Beckhoff ethercat 64 with bit linuxcnc, How to install.
09 Jul 2019 20:04 #138967 by JimPanski
Hello Grotius!
so this means you dont use the ena signal on the drivers and ony stp+dir for one axis?
Yes, in both tutorials you have to create the halfile called postgui.hal. thats a bit confusing because when you use the (already) existig postgui_call_list.hal to shorten things up (i thaught in that moment), you wont succeed ;)
What item do you mean?
Cheers,
Conny
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Jul 2019 20:26 #139018 by Grotius
@Conny,
That is correct. I don't use enable signals, do you know why?
You need the postgui.hal file. It's a very good program flow for the linuxcnc software. Some developper's had to think about
this file at that time.
In my tutorial there is no file like :
10 Jul 2019 22:18 #139029 by JimPanski
No, I really don't know why. Please tell me the reason why.
  • Grotius
  • Platinum Member
  • Platinum Member
10 Jul 2019 23:20 - 10 Jul 2019 23:29 #139036 by Grotius
@Jim,
I will tell you why..
Once i was expert programmer related to Kuka robotic's.
Safety is number one in automotive industry. So enable the robot servo drives is not a option if a person is trapped by a robot.
It will only cause more (hours) of delay to free the person. To free the person first the drives have to be enabled. For lineair machines main power shut down is the best option.
Last edit: 10 Jul 2019 23:29 by Grotius.
11 Jul 2019 19:35 #139121 by JimPanski
Hi Grotius,
thanks, that makes sense.
There is one other thing:
Please tell me, that i have a chance to use Beckhoff KL modules with linuxcnc. (if not - i may have a problem..)
25 Jul 2019 20:50 - 25 Jul 2019 20:51 #140567 by JimPanski
Hello Grotius,
3. Modify the EL3255.c and EL3255.h to your EL3062.c and EL3062.h needs.
It's almost as simple as the find and replace function for whole document with text editor geany.
I didnt get this. So please can you say what in your example was really needed to change?
Conny
Last edit: 25 Jul 2019 20:51 by JimPanski.
  • Grotius
  • Platinum Member
  • Platinum Member
25 Jul 2019 21:00 #140568 by Grotius
Hi Conny,
What i mentioned, if a driver not exist's it is possible to copy and edit a existing driver.
25 Jul 2019 21:17 #140570 by JimPanski
What i meant was what exactly is needed to change in this files.
In the .h file i have seen its the PID VID and PDOS lines but what do i need to change in the .c file?
I am asking because today i get my K-Bus modules wich now i need to adopt drivers for :/
Thank you!
Conny
  • Grotius
  • Platinum Member
  • Platinum Member
25 Jul 2019 21:26 - 25 Jul 2019 21:28 #140571 by Grotius
@Conny,
It depend's of the difference. If you are only editing a driver name, it's quite easy.
If you want to edit a 2 channel analog input from 16 to 10 bit for example, it's more complicated.
You have to edit more related to the 16 and 10 bit input size.
But if you think logical it would be to do. And take your time. If you are stuck for 36 hour's we can help you with coding.
Header file's are not so important. But you have to look at it alway's if there are differences.
Last edit: 25 Jul 2019 21:28 by Grotius.
The following user(s) said Thank You: Nico2017, BICHLER
12 Feb 2020 05:43 #157120 by Sockheaven
Hi everyone,
I've build an XXYZ gantry and have it running on step/dir but wanted to move to EtherCAT for improved performance.
(using Kollmorgen Servo Drives)
I stumbled upon this guide but I'm stuck at installing etherlab.
When i run the step:
dpkg-buildpackage
and the output I get is:
~/ec-debianize/etherlabmaster$ dpkg-buildpackage
dpkg-buildpackage: info: source package etherlabmaster
dpkg-buildpackage: info: source version 1.5.2+20190904hg33b922p8ea394-1
dpkg-buildpackage: info: source distribution lucid
dpkg-buildpackage: info: source changed by Sascha Ittner <This email address is being protected from spambots. You need JavaScript enabled to view it.>
dpkg-buildpackage: info: host architecture amd64
dpkg-source --before-build etherlabmaster
fakeroot debian/rules clean
dh clean --with autoreconf,dkms
dh_testdir
dh_auto_clean
dh_autoreconf_clean
debian/rules override_dh_clean
make[1]: Entering directory '/home/paul/ec-debianize/etherlabmaster'
rm -f ChangeLog
dh_clean
make[1]: Leaving directory '/home/paul/ec-debianize/etherlabmaster'
dpkg-source -b etherlabmaster
dpkg-source: error: can't build with source format '3.0 (quilt)': no upstream tarball found at ../etherlabmaster_1.5.2+20190904hg33b922p8ea394.orig.tar.{bz2,gz,lzma,xz}
dpkg-buildpackage: error: dpkg-source -b etherlabmaster gave error exit status 255
I've found various people with this problem with quilt and they used different build arguments, and while some build arguments appear to make it farther (or the build output is more verbose), it always has the same failure.
I saw someone earlier mention that they had a similar problem that was solved by making sure they had the correct headers - I updated my RT kernel and headers and removed all others but am still having this same issue.
Has anyone else run into this issue?
Best Regards,
Paul
Time to create page: 0.231 seconds
