- Thank you received: 4153
Ethercat installation from repositories - how to step by step
3 years 5 months ago - 3 years 5 months ago #271056
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Great feedback. I guess it will be merged shortly. In the meantime, you could checkout the fix_vm_set_flags branch
Also overnight the PREEMPT_RT team released the v6.3.1-rt13 patch set which is now available at kernel.org
They say this will be back ported to 6.1 if it works out.
I might try and build 6.3.1
Last edit: 3 years 5 months ago by rodw.
- CORBETT
- Thank you received: 113
3 years 5 months ago #271073
by CORBETT
Replied by CORBETT on topic Ethercat installation from repositories - how to step by step
Rod,
Yep Yep, just cloned the git repo, built and installed. When I say compile, I am simply referring to the process as before Andreas put up the repository you could only get ethercat by doing EC-Debianize or compile the IgH code. Back when I did it on Wheezy it was mercurial not git, but still same basic principle... but yeah, I have put it on a couple of times since the last post and it is rock solid... it's up every time, no having to restart the service.
Yeah, I am not referring to true compiling from scratch. Everything is much easier now... when I was a teen in late 80's I had to learn UNIX for my father's company server (Texas Instruments, 286 architecture, monochrome monitors, no hdd, tape only, and a whopping 15K of RAM... Kilobytes not Mega, our cost $22,000; UNIX was $6,000 alone)... I hated it, felt there should be an easier way (GUI with point & click), but now glad that I went through that hell. I can halfway get around in Linux, but Linux is not UNIX. I am not a programmer or developer, only picked up the manuals and figured out how to operate the thing. Today is much easier as you can get on the internet and find out how things work, back then it was pure hell to get things working. I can remember when we received our IBM XT with twin 5-1/4 floppies, it was a huge step up with the floppies alone as got rid of the tape. Even though 5-1/4 floppies were bigger in physical size to a 3-1/2, it still was way smaller than that huge tape. What is funny back then is that there were computer courses for just learning how to send email as it wasn't easy at all. I remember the most complicated thing to do in the day was to add a video card, you didn't have anything on the monitor as the card hadn't been installed yet, so you would have to write out all the commands and do everything in order perfectly and then when you rebooted, hoped that you saw something on the monitor (monochrome green letters LOL= Login at:). I don't miss any of it at all, what a lot of work back then just to have a payroll server.
I am impressed with how far things have advanced... in the 90's I use to cream over a Pentium II 333 Slot1 chip LOL. Even LCNC has came a long way since back in the early 2000's with EMC (I still have my EMC BDI disc & EMC2 disc). I am truly impressed with QTDRAGON-HD as that really makes LCNC look like a high quality control at this point. Even Norbert's Gmoccapy was impressive way back when, but Persei has built something really beautiful with Dragon. I love open source and what all of this has evolved into, just awesome. Just never enough time to do all that is available now...
3 years 5 months ago #271074
It seems like Igh just dropped the Bookworm repo but they are still making the debs on their buildbot. You just need to login with google to get access. I suspect it is something to do with the later kernels. The days of the PREEMPT_RT patch are numbered. That will be awesome when its all in mainline...
I remember those days. At college our mainframe gave each terminal 11k and we programmed in basic. Sometimes we'd enter the data using mark sense cards and a pencil.. Then they bought a couple of Apple II pcs with 48k of Ram and 170 k floppy....... I remember paying $1k for a 40 Mb HDD.Rod,
The following user(s) said Thank You: CORBETT
- CORBETT
3 years 5 months ago #271709
by CORBETT
@ 0x2102
How did Kernel 6.3 work. I had seen on John Thornton's site that latency was problematic after 5.10 with using Ethernet on Mesa cards, so I wasn't sure if that would affect EtherCAT as well.
@ Rod Webster
Ouch, so you felt the pain also , yeah I am glad things have gotten affordable. Speaking of HDD's, I can't remember what year it was, but we picked up a 4Gb drive and I remember telling my Dad: "We will never fill it up" LOL LOL LOL, well I was completely wrong... Yeah, Texas Instruments sent Basic with the computer, I never did get deep into it as I was just trying to get around Unix alone, but I do remember doing a few of the simple little programs in basic on a commodore computer back in the mid 80's right before we got the TI server.
Yeah I still haven't checked out the DEB's as I am still overloaded with work and don't have time to tinker... I'm really under the gun now.
But, since I last posted and over last weekend, I have built 8 complete systems using Bullseye, with LCNC 2.9 RIP, IgH EtherCAT build, Sasha's Driver, Touchscreen with Dragon_HD GUI all working without issues, fires right up everytime. I have gotten the builds down pat to the point that not having to do any work arounds for anything other than the realtime.mk fix. Didn't do the Mutex fix, but don't think that is needed anymore since RTAI was dropped by Sasha. I am going to look at the realtime.mk fix a little bit more when I have time. Just copied what Stormholt had. Even have the libethercat.so linked correctly so that it works out of the box without editing the /.profile. I'm setting them up like I have the current 2.8 deployment at each machine so that when you turn on the disconnect to the machine it will automatically fire up LCNC with Dragon. That way no one has to do anything but start work. I still have more HAL to write but wanted to make sure E-cat worked with Dragon, and simply did a couple of pins to make sure. The only thing I have left is figuring out how to have a NGC file load automatically like you would in Axis. I tried the same way as Axis under the [DISPLAY] section and adding OPEN_FILE = /full/path/to/filename.ngc but it didn't work like Axis does. Plus Jim and/or Chris Morley may not have it set up to work. When I have time, I'm going to post on the qtvcp section to find out. I simply want the current production job to load so that a basic machine operator can go right to work without screwing around wasting time. Right at the moment that machine operator is me LOL LOL LOL.
I just made a quick setup in HAL using a EL7041 and stepper as a spindle motor. I am checking out [SPINDLE] code as it was implemented in 2.9, plus a few other things I wanted to look at. I was pretty content as was using AXIS with Devils Pie, so it made a nice full screen... but after
seeing Jim's Dragon_HD GUI, I was impressed and decided to step up to Bullseye & 2.9... plus I need to keep somewhat updated. (I still
had one of them running wheezy with 2.7).
@ Rod Webster
3 years 5 months ago #271719
Yes, I have Ethercat, RS485 controlled VFD and QTdragon with Bullseye too.
Myself and Roguish have done a lot of testing of the probing so it's pretty clean now
Cmorley also worked with me to build a panel which is now an extra panel now available in the core code after we found quite a few bugs.
So all I all, I think it's ready for prime time!
I've been cheating and grabbing updated Debs from Seb''s secret buildbot to keep current.
buildbot2.highlab.com/
- 0x2102
- Thank you received: 88
3 years 5 months ago #271735
by 0x2102
so far so good. The 6.x kernel's network stack (compared to 5.x) seems to be vastly improved. I have had no issues so far with regard to latency (Mesa and EtherCAT) - which I am both testing. I am able to run up to 4 kHz Servo Thread (Mesa and EtherCAT).
Replied by 0x2102 on topic Ethercat installation from repositories - how to step by step
Hi Robert,@ 0x2102
The following user(s) said Thank You: CORBETT, xwhatsit
Time to create page: 4.542 seconds
