- Thank you received: 12
Start from the beginning (in reply to your first post)
If I power the drives up with the CAT/Network cable disconnected between drive 1 and 2 (aka drive 2 and 3 not linked to the master), load LinuxCNC, then connect the CAT cable (so drives 2 and 3 are now connected/linked to the master), drives 2 and 3 get configured and can be enabled and controlled by LinuxCNC (I can jog the Y and Z axis), but drive 1 still does nothing.
Added those for each slave, and all the drives now intialise and activate when LCNC is opened.<syncManager idx="0" dir="out">
</syncManager>
<syncManager idx="1" dir="in">
</syncManager>
This configures the drive to 4000mA current, and reads the digital inputs to a halPin.<slave idx="0" type="generic" vid="00000a79" pid="00001000" configPdos="true">
<!-- Lichuan CL£-E57H -->
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<sdoConfig idx="2303" subIdx="00"> <!-- Peak Current -->
<sdoDataRaw data="a0 0f" />
</sdoConfig>
</syncManager>
</syncManager>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
<pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1a00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
<pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
<pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
<pdoEntry idx="6077" subIdx="00" bitLen="16" halPin="actual-torque" halType="u32"/>
<pdoEntry idx="60fd" subIdx="00" bitLen="32" halPin="digital-inputs" halType="u32"/>
</pdo>
</syncManager>
</slave>
