- Thank you received: 4153
Yes, it is confusing. I tried to use joint.N.is_custom-homing to trigger the cia402 homing input but hal complained about the pin type so had to add a pin of type IO (joint.N.start-homing). I think I could sense homing is done when it is set to zero. But I am getting ahead of myselfI'm not surprised I misinterpreted the intent of that pin. The current state of in-drive homing code and documentation makes it a bit of an "adventure!"
