Ethercat auto configurator.
1 year 11 months ago #315585 by Grotius
Replied by Grotius on topic Ethercat auto configurator.
@Kworm,
I think the current code is able to setup connections for input's and output's for all kind of ethercat devices.
Not all data type's are integrated yet. 1,8,16,64 bit data type is integrated. But there are more types.
It's just following a digital "ethercat xml" structure. From there it creates pdo's. The actual xml structure in
the core code is a complexer struct :
~/realtime_app/src/vendor/ethercat_master/tool/common.h
struct ethercat_entry_data {     ec_ioctl_slave_sync_pdo_entry_t entry;     ethercat_data_type data_type; }; // Pdo entry's of a pdo. struct ethercat_pdo_data {     ec_ioctl_slave_sync_pdo_t pdo;     ethercat_pdo_type pdoType;     std::vector<ethercat_entry_data> entry_vec; }; // Pdo's of a sync. struct ethercat_sync_data {     ec_ioctl_slave_sync_t sync;     std::vector<ethercat_pdo_data> pdo_vec; }; // Device and sync's struct ethercat_device_data {     ec_ioctl_slave_t slave;     std::vector<ethercat_sync_data> sync_vec;     unsigned int offset;     unsigned int bit_position; };
It setup's 1 bit, 8 bit, 16 bit, 64 bit value's and start adress for input and outputs.
There is no typical driver code for a certain servo drive.
If code is expanded, it can match a xml product code to use a certain servo driver setup.  This is
like linuxcnc-ethercat
If i had a servo here, i certainly would test it out. image missing /media/kunena/emoticons/smile.png
My goal so far was to be able to interact with ethercat-master using a auto configurator.
This was quite a bit off work to get that done.
In that process i got some insights how automate this process for linuxcnc.
The following user(s) said Thank You: endian, kworm
1 year 11 months ago - 1 year 11 months ago #315664 by kworm
Replied by kworm on topic Ethercat auto configurator.
@Grotius,
I was suggesting you would need ESI support if you wanted to be able to avoid having to have special code for specific devices like linuxcnc-ethercat does. Ie, if you were wanting it to work something like twincat or other commercial products do.
@Endian,
Have you seen any issues on ethercat with the current position dropping to zero intermittently...noticed on the DRO? I've been attempting to use LCNC on a machine that has G1 acceleration of 1m/s and G0 acceleration of 3m/s (feed is 25-50m/min) and I keep getting following errors.
Last edit: 1 year 11 months ago by kworm. Reason: Correct acceleration and feed
1 year 11 months ago #315681 by endian
Replied by endian on topic Ethercat auto configurator.
@Grotius,
@Endian,
Which mode U are running? If U run them in the
  • CSP - U have to tune your servos for your application ...
  • CSV - U have to tune your PIDs and servos too for your appication ...
For ethercat control is lcnc only a trajectory planner such as realtime "position sender" where to go and all control stuff as positioning corrections accel. and deccel. or velocity servo calculates internally ... they are 1st and 2nd derivations of position and ethercat interface of servo has tools to calculate them..
bdw .. I have stuff which has this control loop at 250us but should be faster as siemens DriveCliq S120 drivers which are running at 31.25us
1 year 11 months ago #315685 by kworm
They are running in CSP mode and servos have been tuned. They work fine with 2000us control loop with TwinCAT CNC with the same config. I don't mean to hijack Grotius thread just thought I would see if you had seen this.
1 year 11 months ago #315686 by endian
You have not SDO config out of lcnc .. check setup of PDO 60C2 index 2 and 3 ... It has to be setup in your ethercat-conf.xml file .. probably you has wrong timing for sure.. it should happend because of free run of PLC and there is SDO download which are overwriting them
Try to find my old post with s300 kollmorgen xml setup .. there they are 60C2s with 1ms values
The following user(s) said Thank You: kworm
1 year 10 months ago - 1 year 10 months ago #315766 by fake_name
All links in the OP are broken.
Why on earth does something to configure ethercat require the entirety of OpenCascade?
Last edit: 1 year 10 months ago by fake_name.
The following user(s) said Thank You: Salame
Time to create page: 0.386 seconds
