Hello again everyone. Thank you all for your responses and for letting me know I shouldn't waste my time with RTAI.
I believe I have managed to solve the latency errors and am now at the next roadblock..
I had previously passed
isolcpus=1 to grub as a kernel parameter, however I read up more and realized that was incorrect. LinuxCNC uses the last core for realtime processes from what I understand. I changed that to
isolcpus=2,3 (extra core helped even more) and the latency is in my opinion very good now. <10k on idle and no more than 55k even with 20 instances of glxgears open (I should have tried glxspheres too, but I'm not sure how to install it on Debian). I let it run for quite a bit and there were also no random spikes to speak of.
Now the issue I will look into is a random
"joint X following error" or a "joint X amplifier fault" (it is a seemingly random joint from 0-4 each time) at weird times. I had previously also been getting this error, however I neglected to mention that as I thought it was all due to the latency. Sometimes this will occur as my test program is running, but the weird thing is that it also happens as the machine is idle. Even more strangely, one time the program conducted successfully with no issues and immediately as it ended the joint following error appeared. All of this leads me to rule out the latency being problematic now after I improved it - I doubt the latency would "wait" for the program to finish before it caught up.
I also tested the same machine on another small fairly modern i3 >3GHz PC (the onboard one is around 1.2GHz) just to be sure. Same situation.
Only now that I look into it, do I think to focus on the word "following" in the following error. The .ini file does have an
FERROR variable which the previous colleague has set to 0.5 all across and
MIN_FERROR to 0.05.
I am going to spend the day reading the
wiki page on the "Following Error"
and making sense of it. In the first paragraph it says we can be almost certain this error implies a mistake in the .ini. I thought I'd post this beforehand to give an update and to let you kind folks know not to bother with the RTAI line of thinking anymore.
I am attaching my .ini once again just in case someone may have the time to point me in the right direction.
Also, since my issues have moved rather out of scope of the EtherCAT forum subsection, do let me know if I should make another post in a different section.
PS. Neglected to mention that the maximum velocity of the configuration is
6000mm/min. Interestingly, I have the impression that it works much better at lower velocities in the 2-3k range, which should additionally point to the FERROR not being configured properly. I can't conclude it for certain since my test program is rather long and I haven't had the time to extensively test it at even lower speeds.
