StepperOnline A6 Servo
9 months 2 weeks ago #341354 by dschultz
Replied by dschultz on topic StepperOnline A6 Servo
It has been very stable other then an occasional following error when I home.
I'm still using standard homing, guess I haven't taken the time to pursue the absolute encoder instant homing.
Only time that I had a racking issue was when one of my Y homing sensors went bad and the other side of the gantry kept going...
9 months 2 weeks ago #341383 by andrax
Replied by andrax on topic StepperOnline A6 Servo
Well, I can't recommend the servo reference run!
The problem is that it is not monitored. If an axis does not move, Linuxcnc does not notice. It happened to me again today. During homing, a Y-axis does not start moving, even though I waited until all axes were OP.
I will switch back to Linuxcnc homing.
It's a pity that the servos do not output the Z signal.
9 months 2 weeks ago - 9 months 2 weeks ago #341439 by TAKUYA
Replied by TAKUYA on topic StepperOnline A6 Servo
@mobiusToast
Did you have any issues with the Drives sometimes not homing at all? Or them jumping at the end of the home procedure with ER87?
Last edit: 9 months 2 weeks ago by TAKUYA. Reason: tag user
9 months 2 weeks ago #341456 by andrax
Hello,
since my problems persist and one Y-axis does not move during homing, and I don't give up so easily, I tried “dmesg” and “ethercat slaves -v” again.I see two errors in the output:[  459.958251] EtherCAT WARNING 0-1: Slave did not sync after 5000 ms.[   13.362825] EtherCAT ERROR 1: Failed to calculate bus topology.Otherwise, everything is OK and the drives go to OP.Where could the problem be?I also don't understand why I have to turn off the servos and Linuxcnc and restart them for homing to work.
9 months 2 weeks ago #341460 by tommylight
Replied by tommylight on topic StepperOnline A6 Servo
I would try using a new LAN cable, preferably CAT6
The following user(s) said Thank You: andrax
9 months 2 weeks ago #341474 by andrax
I use cat5e 1m and 0.25m.
Is that the problem?
Time to create page: 0.240 seconds
