- Thank you received: 4153
Ethercat installation from repositories - how to step by step
4 years 4 weeks ago #253300
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Yes, the ethercat packages install without error so it should be fine to follow my last post. Let us know how you get on and I'll try and updat the first post
- sqmathlete
- Thank you received: 18
4 years 4 weeks ago #253301
by sqmathlete
Replied by sqmathlete on topic Ethercat installation from repositories - how to step by step
Well, now I am really confused. I have tried to follow those instructions several times.
Step 1) create an empty file in /etc/apt/sources.list.d
STEP 2)copy and paste the keyring
deb [trusted=yes]
download.opensuse.org/repositories/home:.../EtherLab/Debian_10/
./[/code]
spits out
KEYRING=/usr/share/keyrings/ethercat.gpg && curl -fsSL https://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_10/Release.key | gpg --dearmor | sudo tee "$KEYRING" >/dev/null
Step 3) Add this line to the etherlab.list file in /etc/apt/sources.list.d
sudo apt update
spits out
- sqmathlete
4 years 4 weeks ago #253304
by sqmathlete
One thought, can this part be done with the wget command?
4 years 4 weeks ago #253307
I got this:
I saw the W; on the GPG error so decided it was just a warning and pressed on. It seemed to work and it crated the ethercat drivers ec_* in the right folder.
But I did do
first just in case
od@penguin:/usr/share/keyrings$ sudo apt update
Hit:1 https://deb.debian.org/debian bullseye InRelease
Hit:2 https://deb.debian.org/debian bullseye-updates InRelease
Hit:3 https://deb.debian.org/debian-security bullseye-security InRelease
Ign:4 https://storage.googleapis.com/cros-packages/108 bullseye InRelease
Hit:5 https://storage.googleapis.com/cros-packages/108 bullseye Release
Get:6 http://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_10 ./ InRelease [1,339 B]
Ign:6 http://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_10 ./ InRelease
Fetched 1,339 B in 1s (946 B/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
48 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: GPG error: http://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_10 ./ InRelease: The following signatures were invalid: B1C282D9C181FD2DC684D6A1A08216C4FF0D8EF7
But I did do
sudo rm ethercat.gpg
- sqmathlete
4 years 3 weeks ago #253476
by sqmathlete
Hi Rod,
I've got things sorted out. I hate to admit but I think I must have copied the install line along with ip a (find the MAC address) DUH!
The only edit to the instructions I would suggest is to add cd linuxcnc-ethercat before running the make, make clean commands. Other than that flawless. Well done!
Dan
Dan
4 years 4 days ago #255263
The first post has been updated to incorporate additional steps mentioned in subsequent posts.
However, please check I got it right!
The following user(s) said Thank You: tommylight, uur.ersan
Time to create page: 0.832 seconds
