What do i need exactly for ethercat ? Recommended hardware??
1 year 2 months ago #333959 by BipinBabu
Sir,
New guy here..!
Thanks for those precious lessons.!!!
  The latest Linux version with Realtime kernel is available as a bootable image on the official site right?
Once I install the OS, Can I directly go for Ethercat Configuration?
I am planning to Use EL7 -400W Ethercat Servo Drive from Leadshine with 23Bit magnetic Encoder.
I hope the ESI File of the Servo drive gives me the encoder Counts per revolution????
I set them Up in INI file right?
How does the "LinuxCNC-HAL ----INI----Ethercat
Servo" Drive RelationShip Toplology work?
Traditionally ,I write in the "INI" File that , My servo Drive encoder needs 8million/5=1.6million encoder Counts for a millimeter of travel.
(Because My servo Drive encoder needs 8million counts for every revolution.And my ballscrew travels 5mm at full revolution of the servo)
What happens next?
The INI file sends instruction for  1.6 million counts for 1 millimeter on X axis  if I say G0 X1 in Gcode.
There is no such detailed videos on YT  either..!
Thanks.
1 year 2 months ago #333960 by BipinBabu
The Ethercat Master For Linuxcnc is not an executable file. It says We need to patch and Compile based on our application. ! What are the variables that may vary mainly? Not universal at all? (Looking For a traditional 3 Axis Wood router with Dual Y Motor.)
1 year 2 months ago #333975 by Hakan
Maybe start with a fresh install of the latest debian "trixie". Linuxcnc is available as an apt package directly, just sudo apt install linuxcnc-uspace and so on forum.linuxcnc.org/9-installing-linuxcnc...ade-install-to-2-9-4
Ethercat needs to be installed after that, follow the guides here first  forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories and then  forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Ethercat server consists of two kernel modules, run in kernel space that linuxcnc communicates with.
Linuxcnc uses traditional HAL files for configuration. Translation between HAL pins and EtherCAT PDOs is provided by the linuxcnc lcec module which requires a configuration file "ethercat-config.xml". Often a source of questions, the easiest way to generate a good starting point is the Linux command "lcec_configgen". Reference for linuxcnc-ethercat (lcec) can be found github.com/linuxcnc-ethercat/linuxcnc-ethercat but it seems not many people read it.
Your servo drives seems to use the common cia402 drive profile. A must read is the example config found at github.com/dbraun1981/hal-cia402 .
There is no easy (well...) way to configure an Ethercat machine. Typically you start with a sample configuration from the LinuxCNC simulator or generate a configuration using either stepconf or pncconf and then replace the motion and IO pins with the Ethercat motion and IO pins from ethercat-conf.xml.
Regarding the encoder resolution, there is a scaling number one need to provide, counts/mm or counts/inch, check the cia402 example hal file. After that, the cia402 module reports position directly in mm or inch in the pos-fb pin.
The following user(s) said Thank You: BipinBabu, Pontus
1 year 1 month ago #334417 by BipinBabu
Wow.! Thank you for the deep explanation.! Let me try that. Because I am no fan of step/dir method which is unreliable and prone to many isues like EMI. Since Ethercat is free and Ethercat Based servos have become relatively inexpensive. I am going to give a shot.
11 months 3 weeks ago #337877 by Gogonfa
Hi GuiHue,
that sounds really interesting!
I’m using three 1 kW Delta B3M servos on my machine and would like to make the system fully closed-loop by adding linear encoders to the axes. I’m still quite new to LinuxCNC and currently trying to understand how to build my machine configuration file and how to connect all the inputs and outputs from the Beckhoff DI/DO modules. My previous controller was an EDING CNC760 with Step/Puls and no encoder support...
What should I pay special attention to, and where would you recommend I start?
Also, which encoders are you using on your axes?
Best regards,
Michael
Time to create page: 0.180 seconds
