- Thank you received: 38
Hello, thanks for sharing your configuration. I took a quick look and there is one thing I don't quite understand
net x-output <= cia402.2.velocity-cmd
net x-output <= pid.x.output
Is the direction above reversed? It should be
net x-output => cia402.2.velocity-cmd
This is given by:pitch of your ballsrews / Number of Encoder pulses per revolution.
In this case I would guess:
2^23 / 5 = 1677721.6
i.e. this tells you how many encoder pulses you get per physical movement of your machine.
This would foe example be for an sfu2005 ball screw with a 23bit encoder (23bit = 2^23 = 8388608)
(I'm pretty new to all of this so please correct me if I'm wrong)
you can do it like thisloadrt flipflop names=flip-is-on
addf flip-is-on servo-thread
net is-on halui.machine.is-on => flip-is-on.set
net is-on-reset motion.is-all-homed => flip-is-on.reset
net go-home flip-is-on.out => halui.home-all
I wanna see this actually moving a machine. Interesting about the CSV/CSP, but I think it makes sense in relation to what someone else said in another thread, that you are getting the reported position one frame late, so it always appears to lag, even though it "isn't".
