EtherCAT i/o board for spindle, estop and mpg
- Thank you received: 4153
05 Aug 2024 22:04 #307039
Replied by rodw on topic EtherCAT i/o board for spindle, estop and mpg
Odd, it looks like the A+, A-, B+, B- and 5 volt power is provided for a motor encoder
- onceloved
- Thank you received: 59
06 Aug 2024 10:40 #307068
by onceloved
Replied by onceloved on topic EtherCAT i/o board for spindle, estop and mpg
However, it outputs the count value and has no direction. The encoder forward counter value increases, and the encoder reverse counter value also increases instead of decreasing.
- avive
06 Aug 2024 12:44 #307078
by avive
In this video, the man controls the position of the axes through the counter. He does it through the arduino, but I think it's not so important and it's about the right connection.
Replied by avive on topic EtherCAT i/o board for spindle, estop and mpg
07 Aug 2024 00:09 #307131
Seems odd
0x2020 (or 0x2040 depending on where you look) shows a signed 32 bit integer for encoder.
I was able to translate the manual into English with Google Translate
drive.google.com/file/d/1GwtOZH0HaHGVrvv...SEO/view?usp=sharing
Seems odd
The following user(s) said Thank You: avive
- onceloved
07 Aug 2024 03:41 #307137
by onceloved
07 Aug 2024 07:28 #307152
But it adds additional expense and complexity.
I am tempted to get one of these to play with it. Once I finish the mesa control box I am working on...
But I like ethercatMy suggestion is to give up ecat-io and look for other solutions, such as mesa card or fpga or arduino (I don't know how fast they are
- onceloved
07 Aug 2024 08:19 #307155
by onceloved
My servo driver uses ethercat and my io uses rv901 fpga card. They both work well together on Orange Pi 5 Plus.
- avive
07 Aug 2024 08:45 #307159
by avive
aliexpress.ru/item/1005007068086214.html
It is also single-board inside.
Tell me, please, was it difficult to configure EtherCAT on Orange Pi 5 Plus and is the performance sufficient? I want to use the computer not only to run Gcode, but also to develop my interface.
I was afraid to deal with relatively new architectures and ordered a mini PC on a six-core AMD processor:My servo driver uses ethercat and my io uses rv901 fpga card. They both work well together on Orange Pi 5 Plus.
07 Aug 2024 08:50 #307160
I have a small retrofitted machine with Ethercat drives and a Rtelligent I/O module. I added an encoder on the spindle but nothing to connect it to. Swapping it put for one of these would solve that problem. I'd also like to try an Ethercat VFD on it too.My servo driver uses ethercat and my io uses rv901 fpga card. They both work well together on Orange Pi 5 Plus.
- onceloved
07 Aug 2024 10:05 #307166
by onceloved
Orange Pi 5 Plus has better performance than Raspberry Pi 5, but its ecosystem is not as good as Raspberry Pi. Ethercat is easy to install. You can check it out forum.linuxcnc.org/18-computer/48079-can...-to-run-lcnc?start=0
Time to create page: 0.355 seconds
