StepperOnline A6 Servo
9 months 2 weeks ago #341481 by tommylight
Replied by tommylight on topic StepperOnline A6 Servo
Usually no, but i had new cables not work properly, occasionally.
The following user(s) said Thank You: andrax
9 months 1 week ago #341613 by andrax
Replied by andrax on topic StepperOnline A6 Servo
Yes, you were right.
It was EMC problems.
I have now purchased CAT6 cables and made sure that no loops form. The error EtherCAT WARNING 0-1: Slave did not sync after 5000 ms has disappeared and I am currently having no problems with the Y-axis.
Thank you very much for the tip.
9 months 1 week ago #341646 by TAKUYA
Replied by TAKUYA on topic StepperOnline A6 Servo
In the meantime, I was testing around with the HOME_ABSOLUTE_ENCODER = 2 setting in axis SIM. It turns out that there might be a positional accuracy issue when homing. Ive created a github Issue for it already. It seems like its reading the joint position and not the encoder position when setting the new home so on re-home, it shifts the axis location in software by your home-offset value while hardware remains the same.
9 months 1 week ago #341775 by andrax
What did you use for noise filters on the servos?
I can't find any information anywhere.
9 months 1 week ago #341800 by tommylight
Ferrite beads on the motor wires near the drive are usually a must, and having an LC filter on the mains side never hurts.
9 months 1 week ago #341897 by andrax
Hi, I have now made some changes and am not experiencing any more problems for the time being.
1. I had Ethercat running on two network cards.
I have now combined them into one card and made sure that it has an Intel chip.
2. I have made the following changes in ethercat.xml:
appTimePeriod="1000000" >>> appTimePeriod="2000000"
sync0Shift=“25000” >>> sync0Shift="50000"
Since then, the errors have disappeared and the servos are ready immediately.
3. I have attached ferrite cores to the Ethercat cables.
The ferrite cores for the servos have been ordered.
The following user(s) said Thank You: NWE
Time to create page: 0.400 seconds
