Ethercat installation from repositories - how to step by step
3 years 9 months ago #263213 by rodw
Please read the error. It says to Look at line 66 in your xml...
3 years 9 months ago #263218 by akg1904
Hi Rodw,
Thank you..
I figure it out.
Regards
Abhishek
3 years 9 months ago #263225 by akg1904
Hi Rodw,
I have mapped my halpins in "ethercat_conf.xml" according to your module and referencing ESI.xml file of my drive
For .hal file I mostly followed your .hal file example.
Thus, now my linuxcnc is Opening but when I tried to jog my servo drive to shows "Joint following error"
Can you  point me in a direction where I can figure out would is the Problem and hopefully debug it.
for reference I have attached my modified ethercat_conf.xml file and pre-gui.hal file is already attached below
File Name: ethercat-c...1-30.xml
File Size:5 KB
Regards
Abhishek
3 years 9 months ago #263227 by rodw
A following error happens when the encoder position exceeds the commanded position by allowable limits.
Its possibly because the scale is not correct in your xml file (eg say you move 10mm but the encoder only registers 5mm)
Or your sevo is not yet tuned.
There are some settings in your ini  file that relax the limists in your ini file You could make them big units until you get it tuned.
FERROR = 200
MIN_FERROR = 50
Also check if you rotate the motor by hand, does the encoder count? Is the encoder countung the right way?
3 years 9 months ago #263234 by akg1904
Hi Rodw,
I tried rotating the motor by hand and looked at the reading at DRO scale for axis for distance but there was no change.
I think this is what you mean by checking encoder count?
Or is there any other way to check the encoder count?
but there is some blink in seven segment led in drive when I rotate the motor.
Regards
Abhishek
3 years 9 months ago #263265 by rodw
Sounds like you have got something wrong in your wiring or config.
Please raise a seperate thread and share you config files xml, ini and hal.
Time to create page: 0.255 seconds
