-conf.xml (delete the dots)
2. loadrt lcec
3. addf lcec.read-all servo-thread
In fact you could directly link to the orginal lcec_conf folder, in above example without making a copy of the
lcec_conf file to your linuxcnc config directory, where your axis.ini file is located.
You could start linuxcnc with only line 1**. Only load the lcec_conf file. If linuxcnc starts normal, add line 2, etc.
Check the message output of linuxcnc and anticipate on this. If you can't solve it. Just ask over here.
I mentioned Debian buster 10 will not provide usb-tetering from a clean install.
To enable Ethernet over USB :
in terminal :
$ ip link show --> look for the output number other then enp0s25 or lo, in my case :
3: enp0s26f7u5: <BROADCAST,MULTICAST,UP,LOWER_UP>
goto :
c:/etc/modules-load.d/modules.conf --> add:
g_ether
c:/etc/network/interfaces --> add :
allow-hotplug enp0s26f7u5
iface enp0s26f7u5 inet dhcp
done !
restart pc.
Reference : unix.stackexchange.com/questions/574640/...-using-ethernet-over
2. loadrt lcec
in terminal :
goto :
g_ether
done !
restart pc.
Last edit: 06 Oct 2020 12:48 by Grotius.
The following user(s) said Thank You: Mduran
- EtherCAT
Time to create page: 0.307 seconds
