Installing ethercat repositories
- Fr3nzy
My motherboard is very old and doesn't support UEFI. Maybe I should use one that will support it.Try enabling UEFI in BIOS.
- tuxcnc
- Thank you received: 45
This is common kernels RT problem (efivars disabled in config).
The solution is to add "efi=runtime" to the kernel parameters (once at boot or to /etc/default/grub).
- tuxcnc
You have the right to have a computer museum, but do not require anyone to help you maintain it.
- Fr3nzy
"efi=runtime" is added and the same "EFI variables are not supported on this system" error appears.The "EFI variables are not supported on this system" has nothing to do with BIOS setup.
- Fr3nzy
Would you suggest a hardware that is guaranteed to work with the latest repositories and EtherCAT?
- tuxcnc
Some second hand computer after leasing.Would you suggest a hardware that is guaranteed to work with the latest repositories and EtherCAT?
I use for ethercat HP 705 G3 AMD Radeon R7 A10-8770.
It is not newest, but small and powerfull.
In my opinion, you can buy very good computer for LinuxCNC for 50-100 USD.
- Fr3nzy
Error: Failed to fetch www.linuxcnc.org/dists/trixie/2.9-uspace...pace_2.9.9_amd64.deb 404 Not Found [IP: 69.163.143.134 443]
Error: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Why is that happening?
The good thing is that I managed to install the ethercat. But I used another computer with UEFI for the purpose.
Thank you very much in advance!
- Thank you received: 2164
- Fr3nzy
- Thank you received: 4144
