EtherCAT System Implementation of JMC Ethercat Servos
2 years 9 months ago #289867 by udoS
@ all
And I hope needless to say,
it can be done with a RPi4+ ; :-)
Have Fun
2 years 7 months ago - 2 years 7 months ago #295520 by Smitherman
Hello @rodw ,
took me some time to get back here.
I now have installed the newest version of LCNC with your description of the installation with Ethercat from repositories.
Everything worked well until the implementation of the CIA402 devices.
For your info: the JMC drive is CIA402 compatible but i really dont understand the next steps. For me to build up a working machine.
What showed up in the moment when I am searching for slaves are EK1100 and also the drives, but also want to implement an Ethercat VFD from Lusintun and really have Problems understanding the connection between setting up a machine with the correct HAL, XML and Ini files.
I tried to follow your description of implementing CIA402 drives but that didnt worked out for me
Hope you can help
Last edit: 2 years 7 months ago by Smitherman.
2 years 7 months ago #295566 by rodw
I can't really help but here is my config for cia402 devices
github.com/rodw-au/linuxcnc-cia402
2 years 7 months ago - 2 years 7 months ago #295573 by 0x2102
@Smitherman, are you from Germany? I might be able to assist.
Last edit: 2 years 7 months ago by 0x2102.
The following user(s) said Thank You: Smitherman
2 years 7 months ago #296248 by Smitherman
With the help of 0x2102 and a video of Metalmusings (
), I got the JMC drive into OP status. Tomorrow I will post my momentary XML file. The only problem I am facing right now is the Hal file, which I must say I don't really understand how to set up correctly
2 years 7 months ago #296290 by Smitherman
So here are the 3 files, which brings the Servo into Op State. Next strep would be to customize the Hal file. But i do not know exactly where to start....
Time to create page: 0.438 seconds
