- Thank you received: 599
Nah estop-loop doesn't work right in practice without extra logic components either. The way it's shown in the other thread it does block the UI Estop, but the reset won't trigger until you toggle the UI button afterwards. I just didn't notice I still had iocontrol.0.emc-enable-in connected to iocontrol.0.emc-enable-in. I just needed to break that with a NC circuit. Maybe one day somebody will rework the mess that exists between halui and iocontrol estop pins. It would probably be as simple as adding 2 pins to halui to break the iocontrol loop when is-activated=true. If that loop is unused it would behave as it does now, like a toggle off a momentary switch.....That's besides the point, I figured it out.Take a look at this thread for the coordination of an external E-Stop with LinuxCNC
forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
If they followed the same logic as the actual E-stop and Power states like the button labels do they'd be fine. You can test it easily by setting the halui.estop activate, reset and halui.machine.on pinsI have not tested an external E-Stop so the colors may not stay in sync.
I'm downloading the deb release from the git page. It's still at 1.1.1 but is says it's been updated since then.Your screen shot looks correct. I added multi state labels on the 20th, how are you updating?
JT
