Installing ethercat repositories
- NickH
- Thank you received: 4
07 Jan 2026 19:33 - 07 Jan 2026 19:34 #341139
by NickH
Replied by NickH on topic Installing ethercat repositories
Tntmold: I think you have to build LinuxCNC from source for an Ethercat install, then build Ethercat master. It will not work from the downloaded ISO file.
Build from a Debian13 Netinstall(or full) image.
Last edit: 07 Jan 2026 19:34 by NickH. Reason: Sp
- Thank you received: 7488
07 Jan 2026 19:41 #341140
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
Replied by tommylight on topic Installing ethercat repositories
It does work, RodW did a lot of work for that to workIt will not work from the downloaded ISO file.
The following user(s) said Thank You: NickH
- NickH
07 Jan 2026 19:49 #341142
by NickH
I stand corrected, and somewhat outdated!
- Thank you received: 4151
07 Jan 2026 22:50 #341146
Replied by rodw on topic Installing ethercat repositories
There are still some reasons why its necessary to build the Ethercat master from source which is pretty easy anyway. In that case, go to the etherlab site, get their source and read their instructions in the PDF instructions
etherlab.org/en_GB/ethercat
@NIckH, the Etherlab repository also hosts the latest Ethercat hal driver thanks to Scott Laird. So it is possible to install everything without building anything!
- low79fx
28 May 2026 12:43 #346703
by low79fx
Replied by low79fx on topic Installing ethercat repositories
Hello, First of my name is Samuel and I am completely new to the whole Linux enviroment but want to learn the process. I am experiencing some issues that I can go through whole setup process and everything is fine but the whole thing falls apart only when the sudo apt update followed by sudo apt upgrade messes everything up. And by evertyhing I mean I lose my link to mac address and some dependenciy files fail to complete and are left unconfigured.
What am i doing wrong I've MrRodW install and SZolkaa install and get the same result.
Below is what is not completing. Thanks again.
dpkg: error processing package linux-headers-rt-amd64 (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
linux-image-6.12.86+deb13-rt-amd64
linux-image-rt-amd64
linux-headers-6.12.86+deb13-rt-amd64
Error: Sub-process /usr/bin/dpkg returned an error code (1)
28 May 2026 15:08 #346704
That is not the issue, it is the result of the issue, see if there is "raspi" mentioned in the error report.
The following user(s) said Thank You: low79fx
28 May 2026 23:46 #346718
I suspect its an EFI issue installing dkms. EFI/Secure boot prevents untrusted things from modifying the kernel and dkms does exactly that.
There is a spoiler in the very first post about how to fix this where you tell EFI that dkms can be trusted. Alternatively, consider disabling secure boot in the BIOS
Kernel 6.12 is Debian Trixie and thankfully Debian fixed the Raspi issue on its release, so its not the issue.That is not the issue, it is the result of the issue, see if there is "raspi" mentioned in the error report.
- low79fx
29 May 2026 11:56 - 06 Jun 2026 11:36 #346731
by low79fx
Last edit: 06 Jun 2026 11:36 by low79fx.
- Fr3nzy
28 Jun 2026 14:48 - 28 Jun 2026 14:52 #347370
by Fr3nzy
Replied by Fr3nzy on topic Installing ethercat repositories
Hello dear,
mokutil --sb-state says that EFI variables are not supported on this system. And it doesnt want to install linuxcnc-ethercat. The same dpkg error is shown. I do not know what to do...
Last edit: 28 Jun 2026 14:52 by Fr3nzy.
28 Jun 2026 19:16 #347374
Try enabling UEFI in BIOS.
Time to create page: 0.139 seconds
