Yes, I can assemble everything I need using Beckhoff modules, but it will be very expensive.You need el5102 module with two encoder interfaces, one for spindle and one for handwheel AB phase
Could you please write the name and model? There is no product at the link.I think this would be a good I/O module but you would need to create the generic xml which is not hard There may be an xml file here somewhere.
www.aliexpress.com/item/1005004377766525.html
