Custom EtherCAT device
3 years 5 months ago #271734 by Tady
Replied by Tady on topic Custom EtherCAT device
Interesting.. A votage to frequency converter. I fix CNC plasma machines at work and no technology like this is used. Only voltage to voltage isolators. The older machines have an independant height control ( IHT ). And the newer have everything integrated. But the isolators are still the same.
No I didn't try anything out, we have some birthdays this weekend so maybe I can do a little bit in the evening. But still thank you for the example XML
I was looking in the LinuxCNC docs for different data taypes. S32,REAL,.... Is there any oher datatype? S16 or S8,... And unsigned versions?
3 years 5 months ago #271737 by pippin88
Replied by pippin88 on topic Custom EtherCAT device
I am interested to hear your progress.
I'm also keen for better and cheaper ethercat IO options.
I did just come across www.mikroe.com/ethercat-click for the first time (which I searched LAN9252). Have not come across it before in many searches for the cheapest way to get ethercat / ethercat for MCU
3 years 5 months ago #271738 by rodw
Replied by rodw on topic Custom EtherCAT device
This is Linuxcnc!
QTplasmac should hold its own against your integrated systems, possibly exceed. The $70 Mesa THCAD2/5/10's  are built for the dirty plasma environment and can handle 500 volt over voltage indefinitely. They are individually calibrated and are connected to an encoder input on a  Mesa card. Linuxcnc converts the frequency in software and controls the torch height internally.
Here is a walkthrough I did
And the cut recovery features
Data types are described in the docs here  linuxcnc.org/docs/2.9/html/hal/comp.html
  • TYPE - One of the HAL types: bit, signed, unsigned, or float. The old names s32 and u32 may also be used, but signed and unsigned are preferred.
I think the xml uses S32 and and U32
The following user(s) said Thank You: Tady
3 years 5 months ago #271739 by Tady
The ethercat click is the same thing as mine. But this one seems to use only one port.. Ethercat that i have seen uses two so you can dasy chain them together. You could use a switch to connect them, but the default topology is dasy chaining.. Also these slaves don't use any addressing, the physical position in the chain provides the "address"
3 years 5 months ago #271758 by pippin88
The pictures are a bit confusing. There are two ethernet ports - they are stacked vertically.
3 years 5 months ago #271760 by andypugh
Replied by andypugh on topic Custom EtherCAT device
V to F is an effective way to interface an analogue signal with the digital control system. There are other ways to do it, but as most LinuxCNC systems have the possibility to count encoder pulses, and not all have any analogue input capability, it's a sensible choice.
Time to create page: 0.397 seconds
