- Thank you received: 167
There's a note in your docs:
What bold text thing?
JT
Not sure if that's referring to the same thing but normal fonts set to bold appear fine in Designer. When run the bold text is missing. I've only tried the dark-tough theme so far but this:NoteThere is an documented issue with Qt5 Designer and bold fonts not appearing properly.
Yes you should check out the themes thread I uploaded fresh screen shots.I haven't played with the qss builder but I did update to 1.1.1 this morning so it sounds like you are saying I should be seeing bold text with the dark-touch theme?
