- Thank you received: 10
Ethercat with EL6751 CanOpen Master and JAT Servo Drives
5 years 2 weeks ago - 5 years 2 weeks ago #223487
by Sviper
Replied by Sviper on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hello JimPanski
please share the config File for the EL6751 for the JAT Servo Drives.
Can you post your last Twincat Projekt and the xml for Linuxcnc?
I have 4 Ecovario 414 maybe I can drive my cnc with linuxcnc over ethercat and CanOpen.
Are you german?
Greetings
Steffen
Are you german?
Greetings
Steffen
Last edit: 5 years 2 weeks ago by Sviper.
5 years 1 day ago #224855
by Sviper
would you help me? I would also drive JAT Ecovario servodrives using the EL6751.
Do you have the latest data from JimPanski?
Unfortunately it does not work with the XML attached here.
Regards sviper
Hello chimeno,Hi @JimPanski
This device is not configured in linuxcnc-ethercat, you will have to create using the generic one, I will attach a configuration finalizing EL6751, first you have to send the configuration and then load the PDOs, I hope it helps you.
Chimeno
Regards sviper
5 years 1 day ago #224860
by db1981
Replied by db1981 on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hello,
can you descripe what in detail is not working?
Do you have an working Twincat Configuration?
und schau mal hier nach : forum.linuxcnc.org/42-deutsch/43027-prob...on-ethercat?start=10
The following user(s) said Thank You: Sviper
5 years 1 day ago #224867
by Sviper
I'll try to put everything together tonight and post it in the German thread.
Helle db1981,Hello,
Time to create page: 0.195 seconds
