- Thank you received: 29
Ethercat installation from repositories - how to step by step
- TangentAudio
3 years 5 months ago - 3 years 5 months ago #272089
by TangentAudio
Replied by TangentAudio on topic Ethercat installation from repositories - how to step by step
Has anyone managed to get the Ethercat kernel modules/driver to build against a 6.3 or 6.4 kernel? I installed Bookworm on my test bench setup yesterday, and got everything (LinuxCNC + Ethercat Master + lcec) working fine with the 6.1 kernel, with nice stable latency numbers. Out of curiosity I tried the 6.4 and 6.3 kernels made available in various threads on the forums here, but the kernel modules don't seem to build properly.
I have only tried the 'easy' path as outlined in this thread, I haven't gone through the lengths of trying to do everything by hand.
edit: Here's a pastebin for the failed install/build step.
pastebin.com/raw/VxZ5vRnX
Last edit: 3 years 5 months ago by TangentAudio.
- TangentAudio
3 years 5 months ago - 3 years 5 months ago #272092
by TangentAudio
Looks like there have been some changes since 6.3 around access to vm_flags, per
lwn.net/Articles/921359/
In short, there are now access functions for modifying vm_flags which must be used instead of modifying it directly.
A patch to ethercat-dkms/1.5.2/build/master/cdev.c similar to this should help fix it for newer kernels and retain compatibility with older ones. Note, this isn't a real patch, just roughly what needs to be done.
+#if LINUX_VERSION_CODE < KERNEL_VERSION(6, 3, 0)
+static inline void vm_flags_set(struct vm_area_struct *vma, vm_flags_t flags)
+ vma->vm_flags |= flags;
+static inline void vm_flags_clear(struct vm_area_struct *vma, vm_flags_t flags)
+ vma->vm_flags &= ~flags;
+#endif
- vma->vm_flags |= VM_DONTDUMP;
+ vm_flags_set(vma, VM_DONTDUMP);
- Thank you received: 4153
3 years 5 months ago #272101
Replied by rodw on topic Ethercat installation from repositories - how to step by step
I think there has been a recent commit to the Igh code that fixes this. But it may not have got to their repo.
Build etherlabmaster from their source probably will work
The following user(s) said Thank You: TangentAudio
- CORBETT
- Thank you received: 113
3 years 5 months ago - 3 years 5 months ago #272311
by CORBETT
Replied by CORBETT on topic Ethercat installation from repositories - how to step by step
@ 0x2102
Markus, that is awesome to hear, as I was worried it may be a future problem... will be checking that out down the road. Thanks for the feedback!
@Rod Webster
First, Awesome that you and Roguish worked on the probing as that is what I am wanting to check out with Dragon. I have a Renishaw probe from one of our previous Monarch VMC's that I am planning to use... just need time to implement.
Second, Awesome again with you and CM doing the bug work and getting it ready. I always like to thank everyone that makes this all happen with LCNC as without everyone like you and the others doing the work, then this wouldn't happen and keep advancing. Just awesome how far it has came in the last 10 years especially.
Yeah I knew you would have already been running bullseye with Ecat, heck I figured you would have bookworm or trixie working as you are always on top of things.
I have looked at Seb's buildbot in the past, but it's been awhile. LOL, your not cheating.. we all don't have enough time as it is and that is a good way to save time advancing. I have too many projects also... plus, I have another little project that I'm going to waste some time on this weekend (already have since Friday night). I have 4 Beckhoff CX5020 PLC's with Atom 1.6, 512Mb DDR2, and CF HDD's, so these are not fast, but they do work. Back in 2015 I put Wheezy w/ XFCE, LCNC 2.6 RTAI, and Ecat on and they work. I get a realtime error at LCNC startup, but after that they do not error at all and can run NGC code through for hours... I have this weekend off and I am going to do a expert build from debian 11 with nothing but the base system, no GUI and no Utilities get the OS working with a stripped out panel using LXQT-core and see if I can get LCNC 2.9 to work. I had it working on a Dell Optiplex 9020 last night, so I'm going to try the PLC next. I previously tried the PLC with the debian net install and XFCE, but it would hang when trying to start the GUI. I know this is somewhat possible, as I did it with Wheezy and LCNC2.6, but then again debian and LCNC have advanced. The debian 11 specs call for 512mb of RAM w/o a GUI and 2GB with, so I know I am close to EOL if not already. Plus, these were just test setups and play stuff as I only had 1 of them mounted in a machine. I had LXQT-core and SDDM stripped down to just 195 packages total with "no-recommends" but it was acting a little unstable. It runs fine with the regular core install with all 667 packages, but I will figure it out. Back then I liked the small footprint of the PLC and it was DIN mounted, but finally the Optiplex Micro's have become affordable on Ebay and haven't worried about these in years. Just figured I would update these since moving everything else up.
@Rod Webster
Last edit: 3 years 5 months ago by CORBETT. Reason: spelling
3 years 5 months ago #272314
Thanks. Corbett. I suspect a 32 bit PC might struggle today.
I don't know the first thing about it but perhaps RTAI might work for you if you can match the kernel. and lcnc version
github.com/NTULINUX/RTAI/releases/tag/v5.3.3-delta
3 years 4 months ago - 3 years 4 months ago #273752
Just a heads up that if you do an upgrade of a Bookworm environment, the kernel will likely change and break your config. The reason this happens is the debs have been installed into a specific kernel and therefore you need to install to the right kernel. dkms is meant to look after this but it does not seem to do it.
So if it breaks after an upgrade, first remove the existing debs
And follow the sticky again. You can probably skip the bit about creating keys and you will probably already have the EtherCAT repo in your sources.list file.
Be sure to install linux-headers again for your new kernel.
I got an error when attempting to start the EtherCAT service. This was resolved by typing
sudo apt-get remove ethercat-dkms libethercat libethercat-dev ethercat-master
sudo apt install depmod
sudo depmod
Last edit: 3 years 4 months ago by rodw.
The following user(s) said Thank You: mra7768
Time to create page: 7.826 seconds
