Ethercat installation from repositories - how to step by step
3 years 6 months ago #268509 by dineshann63
i have inovance ethercad servo drive and i have a xml file also . i need details for communication and control with 2axes lathe.
3 years 6 months ago #268511 by dineshann63
I am having inovance ethercad servo drive and  xml file. How to communicate and Linuxcnc and AM401 inovance plc it is motion control plc they have ethercad communication also. To run a 2axes lathe.
3 years 6 months ago #268554 by rodw
Linuxcnc is the motion controller. You don't need two motion controllers. I don't think we can help. Your question is off topic. Please raise another thread.
  • Frustrated Toolpaths
  • New Member
  • New Member
3 years 6 months ago - 3 years 6 months ago #268666 by Frustrated Toolpaths
Replied by Frustrated Toolpaths on topic Ethercat installation from repositories - how to step by step
Probably the wrong place to post this but those in the knowledge of EtherCAT may see it here!..
My Question:-
I have a perfectly good Parallel port system that has been running for years on Wheezy with LinuxCNC 2.8 (I know...I know...but it works perfectly) Now I would like to ruin it with a 4th axis (5th joint) running on a Ethercat Driver..
Can any of you think of a reason this won't work?
If this looks viable I will start a new thread to document my progress for anyone that wants to upgrade a good Parallel port (G540) system with extra functionality.
Edit: I Should RTFM... new plan, testing on a separate PC with debian 10, so I don't mess up my  wheezy install.
Running through the how to....one question...when is an appropriate time to plug in the hardware?
Last edit: 3 years 6 months ago by Frustrated Toolpaths. Reason: RTFM
3 years 5 months ago #270410 by mehdidadash
is there any way that we can select e1000e as DEVICE_MODULES using this method you introduced ?
3 years 5 months ago #270419 by rodw
The e1000e is a network interface and has nothing to do with ethercat. If that the NIC you use for ethercat, just use it's MAC address.
Time to create page: 0.262 seconds
