Beckhoff ethercat 64 with bit linuxcnc, How to install.
- V-max
3 years 11 months ago #257198
by V-max
Replied by V-max on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hi BOYZO.
Im sorry but i wasnt be abble to run the bechhoff driver with linuxcnc.
I will try again with more time but now i cant help you with some confidence.
Nevertheless there are person here who know a lot.
Luck,
Luck,
- Sviper
- Thank you received: 10
3 years 11 months ago #257210
by Sviper
Replied by Sviper on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hello boyzo,
if you are german maybe you can find a lot of information on this tread:
forum.linuxcnc.org/42-deutsch/43027-prob...n-ethercat?start=170
i configured a lot of new xml for EP Module on this thread.
- Sviper
3 years 11 months ago #257212
by Sviper
in this post i describe roughly how it works
forum.linuxcnc.org/42-deutsch/43027-prob...cat?start=170#233740
- boyzo
- Thank you received: 3
3 years 11 months ago #257244
by boyzo
Replied by boyzo on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Thank you, I am getting through some of your post with google translate.
I did export xml in TC2 and I get huge .xml file for AX5205. From some examples in this forum .xml file content is much shrink. What I really need for correct config?
- Sviper
3 years 11 months ago #257247
by Sviper
I don't used the xml from Twincat für the ep's.
You have only to type in your console:
ethercat pdos
then you have the Information for the EL or EP Module.
I think for the AX5205 you need the configuration for the PDO.
I had configured my JAT servo amplifiers first and then created the XML afterwards. Find attached my configuration.
Can you send us the console output for ethercat pdos like
ethercat pdos >> pdo.list
ethercat pdos
- boyzo
3 years 11 months ago #257350
by boyzo
ethercat slave
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL1809 16K. Dig. Eingang 24V, 3ms
2 0:2 PREOP + EL2809 16K. Dig. Ausgang 24V, 0.5A
3 0:3 PREOP + AX5203-0000-0203 EtherCAT Drive (SoE, 2 Ch.)
Attachment is my pdos output
Maybe you can help me also with .hal file to get basic things there? Do you use some configuration utility like pncconf?
Time to create page: 0.499 seconds
