- Thank you received: 4153
Ethercat installation from repositories - how to step by step
3 years 2 months ago #277459
Replied by rodw on topic Ethercat installation from repositories - how to step by step
I would suggest a normal x86 PC with 4 cores, 4 GB RAM (eg Celeron J1900 or above). I3 and I5 seem OK too
My 16 core i7 on my desk is way over the top
- Thank you received: 7491
3 years 2 months ago #277462
Replied by tommylight on topic Ethercat installation from repositories - how to step by step
16 core i7 ???
- Psylocke
- Thank you received: 3
3 years 2 months ago #277464
by Psylocke
Replied by Psylocke on topic Ethercat installation from repositories - how to step by step
3 years 2 months ago #277486
All I wanted to do was get rid of Windows!
I think technically its 8 core, 16 threads but it reports in with 16 on linux (including in htop). Frightened me!16 core i7 ???
3 years 2 months ago #277488
Oh an 10700, that has 8 P cores and 8 E cores, meaning 8 performance and 8 efficient cores.
That was just another Intel f@k up as for a while those 8E cores could not be used under Windows and caused stability issues, lasted nearly a full year till they figured out how to use those.
Not that they do much anyway, but they do help a bit.
I have gone full AMD several years back, will not buy Intel ever again.
They (and AMD not being able to compete for quite a while) single handily retarded PC advancement for nearly 20 years.
For anyone wanting to rant about this, don't, just have a look how far have graphic chips gone in that time frame.
- buzzFab
3 years 2 months ago - 3 years 2 months ago #277499
by buzzFab
Rod, Thanks for the update. I am trying again from the start on a i7 hp g2 mini. I have come across an error while compiling
I read the part you wrote "becasue you have not installed halcompile (in shipped in linuxcnc-uspace-dev)" but I for sure installed linuxcnc-uspace-dev. As you can see from the error, there is trouble finding ecrt.h even though the find command shows the file here /usr/src/ethercat-dkms-1.5.2/include/ecrt.h.
***EDIT... I forgot mention that i did try the spoiler and it didnt change anything also i tried adding a symbolic link with this line but the error is still the same
Do you know where i should go from here?
thanks
Replied by buzzFab on topic Ethercat installation from repositories - how to step by step
UPDATE: The first post has been updated following upstream changes. It also covers addidional steps required to build DKMS drivers if you have Secure boot (UEFI) enabled on your PC.
cnc@cnc:~/dev/linuxcnc-ethercat$ sudo make install
make[1]: Entering directory '/home/cnc/dev/linuxcnc-ethercat/src'
mkdir -p /usr/lib/linuxcnc/modules
make[2]: Entering directory '/home/cnc/dev/linuxcnc-ethercat/src'
gcc -o lcec_conf.o -Os -g -I. -I/build/linuxcnc-vf7ZID/linuxcnc-2.9.0~pre1+git20230208.f1270d6ed7/src/include -DUSPACE -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -DSIM -fPIC -URTAPI -U__MODULE__ -DULAPI -Os -c lcec_conf.c
In file included from lcec_conf.c:31:
lcec_conf.h:22:10: fatal error: ecrt.h: No such file or directory
22 | #include "ecrt.h"
compilation terminated.
make[2]: *** [user.mk:22: lcec_conf.o] Error 1
make[2]: Leaving directory '/home/cnc/dev/linuxcnc-ethercat/src'
make[1]: *** [Makefile:11: install] Error 2
make[1]: Leaving directory '/home/cnc/dev/linuxcnc-ethercat/src'
make: *** [Makefile:11: install] Error 2
cnc@cnc:~/dev/linuxcnc-ethercat$ sudo find / -name "ecrt.h"
find: ‘/run/user/1000/doc’: Permission denied
sudo ln -s /usr/src/ethercat-dkms-1.5.2/include/
thanks
Last edit: 3 years 2 months ago by buzzFab.
Time to create page: 2.373 seconds
