update-ethercat-config
1 year 7 months ago #325205 by rodw
Replied by rodw on topic update-ethercat-config
Just to confim its not my repository, I just made existing repositories usable as easy as we could and joined some dots...
I started this because I was trying to install into Debian 11 and the old code repo was no longer maintained (it had moved).
The Etherlab team who provide the Ethercat master published their own repository
Then they got permission to add the ethercat-linuxcnc hal driver to that repository
Then Scott Laird got permission to take over management of the Ethercat hal driver and added a lot of extra drivers
Following that I made some introductions and now Scott's hal driver has a Buildbot that pushes any changes across to the Etherlab repo so everything is kept up to date in one place.
The cool thing about all this is Ethercat is available to Linuxcnc without Linuxcnc hosting anything which it cannot do due to licencing restrictions that require licencees of Ethercat be a registered company.
Finally, because I built the 2.9.x installer, I preinstalled the Etherlab repository into apt in the ISO on our downloads page.
So the easiest path to install Ethercat is to install the Debian 12 ISO and follow the sticky which is loosely Rod's repo install.
Now if you are using another Operating System or Linuxcnc 2.10, I wrote a script on this sticky which should set up apt on your system and install Ethercat.
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
1 year 7 months ago #325242 by papagno-source
I apologize, but I ask you for help.
At this point if I used 2.9.x I have to perform a procedure, while for 2.10, I have to perform another procedure.
I installed debian 12 with uspace, from the iso image downloaded from the lunuxcnc download.
The next procedure to correctly install Ethercat and linux cnc to compile, where can I find it?
Many thanks
1 year 7 months ago #325251 by Hakan
Replied by Hakan on topic update-ethercat-config
That should be here forum.linuxcnc.org/ethercat/45336-etherc...step-by-step?start=0
You don't need to compile anything, it is ready to use.
Time to create page: 0.048 seconds
