StepperOnline A6 Servo
7 months 2 weeks ago #344491 by tommylight
Replied by tommylight on topic StepperOnline A6 Servo
Inside the Basic.hal file, you have trivkins called twice as noted in the error report
"trivkins: already exists"
7 months 1 week ago #344518 by Spezidrohne
Replied by Spezidrohne on topic StepperOnline A6 Servo
Thanks for the reply, but im still too dumb to integrate just these files. It just won't work. Can anyone guide me through this? What doch i have to do with these files? All i have done so far is to create a sample from the Premiere Samples and put the 3 files into the folder. Should i even call the Basic.hal from the axis.ini file? What am i doing wrong?
7 months 1 week ago #344532 by andrax
Replied by andrax on topic StepperOnline A6 Servo
Okay, first step: read through the entire thread.
I know there are a lot of pages, but you’ll find a wealth of information here.
Then, step by step.
First, what’s what:
>>> ethercat.xml
provides the information for the LinuxCNC EtherCAT driver (lcnc) – mappings of the signals and registers of the servos to the pins in LinuxCNC
>>> your config.hal
Calls to the LinuxCNC components and internal connections within LinuxCNC
>>> your config.ini
General configuration
Setup
1. Connect the servos and troubleshoot issues
> dmesg | grep ethercat asl root
There shouldn’t be any errors here; if there are, you have EMC issues
2. List connected devices
> ethercat slaves
3. Create ethercat.xml
Study the existing templates in this thread
If you don’t understand something, just ask
3. Create your config.hal
Here, too, simply use the existing templates.
Most of the time, you won’t need to change much.
4. Create your config.ini
Here, you’ll need to read through the LinuxCNC documentation.
The configuration is specific to your machine’s setup.
Again, make sure to familiarize yourself with the individual parameters.
If you have any questions, we’re happy to help.
But please start a new thread for that.
5. Start LinuxCNC
If there are any errors, you’ll see a message right away.
And importantly, most questions and issues have already been posted and answered in the forum. The forum search will surely answer most of your questions.
If you get stuck, just ask—we’re here to help.
Best regards
The following user(s) said Thank You: tommylight, spumco, DemonClaW
3 months 3 days ago #348162 by Jugo2
Replied by Jugo2 on topic StepperOnline A6 Servo
Hey, could anyone with a “2 motors on one axis” setup send his config in this tread, im a little stuck configuring my setup
3 months 3 days ago #348163 by Spezidrohne
Yes, can Post it this afternoon. But Keeper ik mind it currently is configured for my bench test setup, and homes without homing Switches.
The following user(s) said Thank You: Jugo2
3 months 3 days ago #348167 by tommylight
All are for plasma machines, all tandem Y axis, all have home switches, and one is for parallel port.
Time to create page: 0.452 seconds
