- Thank you received: 125
Beckhoff ethercat 64 with bit linuxcnc, How to install.
- chimeno
6 years 3 months ago #175186
by chimeno
Replied by chimeno on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hi @bkt
sorry, I guess I misread your problem.
Greeting
Chimeno
Greeting
Chimeno
The following user(s) said Thank You: bkt
- bkt
- Thank you received: 114
6 years 3 months ago #175337
by bkt
Replied by bkt on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
@chimeno ... no worry for the work you have done on ethercat theme here on the forum you can allow yourself many other mistakes without anyone having anything to complain about
Any how only chance is try to install Lcnc 2.8 ..... but we need to use joint/axis trick (angular or world coordinates on ngc file) provided by dgarret .... on 2.9 works ok on real machine ....
about halcopile not find .... I've not a solution now.
bkt
bkt
The following user(s) said Thank You: chimeno
- bkt
6 years 3 months ago #175339
by bkt
now I have an other questions ..... If install more than one Lcnc-dev versions on home folder ..... linuxcnc-ethercat-master can see the right one?? How??
reagards
bkt
reagards
bkt
- bkt
6 years 3 months ago #175469
by bkt
I try to understand snitter code and where is call halcopile comp, but not see the call .... i think is only a problem of wrong path on 2.9 lcnc rt-preempt versions ... so I try to find the problem and fix it .....
- bkt
6 years 3 months ago - 6 years 3 months ago #175536
by bkt
Now for sure there are a problem. I try with these installation:
so nothing change from 2.9 Lcnc versions .... same problem ... where do I check to solve?
bkt
- Remove previous Lcnc istallation
Code:apt-get purge linuxcnc-doc-en linuxcnc-uspace-dev linuxcnc-uspace
- Setup LinuxCNC 2.8 (download zip file from github selecting 2.8 version)
Code:cd linuxcnc (renamed from linuxcnc2.8 into linuxcnc after extraction)/debian ./configure uspace cd .. cd src make ./autogen.sh ./configure --with-realtime=uspace make -j4 sudo make setuid
- Setup "ec-debianize"
Code:git clone https://github.com/sittner/ec-debianize ec-debianize cd /ec-debianize ./get_source.sh cd etherlabmaster dpkg-buildpackage (the output error "failed to sign .dsc file" is no issue) sudo dpkg -i /git/ec-debianize/etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_amd64.deb (in my case) sudo dpkg -i /git/ec-debianize/etherlabmaster-dev_1.5.2+20190904hgp8ea394-1_amd64.deb (in my case) gedit /etc/default/ethercat (change mac-address [MASTER0_DEVICE=""] e.g. [MASTER0_DEVICE="15:27:33:48:55:66"]) gedit /etc/default/ethercat (change [DEVICE_MODULES=""] to [DEVICE_MODULES="generic"]) sudo update-ethercat-config usermod -a -G ethercat demo (my user) reboot
- Setup "LinuxCNC-Ethercat"
Code:git clone http://github.com/sittner/linuxcnc-ethercat.git linuxcnc-ethercat" gedit /git/linuxcnc-ethercat/src/lcec_main.c (add here [#include "rtapi_mutex.h"] below [#include "rtapi_app.h"]) cd /linuxcnc-ethercat make -j4 ----> error
Code:demo@demo:~/linuxcnc-ethercat$ make configure.mk:8: *** halcompile/comp executable not found or set. Stop. Makefile:17: recipe for target 'config.mk' failed make: *** [config.mk] Error 2
bkt
Last edit: 6 years 3 months ago by bkt.
- Grotius
- Thank you received: 2349
6 years 3 months ago - 6 years 3 months ago #175969
by Grotius
Replied by Grotius on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
If you have some time left,
Soon i will do a new Ethercat installation to trigger your problem. Will let you know what can be your problem.
Last edit: 6 years 3 months ago by Grotius.
Time to create page: 0.277 seconds
