- Thank you received: 599
The ini entry INPUT is now THEME gnipsel.com/linuxcnc/flexgui/ini.html#themesDidn't get a chance to update and try the label yet as I'm working on the hal file at the moment. Couple of things I'm noticing now that I'm running some sims......
Since I added a qss, INPUT = TOUCH seems to not have an effect anymore. Pretty sure I had the touch style file browser before the qss but now it is back to the normal one.
The file browser is a little hard to navigate because it doesn't show the current directory, easy to get lost. Any chance you can add current directory at the top or something?
The flood and mist push buttons disable when a program is running. I'm used to Gmoccapy where you can still operate the mist and flood while running a program. Sometimes I forget to add coolant to the program and need to turn it on when it's running. Not quite sure why yet but as soon as the GUI disables coolant even if I stop the program I can't control it again with the hal buttons until I first turn it on with the GUI buttons.
Do you have an example of what you mean? I'm having a hard time visualizing that...The file browser is a little hard to navigate because it doesn't show the current directory, easy to get lost. Any chance you can add current directory at the top or something?
THEME = touch overrides my qss. I get the touch file browser back be it's using whatever qss the theme uses instead of the one I specified with QSS =. Can I add the touch style file browser to my qss?The ini entry INPUT is now THEME gnipsel.com/linuxcnc/flexgui/ini.html#themes
Which file browser, the keyboard or the touch screen?
Good point on the flood and mist and I see no reason to disable them at any time and that has been fixed.
JT
