- Thank you received: 3
Ethercat with EL6751 CanOpen Master and JAT Servo Drives
6 years 8 months ago - 6 years 8 months ago #157901
by JimPanski
Replied by JimPanski on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hi Chimeno,
finally I got time for testing:
this happens when i start it with the config file attached.
The only different from yours: This config file has only the 2 0x28FF set to the right values like i posted it before. (the win Twincat wont run with standard 1ms synchtime of the servo drive)
Sadly with your .xml File i also had no luck:
In the meantime i think I got a better overview in Twincat, so that I could finally find the COE Startup SDOs which were used in the config xml file.
Do you have any further hints for me?
Thank you for your help!
Greetings
Conny
Warning: Spoiler!
[26338.866289] EtherCAT ERROR 0-1: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[26338.870305] EtherCAT ERROR 0-1: AL status message 0x001E: "Invalid input configuration".
[26338.878321] EtherCAT 0-1: Acknowledged state PREOP.
[26338.882332] EtherCAT 0: Slave states on main device: PREOP, OP.
[26339.861153] EtherCAT 0: Domain 0: Working counter changed to 0/3
[26339.861154] .
[26385.002571] EtherCAT 0: Master thread exited.
[26385.002581] EtherCAT 0: Starting EtherCAT-IDLE thread.
[26385.002617] EtherCAT ERROR 0-0: Failed to receive AL state datagram:
[26385.002620] Datagram
[26385.002621] initialized
[26385.002622] .
[26385.002628] EtherCAT 0: Releasing master...
[26385.003200] EtherCAT 0: Released.
[26385.119901] EtherCAT 0: Slave states on main device: PREOP.
[26385.294546] EtherCAT WARNING: Datagram ffff8a6374aaa678 (master-fsm) was SKIPPED 1 time.
[26426.248972] EtherCAT: Requesting master 0...
[26426.248975] EtherCAT: Successfully requested master 0.
[26426.249103] EtherCAT 0: Domain0: Logical address 0x00000000, 7 byte, expected working counter 3.
[26426.249104] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 7 byte, type LRW.
[26426.252131] EtherCAT 0: Master thread exited.
[26426.252134] EtherCAT 0: Starting EtherCAT-OP thread.
[26426.252163] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[26426.584824] EtherCAT WARNING 0-1: Slave does not support changing the PDO mapping!
[26426.584826] EtherCAT WARNING 0-1:
[26426.584827] Currently mapped PDO entries:
[26426.584828] (none)
[26426.584828] . Entries to map:
[26426.584829] 0x7000:01/16
[26426.584831] EtherCAT WARNING 0-1: Slave does not support assigning PDOs!
[26426.584832] EtherCAT WARNING 0-1:
[26426.584832] Currently assigned PDOs:
[26426.584833] (none)
[26426.584833] . PDOs to assign:
[26426.584834] 0x1600
[26426.596856] EtherCAT WARNING 0-1: Slave does not support changing the PDO mapping!
[26426.596857] EtherCAT WARNING 0-1:
[26426.596858] Currently mapped PDO entries:
[26426.596858] (none)
[26426.596859] . Entries to map:
[26426.596860] 0x6000:01/16
[26426.608880] EtherCAT WARNING 0-1: Slave does not support changing the PDO mapping!
[26426.608881] EtherCAT WARNING 0-1:
[26426.608881] Currently mapped PDO entries:
[26426.608882] (none)
[26426.608882] . Entries to map:
[26426.608883] 0xA000:01/8
[26426.608884]
[26426.608884] 0xF100:01/8
[26426.608885]
[26426.608885] 0xF100:03/1
[26426.608886]
[26426.608886] 0xF100:05/1
[26426.608887]
[26426.608887] 0xF100:04/1
[26426.608888]
[26426.608888] 0xF100:02/1
[26426.608889]
[26426.608889] 0xA000:02/1
[26426.608890] EtherCAT WARNING 0-1: Slave does not support assigning PDOs!
[26426.608891] EtherCAT WARNING 0-1:
[26426.608891] Currently assigned PDOs:
[26426.608892] (none)
[26426.608892] . PDOs to assign:
[26426.608893] 0x1A00
[26426.608893]
[26426.608893] 0x1A80
[26426.615562] EtherCAT 0: Domain 0: Working counter changed to 2/3
[26426.615563] .
[26426.624924] EtherCAT ERROR 0-1: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[26426.628937] EtherCAT ERROR 0-1: AL status message 0x001E: "Invalid input configuration".
[26426.636965] EtherCAT 0-1: Acknowledged state PREOP.
[26426.640979] EtherCAT 0: Slave states on main device: PREOP, OP.
[26427.619539] EtherCAT 0: Domain 0: Working counter changed to 0/3
[26339.861154] .
[26385.002622] .
[26426.608884]
[26426.608885]
[26426.608886]
[26426.608887]
[26426.608888]
[26426.608889]
[26426.608893]
[26426.615563] .
Warning: Spoiler!
[27501.146205] EtherCAT: Requesting master 0...
[27501.146208] EtherCAT: Successfully requested master 0.
[27501.146353] EtherCAT 0: Domain0: Logical address 0x00000000, 7 byte, expected working counter 3.
[27501.146355] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 7 byte, type LRW.
[27501.150380] EtherCAT 0: Master thread exited.
[27501.150383] EtherCAT 0: Starting EtherCAT-OP thread.
[27501.150465] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[27501.471524] EtherCAT ERROR 0-1: SDO download 0x8003 (151 bytes) aborted.
[27501.471529] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[27501.471531] EtherCAT ERROR 0-1: SDO configuration failed.
[27501.475541] EtherCAT 0: Slave states on main device: PREOP, OP.
Greetings
Conny
Last edit: 6 years 8 months ago by JimPanski.
6 years 8 months ago #158739
by JimPanski
Hi Chimeno,
Do you happen to have the such a EL6751 device available? I am asking because I am not getting any furher because I dont know what else i can also try.
So far I could find that "plopes9000" had likely the same issue (seen here at the ethercat thread ) but sadly no solution was posted
Greetings
Conny
Greetings
Conny
6 years 8 months ago - 6 years 8 months ago #158811
by chimeno
Replied by chimeno on topic Ethercat with EL6751 CanOpen Master and JAT Servo Drives
Hi @Conny,
Chimeno
I do not have this device, I never use it, I can not help you much about this, although you can try to scan through the WIRESHARK program the data transmission that TWINCAT performs and see what is happening and replicate it in Linux, you can also publish it and look at it.Do you happen to have the such a EL6751 device available?
Chimeno
Last edit: 6 years 8 months ago by chimeno.
6 years 8 months ago #158948
by JimPanski
Hi Chimeno,
thanks for your offer. I will try to wireshark asap.
Do you think that may help If you have such a EL6751 and maybe one servo drive at hand? If you are interested I can provide both devices to you.
In the meantime I hope I can reach to plopes and try to get some hints.
Thank you very much!
Conny
Conny
6 years 7 months ago - 6 years 7 months ago #159156
by chimeno
Hi @Conny
if you are lucky and you can solve it,
I enclose a simpler V2 version that might work
greeting
Chimeno
If I had them, it would be helpful, of course, although I think we are quite far away, I attach a new file to see if you have any progress, since the TWINCAT3 project that you passed me is not available, can you see if this data is correct?Do you think that may help If you have such a EL6751 and maybe one servo drive at hand? If you are interested I can provide both devices to you.
<sdoConfig idx="1c12" subIdx="complete">
<sdoDataRaw data="01 00 00 16"/>
</sdoConfig>
<sdoConfig idx="1c13" subIdx="complete">
<sdoDataRaw data="02 00 00 1A 80 1A"/>
</sdoConfig>
greeting
Chimeno
Last edit: 6 years 7 months ago by chimeno.
6 years 7 months ago - 6 years 7 months ago #159206
by JimPanski
Hi Chimeno,
first of all I was asking if you have those devices because I got a second set op it here wich I could maybe share if you are interested.
I tried you configs with no luck
EDIT: I am honestly not sure about index 1c13
thank you very much!
Greetings
Conny
Warning: Spoiler!
[ 966.439702] EtherCAT: Requesting master 0...
[ 966.439705] EtherCAT: Successfully requested master 0.
[ 966.439833] EtherCAT 0: Domain0: Logical address 0x00000000, 7 byte, expected working counter 3.
[ 966.439835] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 7 byte, type LRW.
[ 966.442961] EtherCAT 0: Master thread exited.
[ 966.442965] EtherCAT 0: Starting EtherCAT-OP thread.
[ 966.443031] EtherCAT WARNING 0: 1 datagram UNMATCHED!
[ 966.767726] EtherCAT ERROR 0-1: SDO download 0x8003 (151 bytes) aborted.
[ 966.767731] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[ 966.767733] EtherCAT ERROR 0-1: SDO configuration failed.
[ 966.771742] EtherCAT 0: Slave states on main device: PREOP, OP.
Greetings
Conny
Last edit: 6 years 7 months ago by JimPanski. Reason: added content
