Ethercat PDO/SDO Configuration error
- jc2ktr
- Thank you received: 17
13 Feb 2024 21:17 #293263
by jc2ktr
Ethercat PDO/SDO Configuration error was created by jc2ktr
Hello, I'm currently trying to get my Rexroth HCS01 servo controller to work with Ethercat COE.
I was also able to create a generic XML.
but unfortunately my init configuration does not work as desired.
the init.xml was first created from dbraun1981 in this thread
ethercat-hal-driver page 112
when i start my Machine this error messages are appearing.
i don´t understand why it is not working anymore?
- scottlaird
- Thank you received: 161
14 Feb 2024 02:06 #293288
by scottlaird
Replied by scottlaird on topic Ethercat PDO/SDO Configuration error
When did it last work, and what's changed since then? Did you upgrade the linuxcnc-ethercat software since it last worked? Have the XML files changed?
Can you exit LinuxCNC, run `sudo dmesg -C`, restart LinuxCNC, and then share what `sudo dmesg` says?
- jc2ktr
14 Feb 2024 05:50 - 14 Feb 2024 21:14 #293297
by jc2ktr
Replied by jc2ktr on topic Ethercat PDO/SDO Configuration error
Hi thanks for the quick reply, i got the output of sudo dmesg -C this is the section with the Ethercat output, i put the complete .txt as attachment.
The last time it worked was in 2021 and yes since then a new computer/hardware was needed and a complete fresh Linuxcnc/ethercat install was done, but the machine configuration is nearly the same.
But as i got my scaling at that time not tuned to move the right distances i discarded the EtherCAT COE Setup and Configured the Drives with EtherCAT SOE, but this was never reliable enough. and had often bus failures.
I´ve updated the Drives Firmware today to FWA-INDRV_-MPB-21V16-D5_FD
and updated the EtherCAT Master to EtherCAT: Master driver 1.5.2 1.5.2.429.g3079ece-1+378.1
- Sven
Warning: Spoiler![ 6.165874] ec_generic: EtherCAT master generic Ethernet device module 1.5.2 1.5.2.413.g1ace2f4-1+320.1
[ 6.165888] EtherCAT: Accepting 6C:4B:90:CD:99:1D as main device for master 0.
[ 6.165900] ec_generic: Binding socket to interface 2 (enp3s0f0).
[ 6.200887] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 6.201038] EtherCAT 0: Link state of ecm0 changed to UP.
[ 6.211331] mt76x2u 2-3.1:1.0: ASIC revision: 76120044
[ 6.264152] usb 2-3.3: 3:1: cannot get freq at ep 0x86
[ 6.285462] mt76x2u 2-3.1:1.0: firmware: direct-loading firmware mt7662_rom_patch.bin
[ 6.285470] mt76x2u 2-3.1:1.0: ROM patch build: 20141115060606a
[ 6.371376] process '/usr/bin/anydesk' started with executable stack
[ 6.398803] NET: Registered PF_QIPCRTR protocol family
[ 6.426185] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.426188] Bluetooth: BNEP filters: protocol multicast
[ 6.426193] Bluetooth: BNEP socket layer initialized
[ 6.469502] mt76x2u 2-3.1:1.0: firmware: direct-loading firmware mt7662.bin
[ 6.469510] mt76x2u 2-3.1:1.0: Firmware Version: 0.0.00
[ 6.469512] mt76x2u 2-3.1:1.0: Build: 1
[ 6.469514] mt76x2u 2-3.1:1.0: Build Time: 201507311614____
[ 6.520415] usb 2-3.3: 3:2: cannot get freq at ep 0x86
[ 6.606950] Bluetooth: hci0: RTL: fw version 0xffb8abd3
[ 6.743166] Bluetooth: MGMT ver 1.22
[ 6.747051] NET: Registered PF_ALG protocol family
[ 6.776286] usb 2-3.3: 3:3: cannot get freq at ep 0x86
[ 6.844365] EtherCAT 0: Link state of ecm0 changed to DOWN.
[ 6.872371] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 7.072623] r8169 0000:03:00.0 enp3s0f0: rtl_ep_ocp_read_cond == 0 (loop: 10, delay: 10000).
[ 7.220695] r8169 0000:03:00.0 enp3s0f0: Link is Down
[ 7.842571] usb 2-3.3: Warning! Unlikely big volume range (=3896), cval->res is probably wrong.
[ 7.842575] usb 2-3.3: [7] FU [Mic Capture Volume] ch = 1, val = 200/4096/1
[ 7.842761] usbcore: registered new interface driver snd-usb-audio
[ 7.847757] usb 2-3.3: Found UVC 1.00 device FHD Camera Microphone (1bcf:28c4)
[ 7.905787] usb 2-3.3: Failed to query (GET_INFO) UVC control 12 on unit 1: -32 (exp. 1).
[ 7.916409] usb 2-3.3: Failed to query (GET_INFO) UVC control 14 on unit 1: -32 (exp. 1).
[ 7.943404] input: FHD Camera Microphone: FHD Came as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb2/2-3/2-3.3/2-3.3:1.0/input/input17
[ 7.943482] usbcore: registered new interface driver uvcvideo
[ 8.219868] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[ 8.220646] usbcore: registered new interface driver mt76x2u
[ 8.562019] mt76x2u 2-3.1:1.0 wlxe84e0640c5e3: renamed from wlan0
[ 8.612306] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.809203] r8169 0000:03:00.0 enp3s0f0: Link is Up - 100Mbps/Full - flow control off
[ 8.816390] EtherCAT 0: Link state of ecm0 changed to UP.
[ 9.203941] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0f0: link becomes ready
[ 9.220372] EtherCAT 0: 1 slave(s) responding on main device.
[ 9.220378] EtherCAT 0: Slave states on main device: INIT.
[ 9.220451] EtherCAT 0: Scanning bus.
[ 9.291893] Bluetooth: RFCOMM TTY layer initialized
[ 9.291914] Bluetooth: RFCOMM socket layer initialized
[ 9.291942] Bluetooth: RFCOMM ver 1.11
[ 9.659920] usb 2-3.3: Failed to query (GET_DEF) UVC control 12 on unit 1: -32 (exp. 3).
[ 9.667150] usb 2-3.3: Failed to query (GET_DEF) UVC control 12 on unit 1: -32 (exp. 3).
[ 9.916655] EtherCAT 0: Bus scanning completed in 696 ms.
[ 9.916663] EtherCAT 0: Using slave 0 as DC reference clock.
[ 9.916666] EtherCAT ERROR 0: Failed to calculate bus topology.
[ 9.916668] EtherCAT 0: Starting EoE thread.
[ 9.928362] EtherCAT 0: Slave states on main device: PREOP.
[ 10.540366] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 10.540394] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[ 10.542365] EtherCAT 0-0: Acknowledged state PREOP.
[ 10.543287] eoe: port 1(eoe0a20) entered blocking state
[ 10.543308] eoe: port 1(eoe0a20) entered disabled state
[ 10.543385] device eoe0a20 entered promiscuous mode
[ 10.543430] eoe: port 1(eoe0a20) entered blocking state
[ 10.543432] eoe: port 1(eoe0a20) entered listening state
[ 14.616032] wlp2s0: authenticate with c8:0e:14:1c:0b:0f
[ 15.117937] wlp2s0: send auth to c8:0e:14:1c:0b:0f (try 1/3)
[ 15.437201] wlp2s0: authenticate with c8:0e:14:1c:0b:0f
[ 15.437250] wlp2s0: send auth to c8:0e:14:1c:0b:0f (try 1/3)
[ 15.562189] wlp2s0: authenticated
[ 15.564387] wlp2s0: associate with c8:0e:14:1c:0b:0f (try 1/3)
[ 15.568698] wlp2s0: RX AssocResp from c8:0e:14:1c:0b:0f (capab=0x1511 status=0 aid=4)
[ 15.569018] wlp2s0: associated
[ 15.622552] wlp2s0: Limiting TX power to 20 (23 - 3) dBm as advertised by c8:0e:14:1c:0b:0f
[ 15.760499] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 15.962540] usb 2-3.3: Failed to query (GET_DEF) UVC control 12 on unit 1: -32 (exp. 3).
[ 15.976291] usb 2-3.3: Failed to query (GET_DEF) UVC control 12 on unit 1: -32 (exp. 3).
[ 19.668220] wlxe84e0640c5e3: authenticate with c8:0e:14:1c:0b:0f
[ 19.758208] wlxe84e0640c5e3: send auth to c8:0e:14:1c:0b:0f (try 1/3)
[ 20.061034] wlxe84e0640c5e3: authenticate with c8:0e:14:1c:0b:0f
[ 20.061040] wlxe84e0640c5e3: send auth to c8:0e:14:1c:0b:0f (try 1/3)
[ 20.201663] wlxe84e0640c5e3: authenticated
[ 20.204416] wlxe84e0640c5e3: associate with c8:0e:14:1c:0b:0f (try 1/3)
[ 20.207717] wlxe84e0640c5e3: RX AssocResp from c8:0e:14:1c:0b:0f (capab=0x1511 status=0 aid=5)
[ 20.225449] wlxe84e0640c5e3: associated
[ 20.230635] wlxe84e0640c5e3: Limiting TX power to 20 (23 - 3) dBm as advertised by c8:0e:14:1c:0b:0f
[ 20.316481] IPv6: ADDRCONF(NETDEV_CHANGE): wlxe84e0640c5e3: link becomes ready
[ 25.632359] eoe: port 1(eoe0a20) entered learning state
[ 40.740361] eoe: port 1(eoe0a20) entered forwarding state
[ 40.740365] eoe: topology change detected, propagating
[ 40.740420] IPv6: ADDRCONF(NETDEV_CHANGE): eoe: link becomes ready
[ 53.324226] EtherCAT: Requesting master 0...
[ 53.324230] EtherCAT: Successfully requested master 0.
[ 53.351403] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.363206] EtherCAT WARNING 0-0: Other mailbox protocol response for eoe0a20.
[ 53.363255] EtherCAT ERROR 0-0: Reception of CoE upload response failed: No response.
[ 53.363258] EtherCAT ERROR 0-0: Failed to read number of mapped PDO entries.
[ 53.363259] EtherCAT WARNING 0-0: Failed to read PDO entries for PDO 0x1600.
[ 53.363261] EtherCAT ERROR 0-0: Reception of CoE download response failed: No response.
[ 53.363263] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 53.374491] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.374830] EtherCAT ERROR 0-0: Reception of CoE download response failed: No response.
[ 53.374833] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 53.379385] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.385626] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.386832] EtherCAT ERROR 0-0: Received unknown response while uploading SDO 0x1A00:00.
[ 53.386834] EtherCAT DEBUG: 00 30 60 00 1A 03 00 00 00 00
[ 53.386838] EtherCAT ERROR 0-0: Failed to read number of mapped PDO entries.
[ 53.386839] EtherCAT WARNING 0-0: Failed to read PDO entries for PDO 0x1A00.
[ 53.409295] EtherCAT ERROR 0-0: SDO download 0x1A00:00 (1 bytes) aborted.
[ 53.409299] EtherCAT ERROR 0-0: SDO abort message 0x06020000: "This object does not exist in the object directory".
[ 53.409301] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 53.413694] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.419305] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.425049] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 53.425093] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[ 53.426826] EtherCAT WARNING 0-0: Aborting SDO request, slave has error flag set.
[ 53.427054] EtherCAT 0-0: Acknowledged state PREOP.
[ 53.504378] EtherCAT ERROR 0-0: SDO download 0x1600:00 (1 bytes) aborted.
[ 53.504382] EtherCAT ERROR 0-0: SDO abort message 0x06020000: "This object does not exist in the object directory".
[ 53.504383] EtherCAT ERROR 0-0: Failed to process SDO request.
[ 53.548715] EtherCAT 0: Domain0: Logical address 0x00000000, 12 byte, expected working counter 3.
[ 53.548718] EtherCAT 0: Datagram domain0-0-main: Logical offset 0x00000000, 12 byte, type LRW.
[ 53.548728] EtherCAT 0: Master thread exited.
[ 53.548731] EtherCAT 0: Stopping EoE thread.
[ 53.548766] EtherCAT 0: EoE thread exited.
[ 53.548766] EtherCAT 0: Starting EoE thread.
[ 53.548810] EtherCAT 0: Starting EtherCAT-OP thread.
[ 53.548832] EtherCAT WARNING 0: 126 datagrams TIMED OUT!
[ 53.700957] EtherCAT WARNING 0-0: No sending response for eoe0a20 after 100 tries.
[ 53.744415] EtherCAT ERROR 0-0: Mailbox error response received - Unknown error reply code 0x0000.
[ 53.744420] EtherCAT WARNING 0-0: Invalid mailbox response for eoe0a20.
[ 53.780421] EtherCAT ERROR 0-0: Mailbox error response received - Unknown error reply code 0x0000.
[ 53.780426] EtherCAT WARNING 0-0: Invalid mailbox response for eoe0a20.
[ 53.828417] EtherCAT ERROR 0-0: Mailbox error response received - Unknown error reply code 0x0000.
[ 53.828421] EtherCAT WARNING 0-0: Invalid mailbox response for eoe0a20.
[ 55.356040] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 55.356382] EtherCAT ERROR 0-0: AL status message 0x0001: "Unspecified error".
[ 55.362030] EtherCAT 0-0: Acknowledged state PREOP.
[ 57.560367] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 58.564366] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 64.584368] EtherCAT WARNING 0: 6 datagrams UNMATCHED!
[ 68.600367] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 69.604367] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 69.960366] usb 2-3.2.4: new high-speed USB device number 10 using xhci_hcd
[ 70.174835] usb 2-3.2.4: New USB device found, idVendor=0781, idProduct=5567, bcdDevice= 1.00
[ 70.174840] usb 2-3.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 70.174842] usb 2-3.2.4: Product: Cruzer Blade
[ 70.174843] usb 2-3.2.4: Manufacturer: SanDisk
[ 70.174844] usb 2-3.2.4: SerialNumber: 04020123060821233409
[ 70.201293] usb-storage 2-3.2.4:1.0: USB Mass Storage device detected
[ 70.201451] scsi host1: usb-storage 2-3.2.4:1.0
[ 70.201544] usbcore: registered new interface driver usb-storage
[ 70.205350] usbcore: registered new interface driver uas
[ 71.237429] scsi 1:0:0:0: Direct-Access SanDisk Cruzer Blade 1.00 PQ: 0 ANSI: 6
[ 71.243122] scsi 1:0:0:0: Attached scsi generic sg0 type 0
[ 71.246886] sd 1:0:0:0: [sda] 60088320 512-byte logical blocks: (30.8 GB/28.7 GiB)
[ 71.248012] sd 1:0:0:0: [sda] Write Protect is off
[ 71.248015] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 71.248389] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 71.271733] sda: sda1
[ 71.271880] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 71.487236] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 72.612369] EtherCAT WARNING 0: 4 datagrams UNMATCHED!
[ 73.616361] EtherCAT WARNING 0: 8 datagrams UNMATCHED!
[ 74.616359] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 76.624361] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 78.632364] EtherCAT WARNING 0: 2 datagrams UNMATCHED!
[ 85.232552] wlp2s0: disconnect from AP c8:0e:14:1c:0b:0f for new auth to c8:0e:14:1c:0b:0e
[ 85.324940] wlp2s0: authenticate with c8:0e:14:1c:0b:0e
[ 85.324970] wlp2s0: 80 MHz not supported, disabling VHT
[ 85.845912] wlp2s0: send auth to c8:0e:14:1c:0b:0e (try 1/3)
[ 86.168173] wlp2s0: authenticate with c8:0e:14:1c:0b:0e
[ 86.168220] wlp2s0: send auth to c8:0e:14:1c:0b:0e (try 1/3)
[ 86.288629] wlp2s0: authenticated
[ 86.292361] wlp2s0: associate with c8:0e:14:1c:0b:0e (try 1/3)
[ 86.299133] wlp2s0: RX ReassocResp from c8:0e:14:1c:0b:0e (capab=0x1031 status=0 aid=9)
[ 86.299331] wlp2s0: associated
[ 86.990720] wlp2s0: Limiting TX power to 20 (20 - 0) dBm as advertised by c8:0e:14:1c:0b:0e
Last edit: 14 Feb 2024 21:14 by jc2ktr. Reason: added text
Time to create page: 0.096 seconds
