StepperOnline A6 Servo
1 year 8 months ago - 1 year 8 months ago #320456 by bananun
Replied by bananun on topic StepperOnline A6 Servo
MobiusToast wrote: Super cool, I just purchased the same servos/drivers for my mill conversion. This thread will be really useful once I get them and can start setting them up. Regarding tuning, I believe you can just use leadshine's motion studio software as they show it being used to configure the T6 servo in one of their videos (
). Like many of their products, I believe they are licensing leadshine's tech.
For the cabinet, are you planning on using 1 contactor and line filter per motor as is shown in the manual or 1 of each for the entire cabinet?
The A6 are allegedly rebranded Inovance sv660N and not Leadshine as the T6. Might work anyways though!
EDIT: Motion studio seems to only work with RS232...
Last edit: 1 year 8 months ago by bananun.
1 year 8 months ago #320459 by dschultz
Replied by dschultz on topic StepperOnline A6 Servo
I'm using a single contactor for all 4 drives and at this point I don't have a filter installed, however after doing some research, I will probably add a single one sized for all drives.
1 year 8 months ago #320952 by vizavadsky
Replied by vizavadsky on topic StepperOnline A6 Servo
I'm new here and have same servo so decide to try your setup files. I was not able to achieve success with your files like MWalz did.
Maybe you can help me? Here is my output:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
Machine configuration directory is '/home/cnc/linuxcnc/configs/v2xt'
Machine configuration file is 'EtherCat_2025-01-13.ini'
INIFILE=/home/cnc/linuxcnc/configs/v2xt/EtherCat_2025-01-13.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X
KINEMATICS=trivkins coordinates=X kinstype=BOTH
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
Found file(REL): ./Basic.hal
Starting DISPLAY program: axis
Running HAL shutdown script
task: 126 cycles, min=0.000004, max=0.013546, avg=0.008413, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
Note: Using POSIX realtime
note: MAXV max: 250.000 units/sec 15000.000 units/min
note: LJOG max: 250.000 units/sec 15000.000 units/min
note: LJOG default: 5.000 units/sec 300.000 units/min
note: jog_order='X'
note: jog_invert=set()
Could not open command file 'custom_postgui.hal'
Could not open command file 'shutdown.hal'
101766
101796
Stopping realtime threads
Unloading hal components
1 year 8 months ago #320989 by tommylight
Replied by tommylight on topic StepperOnline A6 Servo
Edit the ini file and omit those two lines then try again, usually they are not used.
The following user(s) said Thank You: vizavadsky
1 year 8 months ago #321030 by vizavadsky
Thank you. I made onother step towards spinning this motor because of that for sure!
I thing I got my XML wrong now.
Slaves:
cnc@raspberrypi:~/dev/hal-cia402$ ethercat slaves
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL1008 8K. Dig. Eingang 24V, 3ms
2 0:2 PREOP + EL2008 8K. Dig. Ausgang 24V, 0.5A
3 0:3 PREOP + AS715N_sAxis_V0.10
XML I got from MWalz but I changed slave idx from 0 to 3
I'm not sure but it is looks like logical thing to me.
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<slave idx="3" type="generic" vid="00400000" pid="00000715" configPdos="true" name="A6">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="25000"/>
<watchdog divider="2498" intervals="1000"/>
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="control-word" halType="u32"/>
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
<pdoEntry idx="60B8" subIdx="00" bitLen="16" halPin="touch-probe-function" halType="u32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1A00">
<pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="status-word" halType="u32"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="pos-actual" halType="s32"/>
<pdoEntry idx="60BA" subIdx="00" bitLen="32" halPin="touch-probe-1" halType="s32"/>
<pdoEntry idx="60BC" subIdx="00" bitLen="32" halPin="touch-probe-2" halType="s32"/>
<pdoEntry idx="60B9" subIdx="00" bitLen="16" halPin="touch-probe-status" halType="s32"/>
<pdoEntry idx="603F" subIdx="00" bitLen="16" halPin="fault-code" halType="s32"/>
<pdoEntry idx="60FD" subIdx="00" bitLen="32" halPin="DI-status" halType="u32"/>
<pdoEntry idx="60F4" subIdx="00" bitLen="32" halPin="follow-error" halType="s32"/>
</pdo>
</syncManager>
</slave>
</master>
</masters>
And I got this report
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X
HAL: ERROR: duplicate component name 'lcec_conf'
lcec_conf: ERROR: hal_init failed
./Basic.hal:6: waitpid failed lcec_conf lcec_conf
./Basic.hal:6: lcec_conf exited without becoming ready
6928
Should I change something in Basic.hal or this is my XML wrong?
Will appreciate any help guys.
1 year 8 months ago #321034 by tommylight
6928
Delete or omit (by adding # in front of it) the line trying to load lcec twice.
Time to create page: 0.688 seconds
