- Thank you received: 125
Ethercat with EL6751 CanOpen Master and JAT Servo Drives
6 years 7 months ago - 6 years 7 months ago #159249
by chimeno
Replied by chimeno on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hi @Conny
I don't know how else I can help you
greeting
Chimeno
I don't have them, I could be interested, although then I need another device with CAN-OPEN protocol for the tests that I don't have eitherfirst of all I was asking if you have those devices because I got a second set op it here wich I could maybe share if you are interested.
greeting
Chimeno
Last edit: 6 years 7 months ago by chimeno.
6 years 7 months ago #159250
by JimPanski
Replied by JimPanski on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hi Chimeno,
do you mean an other device besides that JAT drive?
If not sending you those both components wont be a big thing to me
Thank you!
Conny
Thank you!
Conny
6 years 7 months ago #159843
by chimeno
Hello @Conny,
Sorry for taking the time to answer, if I refer to both components, I am from Barcelona, Spain, are you progressing?
greeting
Chimeno
greeting
Chimeno
6 years 7 months ago #159853
by JimPanski
Hi Chimeno,
no problem. I also had noch chance to get further because of less time for it.But the lathe on which i want to use those drives got a bunch of new wiring and lot a new paint in the meantime
- but still much to do on it.
For this PDO issue I also don´t know what else I could try, so this was also a reason why it gets no progress her.
I think -if you really have no problem with that- the best is you reach me by mail on my account "myusernamehere" at online.de so we can discuss the details for the parcel
Thank you very much!
Greetings
Conny
Greetings
Conny
6 years 7 months ago #159920
by chimeno
Hello @Conny,
No problem I sent you an email.
Best regards
Chimeno
Best regards
Chimeno
6 years 6 months ago - 6 years 6 months ago #165630
by purged
Hi Guys, I am stuck in a similar situation, may I chime in?
I am trying to have LinuxCNC talk to ESTUN ProNet Plus series servo drives via linuxcnc-ethercat->Beckhoff EK1100->Beckhoff EL6751.
There is a CANopen manual from the manufacturer so I have high hopes of getting that to work: www.estuneurope.eu/wp-content/uploads/20...anual_compressed.pdf
I have set up TwinCAT on a separate windows machine and I can scan and find all Beckhoff devices automatically. It finds 'special device' EL6751 and asks for baud rate which I set to 500k, the same which I have configured my servo drives to. TwinCAT then 'scans Fieldbus' which takes 30 - 40 seconds or so, but it doesn't discover my servo drives. Is that normal or is my cabling faulty? I've seen in a Nanotec application note that their CANopen devices can be discovered automatically ( en.nanotec.com/fileadmin/files/Applicati.../TwinCAT/TwinCAT.pdf )
On the other hand I have all the PDO data and everything in the CANopen manual so I could set up the devices all manually. How do I generate the ethercat-conf.xml (i.e. github.com/sittner/linuxcnc-ethercat/blo...ex/ethercat-conf.xml ) in TwinCAT then?
Thank you very much
Replied by purged on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
JimPanski wrote: In the meantime i think I got a better overview in Twincat, so that I could finally find the COE Startup SDOs which were used in the config xml file.
Thank you very much
Last edit: 6 years 6 months ago by purged.
Time to create page: 0.270 seconds
